82344705
82344705
    CROUZET(高诺斯)
    MOTOR 82340 GEARBOX OVOIDE 12 RP
82344705 数据手册
Single direction synchronous geared motors ■ ■ ■ ■ Constant speed, dependent on supply frequency Wide range of speeds Direction of rotation controlled by long-life mechanical anti-return (>107 starts) Permanent magnet rotor Types Applications - Programming devices (time base) - Office equipment - Medical equipment - Motorised displays - Scanners - Moving light displays - Pumps Motors : - other voltages/frequencies - lead length - output lead at 120° from standard angle (clockwise or anti-clockwise) - fixed by screws not clips 82 344 0 82 344 0 82 344 0 230 V 50 Hz 230 V 50 Hz 240 V 50 Hz 240 V 50 Hz Anti-clockwise Clockwise Anti-clockwise Clockwise 82 344 736 82 344 698 82 344 690 Direction of rotation Output speeds (rpm) 60 50 48 30 24 20 16.67 15 12.5 12 10 9.6 8.33 7.5 6 5 4.8 4 3 2.50 2.40 2 1.67 1.60 1.20 1 0.83 0.80 0.56 0.5 0.42 0.33 0.28 0.25 0.21 0.20 0.17 0.10 Made to order products, non stocked 2 82 344 0 Voltage and frequency Ratios (i) 10 12 12.5 20 25 30 36 40 48 50 60 62.5 72 80 100 120 125 150 200 240 250 300 360 375 500 600 720 750 1080 1200 1440 1800 2160 2400 2880 3000 3600 6000 Part numbers ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 7200 9000 12000 14400 36000 43200 54000 72000 108000 144000 180000 216000 432000 864000 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 82 344 744 ● ● 82 344 738 82 344 739 82 344 740 ● 82 344 741 ● 82 344 743 82 344 752 ● ● 82 344 754 82 344 755 82 344 756 ● 82 344 765 82 344 766 ● ● 82 344 775 ● ● ● 82 344 771 ● ● ● 82 344 772 ● 82 344 773 ● ● 82 344 746 82 344 747 82 344 748 ● 82 344 749 ● 82 344 751 82 344 760 ● ● 82 344 762 82 344 763 82 344 764 ● 82 344 757 82 344 758 ● ● 82 344 768 ● ● ● 82 344 778 ● ● ● 82 344 779 ● 82 344 780 ● 82 344 699 82 344 692 82 344 693 82 344 694 ● 82 344 695 ● 82 344 697 82 344 706 ● ● 82 344 708 82 344 709 82 344 710 ● 82 344 719 82 344 720 ● ● 82 344 729 ● ● ● 82 344 725 ● ● ● 82 344 726 ● 82 344 727 ● 82 344 691 82 344 700 82 344 701 82 344 702 ● 82 344 703 ● 82 344 705 82 344 714 ● ● 82 344 716 82 344 717 82 344 718 ● 82 344 711 82 344 712 ● ● 82 344 722 ● ● ● 82 344 732 ● ● ● 82 344 733 ● 82 344 734 Output speeds (rev/hr) 5.00 4.00 3.00 2.50 1.00 0.83 0.67 0.50 1/3 1/4 1/5 1/6 1/12 1/24 Gearboxes : - other output speeds - ball bearings - special shaft - special lubrication - fixing by M3 holes Standard gearbox shaft: see dimensions Options : for made to order products non stocked Voltages / Frequencies 24 V 50 Hz 24 / 115 V 60 Hz 48 V 50 Hz For version with no anti-return (SAR version see page 2/6) Free-wheel device : Y system (see page 2/34) Torque limiter F symbol (see page 2/34) Gearbox shaft round 79 200 967 pierced 79 200 779 Ø 6 with flat 79 999 421 Other information For basic principles, see page 2/6 The speed of a motor powered by a 60 Hz supply is 20% higher than that of a motor powered by a 50 Hz supply. 