70514194
70514194
    CROUZET(高诺斯)
    54A ACT SW-83132/33/34 R=35.75
70514194 数据手册
| | www.crouzet-switches.com || 1 | | microswitches | | 06/2016 Subminiature microswitches - Double break 83132 / 83133 / 83134 › Double-break flexible leaf snap-action mechanism › Side, rear or on front face terminals › Momentary or maintained action (option) › Very long life › Ratings from 1 mA 4 Vc to 6 A 250 Va › Operating temperature -40 °C up to +150 °C › Wide choice of actuators on 2 symmetric fixing positions Main specifications Side outputs 83132 Standard Function Connections I (changeover) W2 I (changeover) X1 R (normally closed) W2 R (normally closed) X1 C (normally open) W2 C (normally open) X1 Electrical characteristics Rating nominal / 250 V AC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Max. Allowable overtravel force (N) Rest position max. (mm) Operating position (mm) Differential travel (mm) Min. overtravel (mm) Ambient operating temperature (°C) Mechanical life (operations) Contact gap (mm) Weight (g) Dual-current (DORE) 83132030 83132032 83132040 - 83132053 - 6 11 5* ● Rear outputs 83133 Front face outputs 83134 Standard Standard 83133035 83133045 83133042 83133073 83133052 83133210 ● ● ● - ● ● 83133050 - ● 6 11 1.6 0.4 10 8.45 7.7±0.2 0.35±0.1 0.27 -40 ➞ +125 107 0.3 x 2 1.8 Dual-current (DORE) 5* 1.6 0.4 10 8.45 7.7±0.2 0.35±0.1 0.27 -40 ➞ +125 107 0.3 x 2 1.8 Dual-current (DORE) 83134001 - 83134003 - 6 11 5* 1.6 0.4 10 8.10 7.35±0.25 0.35±0.1 0.27 -40 ➞ +125 107 0.3 x 2 1.8 Additional specifications - Case, Button: PA66 GF (UL 94-V0 / GWFI 960 °C / GWIT 775 °C) - Moving blade: beryllium copper - Contacts: silver, gold-plated silver (dual-current) - Terminals: copper nickel - Levers: stainless steel, polyamide roller - Degree of protection: IP40 (mechanism) - Proof tracking index: PTI 400 - Recommanded min actuating speed: 0.01 mm/s Note: fixing holes are fitted with metal inserts Product adaptations › Maintained action variants (bistable reset switch), with or without lever › 2 or 3-pole assembly with single actuator. Optional mounting on metal plate (8331) › Special levers: special shapes and lengths › Plunger with ball (Ø 5 mm) for lateral approach from any direction › High operating temperature: max +150 °C › Applications in irradiated environment › Higher operating force: max 2.6 N › Larger overtravel: min 0.5 mm (SP4225) › Added overtravel and/or adjustable fixing by threaded barrel (see 83528 and 8354 Series) › cURus and NF approved versions up to 480 Va Principles Double break snap-action switch Changeover - SPDT (form Za) Normally closed - SPST-NC (form Y) Both circuits must be used at same polarity Standard product Product made to order Contact us Normally open - SPST-NO (form X) | | www.crouzet-switches.com || 2 | | microswitches | | 06/2016 Curves Operating curve for types 83132 - 83133 - 83134 1 2 3 {~ L = 5 ms R cos ϕ = 0,8 4 107 5 2 106 5 30V 2 105 5 250V~ 2 104 0,1 0,2 0,5 1 2 6 5 B C D E F Number of cycles Resistive circuit Inductive circuit Mechanical life limit Current in Amps * Dual-current models are designed to operate equally well on low-current (1 mA 4 V minimum recommended) or medium-current (5 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life. Dimensions Product 83132 83133 B Total travel position = 7.35 max. C Ø1.5, depth 0.7 D 2 PTFE plates, thickness 0.8 83134 E Total travel position = 7 max. Connections W2 solder or quick-connect 2.8 x 0.5 (83132 - 83133) X1 for PCB, straight output (83133) X1 for PCB, straight output (83134) | | www.crouzet-switches.com || 3 | | microswitches | | 06/2016 Actuators 54A flat 54B folded 54E roller Ø5x2,6 54A2 2-pole 54D adjustable 54EL transverse roller Ø5x2,6 Standard mounting position For 831320 and 831330 For 831340 1 1 B Cover