F0132200JA
F0132200JA
    DREMEL
F0132200JA 数据手册
4/25/14 DREMEL® VersaFlame (2200-4) DREMEL® VersaFlame (2200-4) The Dremel VersaFlame is the only stationary burner that safely combines open flame use with a catalyst and soldering head, making it the most versatile stationary burner in the market today, especially for DIY applications The Dremel VersaFlame is powered by liquid butane gas for quick heat-up and fast recharge. Applications can be described as: soldering, shrinking, welding, etc. PACKAGING CONTENTS Dremel VersaFlame Catalyst Soldering tip Flame extension piece Deflector Soldering tin with blue cap Soldering sponge + sponge box Inspiring welcome poster Instruction manual Tin storage case TECHNICAL SPECIFICATIONS Weight: Ignition: Burn time : Tank capacity: Temperature: Order number: EAN-Code: 0,227 kg Piëzo 75 min 42ml / 22g 1200C (open air) 680 - 1000C (hot air) 550C (tips) F0132200JA 8710364042081 www.dremeleurope.com/gb/en/ocs/product/6127/344/dremel®-versaflame/dremel®-versaflame 1/1
F0132200JA 价格&库存
很抱歉,暂时无法提供与“F0132200JA”相匹配的价格&库存,您可以联系我们找货
