26150687JA
26150687JA
    DREMEL
26150687JA 数据手册
Accessory Kits Cleaning / Polishing Set (684) All you need for cleaning and polishing in a convenient box. Removable accessory tray and 3 dividers provide perfect storage solution. Dremel Quick Start leaflet explains the included accessories. Included accessories Cleaning / Polishing 403, 404, 405, 428, 520, 414(6), 422, 425(2), 429(3), 421 Collets / Mandrels / Miscellaneous 401, 402 Order information Ordernumber: 26150684JA EAN: 8710364029099 Multipurpose Set (687) Assortment of best selling accessories in a convenient box. Removable accessory tray and 3 dividers provide perfect storage solution. Dremel Quick Start leaflet explains the included accessories. Included accessories Carving / Engraving / Routing 194 Grinding / Sharpening 952, 85422 Cleaning / Polishing 403, 414(2), 429(2), 421 Cutting 409(36), 426 Sanding 407, 408, 432(2) Collets / Mandrels / Miscellaneous 401, 402 Order information 46 Ordernumber: 26150687JA DREMEL-Trade-Catalogue 2007/2008 EAN: 8710364029105 Carving / Engraving / Routing 1. Engraving Cutters 105 106 107 108 110 111 113 Quality cutters for detail engraving, carving, routing in wood, fiberglass, plastic and soft metals. Plastic Plexi Model Quantity Working ø mm 105 1 0.8 106 1 1.6 107 1 2.4 108 1 110 Shank ø mm Ordernumber EAN 2.4 2615010532 8710364007288 2.4 2615010632 8710364007295 2.4 2615010732 8710364007301 0.8 2.4 2615010832 8710364007318 1 1.9 2.4 2615011032 8710364007820 111 1 0.8 2.4 2615011132 8710364007837 113 1 1.6 2.4 2615011332 8710364007325 2. High Speed Cutters 114 196 199 194 115 117 118 125 134 144 192 193 High speed cutters can be used for shaping, hollowing, grooving, slotting, making tapered holes in soft metals, plastics and woods. Plastic Model 26 Quantity Plexi Working ø mm Shank ø mm Ordernumber EAN 8710364007868 114 1 7.8 3.2 2615011432 196 1 5.6 3.2 2615019632 8710364007394 199 1 9.5 3.2 2615019932 8710364007400 194 1 3.2 3.2 2615019432 8710364007387 115 1 7.8 3.2 2615011532 8710364007332 117 1 6.4 3.2 2615011732 8710364007875 118 1 3.2 3.2 2615011832 8710364007349 125 1 6.4 3.2 2615012532 8710364007356 134 1 7.2 3.2 2615013432 8710364007912 144 1 7.8 3.2 2615014432 8710364007936 192 1 4.8 3.2 2615019232 8710364007363 193 1 2.0 3.2 2615019332 8710364007370 DREMEL-Trade-Catalogue 2007/2008 Grinding / Sharpening 1. Aluminum Oxide Grinding Wheel 541 Use for deburring, rust removal and general purpose grinding. Use with mandrel 402. Ag Cu Model Quantity Working ø mm Shank ø mm Ordernumber EAN 541 2 22.4 3.2 2615054132 8710364010523 2. Aluminum Oxide Grinding Stones 911 932 952 953 997 8153 8175 8193 8215 Use on metals, castings,welded joints, rivets and rust. Ideal for sharpening, deburring and general purpose grinding of most materials. Ag Model Cu Quantity Working ø mm 911 1 11.1 932 1 9.5 952 1 9.5 953 1 997 1 8153 1 8175 1 8193 8215 Shank ø mm Ordernumber EAN 3.2 2615091132 8710364008056 3.2 2615093232 8710364007455 3.2 2615095232 8710364007462 6.4 3.2 2615095332 8710364007479 3.4 3.2 2615099732 8710364007486 4.8 3.2 2615815332 8710364008124 9.5 3.2 2615817532 8710364008131 1 15.9 3.2 2615819332 8710364007493 1 25.4 3.2 2615821532 8710364008148 29 Grinding / Sharpening 3. Silicon Carbide Grinding Stones 83142 83322 83702 84922 85422 85602 Designed to work well on stone, glass, ceramics, porcelain and non-ferrous metals. Model Quantity Working ø mm Shank ø mm Ordernumber EAN 83142 1 7.0 3.2 2615314232 8710364016815 83322 1 3.2 3.2 2615332232 8710364016808 83702 1 3.2 3.2 2615370232 8710364016792 84922 1 4.8 3.2 2615492232 8710364016860 85422 1 19.8 3.2 2615542232 8710364016853 85602 1 10.3 3.2 2615560232 8710364016846 4. Abrasive Points 516 518 Use for finishing work and