26150688JA
26150688JA
    DREMEL
26150688JA 数据手册
Accessory Kits Cutting Set (688) Assortment of 68 cut-off wheels in a convenient box. Removable accessory tray and 3 dividers provide perfect storage solution. Dremel Quick Start leaflet explains the included accessories. Included accessories Cutting 409(36), 420(24), 426(3), 540(5) Collets / Mandrels / Miscellaneous 402 Order information Ordernumber: 26150688JA EAN: 8710364029112 47 Cutting 1. DREMEL® SpeedClic® 1 SC406 2 3 SC426 Dremel, the inventor of the Multitool, now brings you SpeedClic - an innovation that makes changing cut-off wheels quick and easy. Through a patented mandrel and wheel design, Dremel has found a way that enables you to change your accessory in 3 simple steps - Pull, Click, Twist - without using any tools. The Starter Set SC406 includes the new SpeedClic mandrel and two SpeedClic cut-off wheels. The fiberglass reinforced cutoff wheels SC426 are replacement cut-off wheels specifically for the SpeedClic system. Al Model Ag Cu Plastic Quantity Working ø mm Shank ø mm Ordernumber EAN SC406 1+2 32.0 3.2 2615S406JA 8710364033461 SC426 5 32.0 3.2 2615S426JA 8710364033478 2. Cut-Off Wheels 426B 456 426 540 420 409 For slicing and cutting in metal, wood and plastic. Cut-off wheels make it easy to cut or slot bolts, screws, sheet metal, thin wood and plastic. Fiberglass reinforced cut-off wheels (456, 426, 426B) are for tough applications. The cut-off wheel cuts only along its edge. Do not attempt to sand or cut curved holes with them. Use Dremel cut-off wheels with mandrel 402. Al 36 Ag Cu Plastic Model Quantity Working ø mm Shank ø mm Ordernumber EAN 426B 20 32.0 3.2 2615426BJA 8710364026296 456 10 38.0 3.2 26150456JA 8710364023011 426 5 32.0 3.2 2615042632 8710364007448 540 5 32.0 3.2 2615054032 8710364010516 420 20 24.0 3.2 2615042032 8710364007431 409 36 24.0 3.2 2615040932 8710364007424 DREMEL-Trade-Catalogue 2007/2008
26150688JA 价格&库存
很抱歉,暂时无法提供与“26150688JA”相匹配的价格&库存,您可以联系我们找货
