26150684JA
26150684JA
    DREMEL
26150684JA 数据手册
Accessory Kits Cleaning / Polishing Set (684) All you need for cleaning and polishing in a convenient box. Removable accessory tray and 3 dividers provide perfect storage solution. Dremel Quick Start leaflet explains the included accessories. Included accessories Cleaning / Polishing 403, 404, 405, 428, 520, 414(6), 422, 425(2), 429(3), 421 Collets / Mandrels / Miscellaneous 401, 402 Order information Ordernumber: 26150684JA EAN: 8710364029099 Multipurpose Set (687) Assortment of best selling accessories in a convenient box. Removable accessory tray and 3 dividers provide perfect storage solution. Dremel Quick Start leaflet explains the included accessories. Included accessories Carving / Engraving / Routing 194 Grinding / Sharpening 952, 85422 Cleaning / Polishing 403, 414(2), 429(2), 421 Cutting 409(36), 426 Sanding 407, 408, 432(2) Collets / Mandrels / Miscellaneous 401, 402 Order information 46 Ordernumber: 26150687JA DREMEL-Trade-Catalogue 2007/2008 EAN: 8710364029105 Cleaning / Polishing 3. Polishing Wheels 414 422 423 429 425 421 Ideal for polishing metals and plastics. Using polishing compound no. 421 with wheels produces a high luster. Use 414, 422 and 429 with mandrel 401. Use 423 and 425 with mandrel 402. Al Ag Cu Plastic Working ø mm Plexi Model Quantity Shank ø mm Ordernumber EAN 414 6 13.0 3.2 2615041432 8710364007141 422 1 10.0 3.2 2615042232 8710364007158 423 1 26.0 3.2 2615042332 8710364007165 429 1 26.0 3.2 2615042932 8710364007189 425 1 22.5 3.2 2615042532 8710364007172 421 1 2615042132 8710364008452 4. Bristle Brushes 403 404 405 Use for light deburring, cleaning, polishing of silverware, jewellery and other precious metals. Can be used with polishing compound (421). Al Model Ag Cu Quantity Working ø mm Shank ø mm Ordernumber EAN 403 1 19.0 3.2 2615040332 8710364007127 404 1 13.0 3.2 2615040432 8710364007134 405 1 3.2 3.2 2615040532 8710364008230 33 Cleaning / Polishing 5. Carbon Steel Brushes 428 442 443 Versatile brush for removing rust and corrosion, polish metal surfaces, deburr and blend surface junctures or clean electrical components. Al Ag Cu Model Quantity Working ø mm Shank ø mm Ordernumber EAN 428 1 19.0 3.2 2615042832 8710364007196 442 1 13.0 3.2 2615044232 8710364007202 443 1 3.2 3.2 2615044332 8710364007219 6. High-Performance Abrasive Brush 538 High performance for deburring, cleaning, rust and corrosion removal. Can be used at higher speed than other brushes (max. 20.000 rpm) 34 Model Quantity Working ø mm Shank ø mm Ordernumber EAN 538 1 26.0 3.2 26150538JA 8710364023066 DREMEL-Trade-Catalogue 2007/2008
26150684JA 价格&库存
很抱歉,暂时无法提供与“26150684JA”相匹配的价格&库存,您可以联系我们找货