light deburring. For paint and rust removal without removing any of the base material. Ag 30 Cu Model Quantity Working ø mm Shank ø mm 516 1 13.0 518 1 13.0 DREMEL-Trade-Catalogue 2007/2008 Ordernumber EAN 3.2 2615051632 8710364015238 3.2 2615051832 8710364015245 Cleaning / Polishing 3. Polishing Wheels 414 422 423 429 425 421 Ideal for polishing metals and plastics. Using polishing compound no. 421 with wheels produces a high luster. Use 414, 422 and 429 with mandrel 401. Use 423 and 425 with mandrel 402. Al Ag Cu Plastic Working ø mm Plexi Model Quantity Shank ø mm Ordernumber EAN 414 6 13.0 3.2 2615041432 8710364007141 422 1 10.0 3.2 2615042232 8710364007158 423 1 26.0 3.2 2615042332 8710364007165 429 1 26.0 3.2 2615042932 8710364007189 425 1 22.5 3.2 2615042532 8710364007172 421 1 2615042132 8710364008452 4. Bristle Brushes 403 404 405 Use for light deburring, cleaning, polishing of silverware, jewellery and other precious metals. Can be used with polishing compound (421). Al Model Ag Cu Quantity Working ø mm Shank ø mm Ordernumber EAN 403 1 19.0 3.2 2615040332 8710364007127 404 1 13.0 3.2 2615040432 8710364007134 405 1 3.2 3.2 2615040532 8710364008230 33 Cutting 1. DREMEL® SpeedClic® 1 SC406 2 3 SC426 Dremel, the inventor of the Multitool, now brings you SpeedClic - an innovation that makes changing cut-off wheels quick and easy. Through a patented mandrel and wheel design, Dremel has found a way that enables you to change your accessory in 3 simple steps - Pull, Click, Twist - without using any tools. The Starter Set SC406 includes the new SpeedClic mandrel and two SpeedClic cut-off wheels. The fiberglass reinforced cutoff wheels SC426 are replacement cut-off wheels specifically for the SpeedClic system. Al Model Ag Cu Plastic Quantity Working ø mm Shank ø mm Ordernumber EAN SC406 1+2 32.0 3.2 2615S406JA 8710364033461 SC426 5 32.0 3.2 2615S426JA 8710364033478 2. Cut-Off Wheels 426B 456 426 540 420 409 For slicing and cutting in metal, wood and plastic. Cut-off wheels make it easy to cut or slot bolts, screws, sheet metal, thin wood and plastic. Fiberglass reinforced cut-off wheels (456, 426, 426B) are for tough applications. The cut-off wheel cuts only along its edge. Do not attempt to sand or cut curved holes with them. Use Dremel cut-off wheels with mandrel 402. Al 36 Ag Cu Plastic Model Quantity Working ø mm Shank ø mm Ordernumber EAN 426B 20 32.0 3.2 2615426BJA 8710364026296 456 10 38.0 3.2 26150456JA 8710364023011 426 5 32.0 3.2 2615042632 8710364007448 540 5 32.0 3.2 2615054032 8710364010516 420 20 24.0 3.2 2615042032 8710364007431 409 36 24.0 3.2 2615040932 8710364007424 DREMEL-Trade-Catalogue 2007/2008 Sanding 1. Sanding Bands 407 408 432 430 431 438 439 440 444 For rough shaping and smoothing wood and fiberglass, removing rust from metal surfaces and shaping rubber surfaces. Sanding bands are easily replaceable. Al Model Quantity Ag Working ø mm Plastic Cu Shank ø mm Plexi Grit Ordernumber EAN 8710364007226 407 1 13.0 3.2 60 2615040732 408 6 13.0 3.2 60 2615040832 8710364007233 432 6 13.0 3.2 120 2615043232 8710364007264 430 1 6.4 3.2 60 2615043032 8710364007240 431 6 6.4 3.2 60 2615043132 8710364007257 438 6 6.4 3.2 120 2615043832 8710364007271 439 1 9.5 3.2 60 2615043932 8710364008391 440 6 9.5 3.2 60 2615044032 8710364008407 444 6 9.5 3.2 120 2615044432 8710364008414 2. Flapwheels 502 504 Perfect for sanding flat or contoured surfaces on metal, wood, rubber or plastic. Al 40 Ag Working ø mm Cu Plastic Model Quantity 502 1 28.6 3.2 80 2615050232 8710364015252 504 1 28.6 3.2 80 2615050432 8710364015269 DREMEL-Trade-Catalogue 2007/2008 Shank ø mm Grit Ordernumber EAN
26150687JA 价格&库存
很抱歉,暂时无法提供与“26150687JA”相匹配的价格&库存,您可以联系我们找货
26150687JA
  • 1+183.33561
库存:54
