2608580413
2608580413
    BOSCH(博世)
2608580413 数据手册
Hole Saw Leafleat 3*6*09:Layout 1 6/3/09 2:50 PM Page 1 Reliable Hole Saw with Allround Application New! The HSS bimetal hole saw with standard adapter system. Hole Saw Leafleat 3*6*09:Layout 1 6/3/09 2:51 PM Page 2 Special tooth geometry The vario-pitch tooth technology and improved gullets enable faster and smoother cutting. High quality material The Bosch HSS bi-metal hole saw composes of HCS carrier and HSS teeth which provides extended lifetime. Broad range Complete range from14mm to 152 mm, Multiple application: It cuts in metal,aluminium, plastic and wood. covers all important diameters. Standard adapter system It fits not only Bosch adapter but also most bimetal hole saw adapter systems c od e 38 1 2608580396 3165140518185 57 38 1 2608580423 3165140518451 16 38 1 2608580397 3165140518192 59 38 1 2608580424 3165140518468 17 38 1 2608580398 3165140518208 60 38 1 2608580425 3165140518475 19 38 1 2608580399 3165140518215 64 38 1 2608580426 3165140518482 20 38 1 2608580400 3165140518222 65 38 1 2608580427 3165140518499 21 38 1 2608580401 3165140518239 67 38 1 2608580428 3165140518505 22 38 1 2608580402 3165140518246 68 38 1 2608580429 3165140518512 24 38 1 2608580403 3165140518253 70 38 1 2608580430 3165140518529 25 38 1 2608580404 3165140518260 73 38 1 2608580431 3165140518536 27 38 1 2608580405 3165140518277 76 38 1 2608580432 3165140518543 29 38 1 2608580406 3165140518284 79 38 1 2608580433 3165140518550 30 38 1 2608580407 3165140518291 83 38 1 2608580434 3165140518567 32 38 1 2608580408 3165140518307 86 38 1 2608580435 3165140518574 33 38 1 2608580409 3165140518314 89 38 1 2608580436 3165140518581 35 38 1 2608580410 3165140518321 92 38 1 2608580437 3165140518598 37 38 1 2608580411 3165140518338 95 38 1 2608580438 3165140518604 38 38 1 2608580412 3165140518345 98 38 1 2608580439 3165140518611 40 38 1 2608580413 3165140518352 102 38 1 2608580440 3165140518628 41 38 1 2608580414 3165140518369 105 38 1 2608580441 3165140518635 43 38 1 2608580415 3165140518376 108 38 1 2608580442 3165140518642 44 38 1 2608580416 3165140518383 111 38 1 2608580443 3165140518659 46 38 1 2608580417 3165140518390 114 38 1 2608580444 3165140518666 48 38 1 2608580418 3165140518406 121 38 1 2608580445 3165140518673 51 38 1 2608580419 3165140518413 127 38 1 2608580446 3165140518680 52 38 1 2608580420 3165140518420 140 38 1 2608580447 3165140518697 54 38 1 2608580421 3165140518437 152 38 1 2608580448 3165140518703 56 38 1 2608580422 3165140518444 06 14 Singapore. EA N Par t nu mb er Dia me ter mm Cut tin Dep g th mm Sal es pac qua kag ntit e y c od e EA N Par t nu mb er Dia me ter mm Cut tin Dep g th mm Sal es pac qua kag ntit e y in the market.
2608580413 价格&库存
很抱歉,暂时无法提供与“2608580413”相匹配的价格&库存,您可以联系我们找货