B Cover | | www.crouzet-switches.com || 4 | | microswitches | | 06/2016 Actuators and mounting accessories Part numbers for standard actuators Actuators Operating position Operating force max. Release force min. Pretravel max. Differential travel Total travel max. 70514175 70514194 70514181 70514182 70514183 Flat 54A R14.75 Flat 54A R35.75 Roller 54E R7.5 Roller 54E R14.1 Roller 54E R34.4 83132 83133 9.5 ±0.8 mm N N mm mm mm 83132 83133 10 ±1.5 83134 9.2 ±0.8 0.34 0.06 5.15 2.1 ±0.65 6.8 0.8 0.16 2.15 1 ±0.3 2.8 Part numbers for standard actuators 83132 83133 14.2 ±0.3 83134 9.7 ±0.15 70514559 2-pole 54A2 R30 83132 83133 16.1±1.4 83134 15.2 ±0.8 0.8 0.17 2.05 0.95 ±0.3 2.7 1.6 0.32 1.1 0.5 ±0.15 1.45 70514125 Folded 54B R13.17 83132 83133 15.5 ±0.8 83134 13.9 ±0.3 70514188 70514178 70514179 Adjustable 54D R27.1 Transverse Roller 54EL R7.5 Transverse Roller 54EL R14.1 Side fixing plate 54Y stainless steel (16 x 8 x 0,4 mm) 83132 83132 83133 83134 83133 83134 12.6-17.6±1.2 12.3-17.3±1.2 14.2 ±0.3 13.9 ±0.3 0.43 1.6 0.08 0.32 3.9 1.1 1.8 ±0.5 0.5 ±0.15 5.2 1.45 83132 83133 83134 15.6 ±0.8 15.3 ±0.8 0.75 0.15 2.25 1 ±0.35 3 Always supplied separately Actuators Operating position Operating force max. Release force min. Pretravel max. Differential travel Total travel max. mm N N mm mm mm 83132 83133 83134 12.7 ±0.8 12.4 ±0.8 0.85 0.18 2.05 0.95 ±0.3 2.7 83132 83133 8.8 ±0.8 0.8 0.16 4.3 2 ±0.55 5.75 83134 15.8 ±1.4 0.34 0.07 4.9 2±0.6 6.6 70514280 Unless mentioned specifically, the levers are mounted in the position illustrated on the dimension diagrams (standard mounting). We recommend that these levers are assembled in our workshops. 83132/133/134 microswitches with referenced actuators 54A R14.75 R35.75 Mounting 70514175 70514194 IW2 Standard 83132039 83132045 IW2 Standard 83133015 83133038 IX1 Standard 83133174 83133062 IX1 Standard 83134004 83134016 On right 83134005 83134012 DUAL-CURRENT STANDARD Lever (standard mounting = on left) 83132 83133 83134 83132 83133 83134 IW2 Standard 83132090 ● 54A2 R30 70514125 ● 83133301 83133306 - 54B R13.17 70514559 83132087 83133171 83133212 83134002 83134007 54D R27.1 70514188 83132076 83133118 83133120 ● ● R7.5 70514181 83132033 83133004 ● 83134015 ● 54E R14.1 70514182 83132003 83133002 83133119 83134011 83134006 R34.4 70514183 83132005 83133003 ● 83134009 ● ● ● ● ● ● ● 54EL R7.5 R14.1 70514178 70514179 ● 83132054 83133058 83133059 ● ● ● ● ● ● ● ● IW2 Standard ● ● ● ● ● ● 83133122 ● ● ● IX1 Standard ● 83133173 ● ● ● ● ● ● ● ● IX1 Standard 83134046 ● - 83134028 ● ● 83134014 ● ● ● On right ● ● - ● ● ● ● ● ● ● Installation recommendations See “Basic technical concepts” For 83133 and 83134: to ensure protection against electric shock after installation in the application, please consult us when conductive parts are located in the immediate proximity of the side walls of the switch housing. How to order Use the 8 digit part numbers when they are defined Other cases, precise: Type of microswitch - Function - Connection -Contact* - UL approval* - Actuator* - Fixing position* - Adaptation* * if needed Example: 83133 I W2 DORE UL 54E R7.5 Standard product Product made to order Contact us | | www.crouzet-switches.com || 5 | | microswitches | | 06/2016 Examples of special adaptations Maintained action variant (bistable reset switch) for level regulation. Has lever with hole for push-pull actuation by a rod with 2 stops Flexible pre-armed lever: provides both precise operating position and extra-long overtravel (5 mm) Plunger with ball (Ø 5 mm) for lateral approach from any direction 3 pole assembly (3PDT) on metal plate: 833162 «US format»: housing with 1/2’’ (12.7 mm) mounting hole pitch (831337)
70514194 价格&库存
很抱歉,暂时无法提供与“70514194”相匹配的价格&库存,您可以联系我们找货
    • 30+19.0744930+2.47242
