ICPT3.15A250V
ICPT3.15A250V
    WALTER(华德)
    插件,4x11mm
    陶瓷管保险丝
ICPT3.15A250V 数据手册
Ceramic Tube Fuses ICP Series / 3.6×10 mm / Time-Lag Type I-T Characteristics / 時間-電流特性 Ampere Rating 額定電流 % of Ampere Rating 額定電流% 250mA~6.3A Opening Time 熔斷時間 150% 1 Hrs Min. / 最短1小時 210% 2Min Max. / 最長2分鐘 275% 400ms Min.10s Max. / 最短400毫秒, 最長10秒 400% 150ms Min. 3s Max. / 最短150毫秒, 最長3秒 1000% 20ms Min. 150ms Max. / 最短20毫秒, 最長150毫秒 In accordance with IEC60127-3 standard,sheet 2&4 / 遵循 IEC60127-3, 規格單2&4 Product Features / 產品特性 Materials 材質 Operating Temperature 操作溫度 Solderability 可焊性 Resistance to Soldering Heat 耐焊接熱 Body / 本體:ceramic tube / 陶瓷管 Lead / 引線:tinned copper wire / 鍍錫銅線 Cap / 銅帽:brass with nickel plated / 銅鍍鎳 Element / 熔絲:alloy / 合金線 Dimensions / 尺寸圖 (Unit / 單位:mm) -55℃ to +125℃ (consider de-rating / 需考慮溫度折減) 260℃, ≤ 3s. (wave / 波峰焊) 350±10℃, ≤ 3s. (soldering iron / 烙鐵焊) 30±2 11±1 260℃, 10s. (wave / 波峰焊) 350℃, 5s. (soldering iron / 烙鐵焊) Ø0.6±0.02 Recommended Soldering Parameters 建議焊錫參數 Storage Conditions 儲存條件 Wave soldering parameter / 波峰焊 Soldering pot temperature / 錫爐溫度:260℃ Max Solder dwell time / 焊接時間:2∼5s Ø4.0±0.2 Hand welding parameter / 手工焊 Soldering iron temperature / 烙鐵溫度:350±5℃ Solder dwell time / 焊接時間:5s Max. Can be stored for 3 years under tight seal condition at temperature of +10℃~60℃, relative humidity ≤ 75%. 在溫度+10℃~60℃,相對濕度 ≤ 75% 的密閉條件下可存放 3 年。 At most can be kept 30 days at temperature +10℃~60℃, relative humidity ≤ 95% under covered conditions. 在溫度+10℃~60℃,相對濕度為 95% 的非露天下最多可存放 30 天。 Electrical Characteristics / 電氣特性 23 Safety Approvals 安全認證 Rated Current Rated Voltage Breaking Capacity 額定電流 額定電壓 分斷能力 250mA 250V ● ● ● ● ● 315mA 250V ● ● ● ● ● 400mA 250V ● ● ● ● ● 500mA 250V ● ● ● ● ● 630mA 250V ● ● ● ● ● 800mA 250V 250mA~3.15A ● ● ● ● ● 1.00A 250V 35A@250V AC ● ● ● ● ● 1.25A 250V ● ● ● ● ● 1.60A 250V ● ● ● ● ● 2.00A 250V ● ● ● ● ● 2.50A 250V ● ● ● ● ● 3.15A 250V ● ● ● ● ● 4.00A 250V ● ● ● ● ● 5.00A 250V ● ● ● ● ● 6.30A 250V ● ● ● ● ● Ceramic Tube Fuses : ICP Series 4A~6.3A 10IN@250V AC www.walterfuse.com
ICPT3.15A250V 价格&库存
很抱歉,暂时无法提供与“ICPT3.15A250V”相匹配的价格&库存,您可以联系我们找货
