EASYDRILL1200
EASYDRILL1200
    BOSCH(博世)
    BOSCH - EASYDRILL1200 - Drill, Cordless, 12 V, 1.5 Ah, 20 N-m
EASYDRILL1200 数据手册
0 603 9A2 172 – EasyDrill 1200 Material number EAN Baretool number AL 1110 CV charger 2 609 120 553 0 603 9A2 172 4053423201352 3603JA2102 ✓ Carrying case 2.1 ✓ Double screwdriver bit ✓ PBA 12 V 1.5 Ah O-A 1 607 A35 07R ✓ Bosch Power Tools | © Robert Bosch UK Holdings Ltd | 18.05.2017 0 603 9A2 172 – EasyDrill 1200 Technical data Description Product name (formatted) EasyDrill 1200 Technical data Battery voltage 12,0 V Battery capacity 1.5 Ah No-load speed (1st gear / 2nd gear) 0 – 450 / 1.650 rpm No-load speed 0 – 1.650 rpm Max. torque 20,0 Nm Max. torque for soft/hard screw. applications 11 / 20 Nm Torque settings 15 + 1 Drill chuck Keyless chuck Machine weight with battery 1,00 kg Screw diameter Screw diameter up to 6 mm Drilling diameter Drilling diameter in steel 6 mm Drilling diameter in wood 20 mm Functions 12 Volt ✓ Lithium-ion technology ✓ Bosch Electronic Cell Protection (ECP) ✓ 2-speed gearbox ✓ Application: screwdriving / drilling ✓ Softgrip ✓ Integrated work light ✓ Bosch Electronic ✓ Right-hand/left-hand rotation ✓ Forward/reverse indicator ✓ Noise/vibration information Sound pressure level 66 dB(A) Sound power level 77 dB(A) Uncertainty K 3 dB Noise level The A-rated noise level of the power tool is typically as follows: Sound pressure level 66 dB(A); Sound power level 77 dB(A). Uncertainty K= 3 dB. Bosch Power Tools | © Robert Bosch UK Holdings Ltd | 18.05.2017 0 603 9A2 172 – EasyDrill 1200 Sales information Positioning Small, lightweight, powerful – Cordless power with good value for money User benefit Syneon Chip: Intelligent control of the energy for optimum power and maximum endurance No memory effect, no self-discharge: Always ready to use thanks to lithiumion technology Compact design thanks to lithium-ion technology Other features Bosch Electronic speed control: “accelerate” from 0 – max. using the trigger switch Highperformance planetary gearbox: superior lifetime, best power transfer, high running smoothness PowerLight – thanks to the built-in LED, your workpiece is always well lit and clearly visible Torque preselection with 15 torque settings plus a drill setting – optimum power for every application Bosch Power Tools | © Robert Bosch UK Holdings Ltd | 18.05.2017
EASYDRILL1200
物料型号为“06039A2172”,EAN为“4053423201352”,Baretool number为“3603JA2102”。
该产品是Bosch Power Tools的EasyDrill 1200,具有以下技术数据: - 电池电压:12.0V - 电池容量:1.5Ah - 空载速度:0-450/1.650 rpm(1档/2档) - 最大扭矩:20.0Nm - 软/硬螺丝应用的最大扭矩:11/20Nm - 扭矩设置:15+1 - 钻夹头:无键夹头 - 机器重量(含电池):1.00kg - 螺丝直径:最大6mm - 钻孔直径:木材20mm,钢材未提供具体数值
功能特点包括: - 锂离子技术 - Bosch电子电池保护(ECP) - 2速变速箱 - 应用:拧螺丝/钻孔 - Softgrip(软握把) - 集成工作灯 - Bosch电子控制 - 右手/左手旋转 - 正/反转指示
噪音/振动信息: - 声压级:66dB(A) - 声功率级:77dB(A) - 不确定性K:3dB
销售信息中提到,该产品定位为小型、轻便、强大,具有高性价比的无绳电力工具。
用户受益于Syneon Chip的智能能量控制,以实现最佳性能和最长续航时间。
无记忆效应,无自放电:由于锂离子技术,始终准备就绪。
紧凑的设计归功于锂离子技术。
其他特点包括Bosch电子速度控制、高性能的行星齿轮箱、PowerLight内置LED、15个扭矩预设加钻孔设置等。
EASYDRILL1200 价格&库存
很抱歉,暂时无法提供与“EASYDRILL1200”相匹配的价格&库存,您可以联系我们找货
