2615S456JD
2615S456JD
    DREMEL
2615S456JD 数据手册
Dremel - DREMEL SpeedClic: Metal Cutting Wheels 12-Pack. (SC456B) 1 of 1 http://www.dremeleurope.com/dremelocs-uk/Product.jsp;jsessionid=B... Home | Accessories | Cutting | DREMEL® SpeedClic®: Starter Set and Cutting Wheels DREMEL® SpeedClic®: Metal Cutting Wheels 12-Pack. (SC456B) Dremel, the inventor of the SpeedClic quick-change system for rotary tool accessories, now offers an extended line of SpeedClic metal cutting accessories. The Starter Set SC406 includes the unique SpeedClic mandrel and two fiberglass reinforced metal cutting wheels. The SC456, SC456B and SC409 are replacement metal cutting wheels, whereby the SC409 wheels have a thickness of just 0,75 mm. 3,2 mm Features & Benefits Contents The fiberglass reinforced cutting wheels are for cutting in all sorts of metals. Quick, Easy, Keyless. Technical specification Shank diameter: 3,2 mm Working diameter: 38,0 mm Quantity: 12 Order number: 2615S456JD EAN-Code: 8710364042845 17/04/2009 15:53
2615S456JD 价格&库存
很抱歉,暂时无法提供与“2615S456JD”相匹配的价格&库存,您可以联系我们找货
2615S456JD
    • 1+157.22812
    库存:382
