Attachments to Cut
Multipurpose Cutting Kit (565)
• Provides controlled cutting in a variety of materials.
• Easily attaches to your Dremel tool.
• Easy depth adjustment up to 19 mm material
thickness.
Contents
Cutting Guide
2 Drywall Cutting Bits 560
1 Multipurpose Cutting Bit 561
Order information
Ordernumber: 2615056532
EAN: 8710364010622
Wall Tile Cutting Kit (566)
• Provides controlled cutting in ceramic wall tiles.
thickness.
Contents
Cutting Guide
1 Tile Cutting Bit 562 (not for use on ceramic floor tiles)
Order information
Ordernumber: 2615056632
EAN: 8710364010639
53
Cutting
5. Rip/Cross-Cut Blade
546
Precision saw blade for fine, clean and straight cuts in all sorts of wood. Perfect for laminate and wood
flooring or thin wood plates. Use only with Dremel Mini Saw attachment 670. Made of carbon steel, 48 offset
teeth guarantee precise, fast cuts up to 6.35 mm.
Model
Quantity
Working ø mm
Shank ø mm
Ordernumber
EAN
546
1
31.8
3.2
26150546JA
8710364023073
6. Spiral Cutting Bits
560
561
562
The drywall cutting bit 560 gives you fast clean cuts in drywall. The multipurpose cutting bit 561 cuts wood,
plastic, fiberglass, drywall, laminate & vinyl siding. The tile cutting bit 562 cuts ceramic wall tile, cement
board and plaster. (Not for use on floor tile)
Al
38
Plastic
Plexi
Model
Quantity
Working ø mm
Shank ø mm
Ordernumber
EAN
560
1
3.2
3.2
2615056032
8710364010592
561
1
3.2
3.2
2615056132
8710364010615
562
1
3.2
3.2
2615056232
8710364010608
DREMEL-Trade-Catalogue 2007/2008
很抱歉,暂时无法提供与“2615056532”相匹配的价格&库存,您可以联系我们找货
