GST 150 BCE PROFESSIONAL
    BOSCH(博世)
    BOSCH - GST 150 BCE PROFESSIONAL - JIGSAW, 780W, 240V, 3100SPM, UK PLUG
GST 150 BCE PROFESSIONAL 数据手册
GST 150 BCE Professional Advantages: GST 150 BCE Professional The most powerful tool in its price class  High power reserves, even in hard and thick beams, due to powerful and overload-capable 780watt motor  Extremely robust and bend-resistant sole plate for the toughest jobs  High cutting precision due to new saw blade clamping system  Tool-free saw blade clamping system for easy and fast saw blade changes  Ergonomic grip area with softgrip surfaces for a high level of work comfort  4-stage pendulum action for fine through to coarse cuts  Electronic speed preselection Technical data: GST 150 BCE Professional Rated power input 780 W No-load stroke rate 500 – 3.100 spm Weight 2,7 kg Cable length 4m Stroke height 26 mm Cutting depth Rated power input 780 W Cutting depth in wood 150 mm Cutting depth in aluminium 20 mm Cutting depth in non-alloyed steel 10 mm Functions  Pendulum stroke adjustment  Dust extraction  Bosch SDS System  Electronic  Constant Electronic Noise/vibration information Measured values determined according to EN 60745 Total vibration values (vector sum of three directions) Sawing sheet metal Vibration emission value ah 4.0 m/s² Uncertainty K 1.5 m/s² Sawing wood Vibration emission value ah 7.0 m/s² Uncertainty K 1.5 m/s² The A-rated noise level of the power tool is typically as follows: Sound pressure level 83 dB(A); Sound power level 94 dB(A). Uncertainty K= 3 dB.
GST 150 BCE PROFESSIONAL 价格&库存
很抱歉,暂时无法提供与“GST 150 BCE PROFESSIONAL”相匹配的价格&库存,您可以联系我们找货
