GSB182LIPLUS
GSB182LIPLUS
    BOSCH(博世)
    BOSCH - GSB182LIPLUS - CORDLESS COMBI DRILL, 18V, 1900RPM
GSB182LIPLUS 数据手册
0 601 9E7 170 – GSB 18-2-LI Plus Material number EAN Baretool number 0 601 9E7 170 0 601 9E7 102 0 601 9E7 103 0 601 9E7 173 0 601 9E7 174 3165140817783 3601JE7100 3601JE7100 3601JE7100 3601JE7100 1 x battery GBA 18 V 4.0 Ah 3601JE7100 3601JE7100 ✓ 1 600 Z00 038 1/2 L-BOXX inlay for accessories 0 601 9E7 175 ✓ 1 600 A00 2WC 1/2 L-BOXX inlay for tool 1 600 A00 2WA ✓ ✓ 2 x battery GBA 18 V 1.5 Ah ✓ 1 600 Z00 035 2 x battery GBA 18 V 2.0 Ah 1 600 Z00 036 ✓ 25-piece screwdriver bit set 2 607 017 037 ✓ ✓ ✓ ✓ AL 1820 quick charger ✓ 2 607 225 425 ✓ Carrying case Carton 2 607 225 426 L-BOXX 136 1 600 A00 1RR ✓ ✓ ✓ 1,5 kg 1,5 kg ✓ ✓ Quick Charger AL 1820 CV ✓ 2 607 225 424 Weight incl. battery ✓ ✓ L-BOXX-ready Charger AL 1820 CV ✓ 1,5 kg 1,5 kg Bosch Power Tools | © Robert Bosch UK Holdings Ltd | 18.05.2017 1,5 kg 1,5 kg 0 601 9E7 170 – GSB 18-2-LI Plus Technical data Technical data Torque, max. (hard/soft) 63 / 24 Nm No-load speed (1st gear / 2nd gear) 0 – 500 / 0 – 1.900 rpm Chuck capacity, min./max. 1,5 / 13 mm Drill spindle thread 1/2" Battery voltage 18 V Battery capacity 2,0 Ah Weight excl. battery 1.2 kg Torque settings 20+1 Length 202 mm Height 230 mm Drilling diameter Max. drilling diameter in wood 38 mm Max. drilling diameter in steel 13 mm Max. drilling diameter in masonry 13 mm Screw diameter Max. screw diameter 8 mm Noise/vibration information Sound pressure level 89 dB(A) Sound power level 100 dB(A) Uncertainty K 3 dB Noise level The A-rated noise level of the power tool is typically as follows: Sound pressure level 89 dB(A); Sound power level 100 dB(A). Uncertainty K= 3 dB. Bosch Power Tools | © Robert Bosch UK Holdings Ltd | 18.05.2017 0 601 9E7 170 – GSB 18-2-LI Plus Sales information Positioning Best price/performance ratio among professional cordless combis User benefit Attractive solution for the entry-level segment of professional applications Keyless chuck with 13mm bit holder for common accessories New ergonomics: Better handling due to compact design Other features Bosch Electronic Cell Protection (ECP): protects the battery against overload, overheating and deep discharge Electronic Motor Protection (EMP) protects the motor against overload and ensures a long lifetime Integrated LED light for illuminating the work area, even in dark places Mountable bit holder for easy transport and storage of bits on the tool Practical belt clip for conveniently hanging the tool on a belt or ladder Motor brake for precise work when driving rows of screws Bosch Power Tools | © Robert Bosch UK Holdings Ltd | 18.05.2017
GSB182LIPLUS 价格&库存
很抱歉,暂时无法提供与“GSB182LIPLUS”相匹配的价格&库存,您可以联系我们找货
