80835005
80835005
    CROUZET(高诺斯)
    MOTOR 82830 GEARBOX RC5 - BASE 2
80835005 数据手册
02/11/2015 www.crouzet.com 5 Nm RC5 33 Watts 33 W Part number made to order Torque rating : 5 Nm, for long service life Motors : nominal power 27 W All-metal high-quality gearboxes, "integrated" geared motors Base speed range : 7.4 to 426 rpm UL approved Part numbers 80835005 Type Type Voltage Standard speed (rpm) Output speed (rpm) Ratios (i) 33 W 808350 - - 7,4 245 Specifications General characteristics Motor Gearbox Maximum permitted torque from gearmotor under continuous conditions (Nm) Axial load dynamic (daN) Radial load dynamic (daN) Max. output power (W) Nominal output (W) Gearbox case temperature rise (°C) Weight (g) Approvals 828300 810350 5 6 6 33 27 50 1540 UL 1004 Made to order products, available on request Motors : Other supply voltages Shaft lengths at front and/or rear Built-in interference suppression on 82 830 Encoders Other fixing flanges on front and rear "High-power" motors Gearboxes : Special shaft Special greasing Other reduction ratios Dimensions (mm) 808350 No Legend 4 fixing holes Ø 4.2 Lead length 200 mm ± 10 7 across flats Shaft pushed-in Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Dimensions (mm) Gearbox shaft 79290064 No Legend Shaft pushed-in Curves Curve : torque/nominal speed No Legend rpm Other information Options Ball bearings on gearbox output shaft : part number becomes 808355 EMC filter 48 V, 90 V, 110 V motor 1- or 2-channel encoder, 1, 5 or 12 pulses/revolution Product adaptations Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Special supply voltage Special cable length Optical or Hall effect encoder Special connectors Special shaft Special reduction ratio Special materials for gears Special ball bearings Special adaptor plate UL/CSA logo on label With 828305 - 67 W motors Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
80835005 价格&库存
很抱歉,暂时无法提供与“80835005”相匹配的价格&库存,您可以联系我们找货