2/14 Downloaded from Elcodis.com electronic components distributor General characteristics Type Motor Gearbox Maximum permitted continuous rated gearbox output torque for 1 million gearbox revolutions Clockwise 82 334 734 82 334 726 82 334 811 82 334 803 ● ● 82 334 758 82 334 759 82 334 760 ● 82 334 769 ● ● ● 82 334 748 ● ● ● 82 334 744 ● 82 334 741 82 334 764 ● ● 82 334 766 82 334 767 82 334 768 ● 82 334 761 ● ● ● 82 334 742 ● ● ● 82 334 751 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 82 334 808 ● 82 334 810 82 334 772 ● ● 82 334 774 82 334 775 82 334 776 ● 82 334 785 ● ● ● 82 334 796 ● ● ● 82 334 792 ● ● ● ● ● 82 334 794 400 300 200 150 100 80 60 40 30 20 ● 82 334 816 ● 82 334 818 82 334 780 ● ● rpm rpm 2 ● ● ● ● ● ● 82 334 799 ● ● ● ● ● 82 334 801 ● ● ● ● ● ● ● ● ● ● ● ● ● ● 30 (pushed-in shaft ←) 82 334 789 ● ● ● ● ● ● ● ● ● ● ● ● ● ● 10 15 60 Dimensions 82 344 0 - 82 334 5 ● 82 334 777 ● ● ● ● ● ● 6 3 4 5 82 334 782 82 334 783 82 334 784 ● ● ● ● ● ● 82 334 5 500 23,8 13,2 max. 23,8 3,2 2 fixing holes Ø 3.2 8 Fixing claw Ø 50,5 17,2 max. 55,5 max. 4 Type 82 344 0 82 334 5 L1 2 L1 (mm) 35.6 max. 41.65 max. Products available to order : gearbox output shaft Shaft 79 200 967 (pushed-in shaft ←) Shaft 79 200 779 (pushed-in shaft ←) Shaft 70 999 421 SP1295-10 13,2 max. Ø 1,5 13,3 max. Ø4 82 334 733 82 334 756 ● 82 334 739 ● 82 334 804 82 334 813 82 334 814 82 334 815 15,6 max. Ø8 ● ● 82 334 812 82 334 805 82 334 806 82 334 807 14 ● 82 334 731 ● 82 334 727 82 334 736 82 334 737 82 334 738 65,9 max. ● 82 334 735 82 334 728 82 334 729 82 334 730 82 344 0 mN.m Ø 12 Anti-clockwise 5 across flat Clockwise 1 8 3.5 0.42 55 -5 +60 210 250 IP40 Ø6 Anti-clockwise 1 8 3 0.16 55 -5 +60 160 250 IP40 Ø8 240 V 50 Hz daN daN W W °C °C g mm 3.5 across flat 240 V 50 Hz 0.5 0 Ø 4-0,018 230 V 50 Hz 0.5 Ø4 230 V 50 Hz 1 2 3 4 Nm Ø8 82 334 5 82 334 5 82 330 5 81 021 0 Ø 47,2 82 334 5 12,75 82 334 5 13,5 82 334 5 Axial load (static) Radial load (static) Absorbed power Usable motor power Maximum temperature rise Ambient temperature Weight Lead length (approx..) Protection Graph of torque versus speed 82 344 0 82 340 0 81 021 0 9 6,8 5 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● To order, specify : Standard products 4 Part number Example : Synchronous geared motor - 82 344 744 ● Standard products, non stocked 1 3 5 Type Direction of rotation 2 4 Voltage and frequency Output speed Option Example : Synchronous geared motor 82 344 0 - 230 V 50 Hz - CW - 0.80 rpm - Round shaft ● 2/15 Downloaded from Elcodis.com electronic components distributor Products available to order, please consult us
82344705
- 物料型号:文档列出了多种型号,例如823440、823345等。 - 器件简介:这些是单向同步齿轮电机,具有恒定的速度,依赖于供电频率,具有长寿命的机械防反转装置,以及永磁转子。 - 引脚分配:文档中没有提供引脚分配信息,但提到了电机和齿轮箱的一些技术规格。 - 参数特性:电机的参数特性包括不同的电压和频率选项,输出速度,以及一些机械特性如最大连续额定齿轮箱输出扭矩、轴向和径向负载、吸收功率等。 - 功能详解:文档描述了电机的应用领域,如编程设备、办公设备、医疗设备、电机驱动显示器等,并提供了不同电压和频率下的转速比和部件编号。 - 应用信息:电机适用于多种应用,包括编程设备、办公设备、医疗设备、扫描仪、移动灯光显示和泵等。 - 封装信息:文档提供了电机和齿轮箱的尺寸信息,包括最大长度、最大直径和固定孔的尺寸。
82344705 价格&库存
很抱歉,暂时无法提供与“82344705”相匹配的价格&库存,您可以联系我们找货
