GSR12V15FCSET
GSR12V15FCSET
    BOSCH(博世)
    BOSCH - GSR12V15FCSET - Drill, Cordless, 12 V, 2 Ah, 10 mm Chuck, 30 N-m
GSR12V15FCSET 数据手册
0 601 9F6 070 – GSR 12V-15 FC Material number EAN Baretool number 1/2 L-BOXX inlay 12 V adapters 1 600 A01 1UW 1/2 L-BOXX inlay for tool and charger 0 601 9F6 070 0 601 9F6 002 0 601 9F6 071 3601JF6000 3601JF6000 3601JF6000 ✓ ✓ ✓ ✓ ✓ ✓ 3165140847728 1 600 A00 2UV 2 x battery GBA 12 V 2.0 Ah 1 600 Z00 02X Angle adapter GFA 12-W 1 600 A00 F5K Bit holder adapter GFA 12-X 1 600 A00 F5J Drill chuck adapter GFA 12-B 1 600 A00 F5H L-BOXX 102 1 600 A00 1RP Offset angle adapter GFA 12-E 1 600 A00 F5L Quick charger GAL 1230 CV 1 600 A01 16B ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ Drill chuck, version 10-mm keyless chuck 10-mm keyless chuck 10-mm keyless chuck Weight incl. battery 0,8 kg 0,8 kg 0,8 kg Bosch Power Tools | © Robert Bosch UK Holdings Ltd | 18.05.2017 0 601 9F6 070 – GSR 12V-15 FC Technical data Technical data Torque, max. (hard/soft) 30 / 15 Nm No-load speed (1st gear / 2nd gear) 0 – 400 / 0 – 1.300 rpm Battery type Lithium-Ion Chuck capacity, min./max. 1 / 10 mm Battery voltage 12 V Weight excl. battery 0.6 kg Keyless chuck 10 mm Torque settings 20+1 Length 132 mm Height 178 mm Cell type Lithium-ion Bit holder 1/4" internal hexagon Drilling diameter Max. drilling diameter in wood 30 mm Max. drilling diameter in steel 10 mm Screw diameter Max. screw diameter 7 mm Noise/vibration information Sound pressure level 79 dB(A) Uncertainty K 3 dB Noise level The A-rated noise level of the power tool is typically as follows: Sound pressure level 79 dB(A); Sound power level dB (A). Uncertainty K= 3 dB. Sales information Positioning Redefine your limits – the flexibility of five solutions in one compact tool User benefit Versatile: Choice of five options – drill driver with a magnetic bit holder, lockable bit holder, drill chuck, angle adapter and offset angle adapter Compact: Perfect for hard-to-reach places – due to extremely compact design Performing: Convincing power – thanks to 30 Nm of torque Bosch Power Tools | © Robert Bosch UK Holdings Ltd | 18.05.2017
GSR12V15FCSET 价格&库存
很抱歉,暂时无法提供与“GSR12V15FCSET”相匹配的价格&库存,您可以联系我们找货
