Reversible synchronous geared motors
➜ 0.5 Nm
3.5 Watts
Mechanical strength : 0.5 Nm
Constant speed, dependent on supply frequency
Wide range of speeds available
Direction of rotation controlled by dephasing
capacitor
■ Permanent magnet rotor
■ UL, CSA, VDE approved, comply with IEC standards
Specifications
Type
Base speed of motor (rpm)
Voltage / Frequency
Output speed (250 RPM)
Output speed (375 RPM)
Ratios (i)
25.00 rpm
37.50 rpm
10
20.00 rpm
30.00 rpm
25/2
13.33 rpm
20.00 rpm
75/4
12.50 rpm
18.75 rpm
10.00 rpm
15.00 rpm
25
5.00 rpm
7.50 rpm
50
4.00 rpm
6.00 rpm
125/2
2.50 rpm
3.75 rpm
100
2.00 rpm
3.00 rpm
125
1.00 rpm
1.50 rpm
250
0.33 rpm
0.50 rpm
750
General characteristics
Motor
Gearbox
Maximum permitted continuous rated gearbox output torque for 1 million revolutions of
gearbox output shaft (Nm)
Axial load static (daN)
Radial load static (daN)
Absorbed power (W)
Motor output (W)
Maximum temperature rise (oC)
Ambient temperature (oC)
Weight (g)
Wires length mm (approximately)
Protection rating
4
3.5 Watts
82 524 0
250
230-240 V - 50 Hz
3.5 Watts
82 524 4
375
230-240 V - 50 Hz
82 524 001
82 524 002
82 524 003
82 524 004
82 524 008
82 524 010
82 524 016
82 520 0
81 021 0
0.5
82 520 4
81 021 0
0.5
1
8
3.5
0.98
50
-5 ➞ +70
140
250
IP40
1
8
3.5
1.12
50
-5 ➞ +70
140
250
IP40
Product adaptations
Special supply voltages
Special cable lengths
Special connectors
Special output shafts
Special gearbox ratios
Special gear wheel material
Special output bearing
Curves
Torque/speed curves 82 524 0
Torque/speed curves 82 524 4
mN.m
400
80
mN.m
500
400
300
200
150
100
80
60
40
500
300
200
150
100
60
40
1
2
3 4 5
8
6
B RPM
To order, see page 13
122
15
10
25
20 30
75/2
1
2
3 4 5
8
6
B RPM
15
10
25
20 30
75/2
Accessories
Voltages/Frequencies
Capacitors for motor 82 520 0
230-240 V - 50 Hz
115 V 60 Hz
24 V - 50 Hz
Capacitors motor 82 520 4
230/240 V - 50 Hz
115 V 60 Hz
24 V - 50 Hz
24 V - 60 Hz
µF
V
Code
0.10 ± 10 %
0.33 ± 10 %
8.2 ± 10 %
700
400
70
26 231 941
26 231 801
26 231 711
0.12 ± 10 %
0.39 ± 5 %
15 ± 5 %
12 ± 5 %
600
630
70
63
26 231 903
26 231 924
26 231 728
26 231 145
Dimensions
82 524 0 - 82 524 4
4
3
1
2
B 2 fixing holes Ø 3.2
C Fixing clip
D 3.5 across flat
E pushed-in shaft
Options
Shaft 79 200 967
Shaft 79 200 779
1
1
B (pushed-in shaft ← )
4
Shaft 70 999 421 SP1295-10
1
B 5 across flat
Connections
In parallel
Motors 82 520 0 - 82 520 4
1
2
SA
SI
UN
B SA : Clockwise
C SI : Anti-clockwise
Other information
The speed of a motor powered by a 60 Hz supply is 20 % higher than that of a motor powered by a 50 Hz supply.
123
➜ 2 Nm
3.5 Watts
Machanical strength : 2 Nm
capacitor
Specifications
Type
Voltage / Frequency
Ratios (i)
10.00 rpm
15.00 rpm
25
5.00 rpm
7.50 rpm
50
4.00 rpm
6.00 rpm
125/2
2.50 rpm
3.75 rpm
100
1.00 rpm
1.50 rpm
250
0.50 rpm
0.75 rpm
500
0.33 rpm
0.50 rpm
750
5.00 rev/hr
7.50 rev/hr
3000
Motor
Gearbox
gearbox output shaft Nm
Absorbed power (W)
Motor output (W)
Weight (g)
Protection rating
4
3.5 Watts
3.5 watts
82 529 0
230-240 V - 50 Hz
250
82 529 4
230-240 V - 50 Hz
375
82 520 0
81 033 0
2.0
82 520 4
81 033 0
2.0
1
10
3.5
0.98
50
-5 ➞ +70
260
250
IP40
1
10
3.5
1.12
50
-5 ➞ +70
350
250
IP40
Product adaptations
Special connectors
Special output bearings
Curves
Torque/speed curves 82 529 0
Torque/speed curves 82 529 4
mN.m
800
mN.m
2000
1500
1000
800
600
400
300
200
1
100
1
5/6
B RPM
126
15/2
2
15
5/2
5
25/2
2000
1500
1000
600
400
300
200
1
100
1
5/6
B RPM
15/2
2
15
5/2
5
25/2
Accessories
230-240 V - 50 Hz
115 V - 60 Hz
24 V - 50 Hz
Capacitors for motor 82 520 4
230/240 V - 50 Hz
115 V - 60 Hz
24 V - 50 Hz
24 V - 60 Hz
µF
V
Code
0.10 ± 10 %
0.33 ± 10 %
8.2 ± 10 %
700
400
70
26 231 941
26 231 801
26 231 711
0.12 ± 10 %
0.39 ± 5 %
15 ± 5 %
12 ± 5 %
600
630
70
63
26 231 903
26 231 924
26 231 728
26 231 145
Dimensions
82 529 0 - 82 529 4
1
4
2
3
5
4
C Fixing clip
D 5 across flat
E (pushed-in shaft ← )
F 3 mounting bosses Ø 7.2 at 120°
4
on radius= 19.5 - 3 holes M3 depth 4
Options
Shaft 79 202 573
2
1
B (shaft pushed-in ← )
C 5 across flat
Connections
In parallel Motors 82 520 0 - 82 520 4
1
2
SA
SI
UN
B SA : clockwise
C SI : anti-clockwise
Other information
127
很抱歉,暂时无法提供与“26231924”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+157.981691+20.50314
