2615S511JA
2615S511JA
    DREMEL
2615S511JA 数据手册
Sanding 1. DREMEL® EZ SpeedClic™: Detail Abrasive Brushes 471S 472S 473S The Detail Abrasive Brushes have very flexible bristles which allow removal of the exterior “surface layer” without damaging the base layer below. This can be used for deburring, cleaning, finishing, and polising of detailed parts, tiny areas and irregular places. Plastic Al Model Quantity Working Ø mm Shank Ø mm Grit Ordernumber EAN 471S 472S 473S 1 1 1 25,0 25,0 25,0 3,2 3,2 3,2 36 120 220 2615S471JA 2615S472JA 2615S473JA 8710364050314 8710364050321 8710364050338 2. DREMEL® EZ SpeedClic™: Abrasive Buffs 511S 512S 511S: 1x Finishing abrasive buff medium + 1x course. 512S: 2x Finishing abrasive buffs fine. For precise and delicate material removal on metal, glass, wood and plastic. The flexible material enables to work on tight and irregularly shaped areas. These buffs can be used with mandrels 402 as well as SC402. EZ SpeedClic. Quick, Easy, Keyless. 50 Model Quantity Working Ø mm Shank Ø mm 511S 2 25,0 3,2 512S 2 25,0 3,2 DREMEL-Catalogue 2012 Grit Ordernumber EAN 180 / 280 320 2615S511JA 8710364037100 2615S512JA 8710364037117
2615S511JA 价格&库存
很抱歉,暂时无法提供与“2615S511JA”相匹配的价格&库存,您可以联系我们找货
2615S511JA
  • 2+34.77701
库存:206
