26231708
26231708
    CROUZET(高诺斯)
    CAPACITOR6,810%
26231708 数据手册
Linear actuators -synchronous ➜ 10 mm displacement - 230 Volts ■ A range of digital linear actuators based upon synchronous motor technology. They offer a linear travel of 10 mm as standard and up to 35 mm upon request for versions with an anti-rotation device builtin. Linear step speed 0.833 or 1.67 mm per second. ■ Output force between 27 and 45 N. Specifications Type Voltages/Frequencies Standard motor speed (rpm) Part numbers General characteristics Connection Rated displacement (mm) Vitesse de déplacement (f= 50 Hz) (mm/s) Axial load static (daN) Radial load Ambient operating temperature (°C) Wires length (mm) Electromechanical specifications Dynamic axial load to 100 Hz (N) Absorbed power (W) Absorbed current nominal Temperature rise at T = 25°C Life Mounting position Storage temperature (0C) Weight (g) Low speed - series connection Low speed - parallel connection High speed - series connection High speed - parallel connection 80 510 0 230 V - 50 Hz 250 80 510 0 230 V - 50 Hz 250 80 510 5 230 V - 50 Hz 500 80 510 5 230 V - 50 Hz 500 ● ● ● ● Series 10 3.33 Series 10 3.33 Series 10 6.67 Series 10 6.67 10 Consult us -5 / +75 250 ± 10 10 Consult us -5 / +75 250 ± 10 10 Consult us -5 / +75 250 ± 10 10 Consult us -5 / +75 250 ± 10 35 2.7 10.9 mA 57°C ± 10 % 500 000 cycles Any position -40➞ +80 90 45 4.3 16 mA 80°C ± 10 % 500 000 cycles Any position -40➞ +80 90 Product adaptations 6 ■ ■ ■ ■ ■ ■ To order, see page 13 170 Special output shafts Special supply voltages Special cable lengths Customised electronics Special construction materials Special connectors 27 2.7 10.9 mA 57°C ± 10 % 500 000 cycles Any position -40➞ +80 90 38 4.3 16 mA 80°C ± 10 % 500 000 cycles Any position -40➞ +80 90 Accessories Voltages/Frequencies Capacitors motor 80 510 0 230 V - 50 Hz 230 V - 50 Hz 115 V - 50/60 Hz 24 V - 50 Hz 24 V - 60 Hz Capacitors motor 80 510 0 230 V - 50 Hz 230 V - 50 Hz 115 V - 50/60 Hz 24 V - 50 Hz µF V Connection Code 0.33 ± 10 % 0.1 ± 10 % 0.27 ± 10 % 8.2 ± 10 % 6.8 ± 10 % 400 700 250 70 63 Serie Parallel Parallel Parallel Parallel 26 231 801 26 231 941 26 231 851 26 231 711 26 231 708 0.33 ± 10 % 0.1 ± 10 % 0.27 ± 10 % 8.2 ± 10 % 400 700 250 70 Serie Parallel Parallel Parallel 26 231 801 26 231 941 26 231 924 26 231 711 Dimensions 80 510 0 - 80 510 5 31.5 max. ø4 .4 3.4 21.5 ø4.5 46 0 2 ø12 ø1 M3 23 .6 ma x. 1 3.2 11 14 4 B Shaft in C Travel Connections In series In parallel 1 1 2 2 6 SA SI SA UN B SA : Shaft out C Si : Shaft in SI UN B SA : Shaft out C SI : Shaft in Other information Electromagnetic compatibility : Conducted emissions : EN 55 014 Radiated emissions : EN 55 022 Protection index IP40 EN 60 034 / CEI 529 Temperature limit when stalled Classe B EN 60 335-1 CEI 85 171
26231708 价格&库存
很抱歉,暂时无法提供与“26231708”相匹配的价格&库存,您可以联系我们找货
  • 4+298.27294
库存:5
