FSD F5AL250V(P)
FSD F5AL250V(P)
    WALTER(华德)
    插件,5.2x20mm
    玻璃管保险丝
FSD F5AL250V(P) 数据手册
Glass Tube Fuses FSD Series / 5.2×20 mm, Fast Acting Type I-T Characteristics / 時間-電流特性 Ampere Rating 額定電流 % of Ampere Rating 額定電流% 200mA~6.3A Opening Time 熔斷時間 1 Hr Min. / 最短1小時 150% 30min Min. / 最短30分鐘 8A~15A 200mA~15A 210% 30min Max. / 最長30分鐘 200mA~15A 275% 50ms Min. 2s Max. / 最短50毫秒,最長2秒 200mA~6.3A 10ms Min. 300ms Max. / 最短10毫秒,最長300毫秒 400% 10ms Min. 400ms Max. / 最短10毫秒,最長400毫秒 8.0A~15A 200mA~6.3A 20ms Max. / 最長20毫秒 1000% 40ms Max. / 最長40毫秒 8.0A~15A In accordance with IEC60127-2 standard, sheet2 / 遵循IEC60127-2, 規格單2 Product Features / 產品特性 Materials 材質 Operating Temperature 操作溫度 Solderability 可焊性 Resistance to Soldering Heat 耐焊接熱 Dimensions / 尺寸圖 Body / 本體:glass tube / 玻璃管 Lead / 引線:tinned copper wire / 鍍錫銅線 Cap / 銅帽:brass with nickel plated / 銅鍍鎳 Element / 熔絲:alloy / 合金線 (Unit / 單位:mm) 20±0.5 -55℃ to +125℃ (consider de-rating / 需考慮溫度折減) 5.1±0.6 260℃, ≤ 3s. (wave / 波峰焊) 350±10℃, ≤ 3s. (soldering iron / 烙鐵焊) Ø5.2+0.1 -0.2 260℃, 10s. (wave / 波峰焊) 350℃, 5s. (soldering iron / 烙鐵焊) 38±2 Recommended Soldering Parameters 建議焊錫參數 Storage Conditions 儲存條件 Wave soldering parameter / 波峰焊 Soldering pot temperature / 錫爐溫度:260℃ Max Solder dwell time / 焊接時間:2∼5s 21.5±1 Ø0.8±0.02 Hand welding parameter / 手工焊 Soldering iron temperature / 烙鐵溫度:350±5℃ Solder dwell time / 焊接時間:5s Max. Ø5.9±0.2 Can be stored for 3 years under tight seal condition at temperature of +10℃~60℃, relative humidity ≤ 75%. 在溫度+10℃~60℃,相對濕度 ≤ 75% 的密閉條件下可存放 3 年。 At most can be kept 30 days at temperature +10℃~60℃, relative humidity ≤ 95% under covered conditions. 在溫度+10℃~60℃,相對濕度為 95% 的非露天下最多可存放 30 天。 Electrical Characteristics / 電氣特性 Rated Voltage Breaking Capacity 額定電流 額定電壓 分斷能力 200mA 250V ● ● ● ● ● 250mA 250V ● ● ● ● ● 315mA 250V ● ● ● ● ● 400mA 250V ● ● ● ● ● 500mA 250V ● ● ● ● ● 630mA 250V ● ● ● ● ● 800mA 250V ● ● ● ● ● 1.00A 250V ● ● ● ● ● ● 1.25A 250V ● ● ● ● ● ● 1.60A 250V ● ● ● ● ● ● 2.00A 250V ● ● ● ● ● ● 2.50A 250V ● ● ● ● ● ● 3.15A 250V ● ● ● ● ● ● 4.00A 250V ● ● ● ● ● ● 5.00A 250V ● ● ● ● ● ● 6.30A 250V ● ● ● ● ● ● 8.00A 125V/250V ● ● 10.0A 125V/250V ● ● 12.0A 125V/250V ● ● ● 15.0A 125V/250V ● ● ● Remark: *FSD 8A~15A approved KC 37 Safety Approvals 安全認證 Rated Current 200mA~3.15A 35A@250V AC 4A~15A 10IN@250V AC 250V only. *125V Voltage only for Glass Tube Fuses : FSD Series , and ● ● . www.walterfuse.com
FSD F5AL250V(P) 价格&库存
很抱歉,暂时无法提供与“FSD F5AL250V(P)”相匹配的价格&库存,您可以联系我们找货
