GSB 13RE 2
GSB 13RE 2
    BOSCH(博世)
    BOSCH - GSB 13RE 2 - Impact Drill, 240 V, 13 mm Chuck, 10 mm Steel, 25 mm Wood, UK Plug
GSB 13RE 2 数据手册
Bosch Power Tools - 1-Speed Impact Drill GSB 13 RE http://www.bosch-pt.co.uk/boptocs2-uk/Product.jsp;jsessionid=94424... www.bosch-pt.co.uk 1-Speed Impact Drill GSB 13 RE The handiest tool in its class Extremely handy: no bigger than a glove and 1.6 kg light Softgrip for a secure hold Robust, twin-sleeve keyless chuck made of metal for fast tool changes Electronic control for exact pilot drilling Speed preselection with setting wheel Forward/reverse rotation Part no. 0 601 217 160 Keyless chuck 13 mm (2 608 572 105) Auxiliary handle (1 612 025 024) Depth stop 210 mm (1 613 001 010) Drill chuck, version Keyless chuck Voltage, electrical 110 V Chuck capacity 1,5 - 13 mm Spindle collar diameter 43,0 mm Part no. 0 601 217 170 Keyless chuck 13 mm (2 608 572 105) Auxiliary handle (1 612 025 024) Depth stop 210 mm (1 613 001 010) Drill chuck, version Keyless chuck Voltage, electrical 230 V Chuck capacity 1,5 - 13 mm Spindle collar diameter 43,0 mm Technical data Rated power input 600 W No-load speed 0 – 2.800 rpm Power output 301 W 1 of 2 01/12/2009 15:02 Bosch Power Tools - 1-Speed Impact Drill GSB 13 RE Weight without cable 1,8 kg Torque (soft screwdriving applications) 10,8 Nm Rated torque 1,8 Nm Drill spindle connecting thread 1/2" – 20 UNF Chuck capacity 1,5 – 13 mm Length 266,0 mm Height 180,0 mm Impact rate at no-load speed 0 – 44.800 bpm http://www.bosch-pt.co.uk/boptocs2-uk/Product.jsp;jsessionid=94424... Drilling range Drilling dia. in concrete 13 mm Drilling dia. in wood 25 mm Drilling dia. in steel 10 mm Drilling dia. in masonry 15 mm Functions 2 of 2 Infinitely variable speed control Forward/reverse operation Electronic Softgrip 01/12/2009 15:02
GSB 13RE 2 价格&库存
很抱歉,暂时无法提供与“GSB 13RE 2”相匹配的价格&库存,您可以联系我们找货
