| SWITCHES.CROUZET.COM
|1
| MICROSWITCHES
| 05/2016
Protected
➜ 83 106
■ Double break switching
■ Options for operation in stable positions
■ Choice of actuators and mounting accessories
Main specifications
Standard
83 106 0
Function
Connections
I (changeover)
W3
I (changeover)
W1 - W2
R (normally closed)
W1 - W2 - W3
C (normally open)
W1 - W2 - W3
Electrical characteristics
Rating nominal / 250 V AC (A)
Rating thermal / 250 V AC (A)
Mechanical characteristics
Maximum operating force (N)
Min. Release force (N)
Tripping point (mm)
Min. overtravel (mm)
Mechanical life (operations)
Max. permitted overtravel force (N)
Rest position max. (mm)
Differential travel (mm)
Ambient operating temperature (°C)
Contact gap (mm)
Weight (g)
2 stable lever positions
83 106 4
2 stable plunger
positions
83 106 7
83 106 701
83 106 411
83 106 022
5
17.5
5
17.5
5
17.5
4
1
11.45+ 0.2 -0.25
0.7
107
0.5±0.2
-40 ➞ +85
0.4 x 2
8
0.45
106
-40 ➞ +85
0.4 x 2
9
2
106
-40 ➞ +85
0.4 x 2
8
Additional specifications
Components
Material
- Case : polyamide UL94V2 (83 106)
- Contacts : nickel silver
Levers
- Mild steel (zinc)
- Roller : polyamide
- Adjusting screws : self-retaining
- Plates : iridescent passivated mild steel (zinc)
NB : Fixing holes for these microswitches have metal ferrules.
Product adaptations
Special levers
Reinforced spring
Special contacts
High operating temperature: 125 °C
Approvals : UL - cUL
|2
| MICROSWITCHES
| 05/2016
Principles
Double break changeover snap-action switch
Curves
Operating curve for types 83 106 0 / 4 / 7
1
2
3
L = 5 ms
R
cos ϕ = 0,8
108
5
2
107
5
4
2
106
5
250V~
380V~
30V
2
105
0,1 0,2 0,5 1 2
5 10 16
5
B
C
D
E
F
Number of cycles
Resistive circuit
Inductive circuit
Mechanical life limit
Current in Amps
Dimensions
➜ Product
83 106
83 106 4
83 106 7
W2 solder
W3 for 6.35 mm clips
1
2
B OL = 10.65
Depth 1.2
CØ2
+0.01 +0.65
➜ Connections
W1 screw
|3
| MICROSWITCHES
| 05/2016
➜ Actuators
A
B
Lever cross-section 1 x 6.4 mm
Q
E
B9
V3
F
➜ Mounting accessories
O2
2-pole side mounting plate
K2
2-pole vertical mounting plate
H
Horizontal single-pole mounting plate
Unless indicated, the thickness of plates is 1.5 mm
Y
Side plate
|4
| MICROSWITCHES
| 05/2016
Actuators and mounting accessories
70500888
Actuators
A R49
Operating force - max.
Release force - min.
Pre-travel - max.
Differential travel
Total travel max.
N
N
mm
mm
mm
1.2
0.25
6.2
2.1 ±0.9
7.5
70500828
70500813
ER47
BR49
1.2
0.25
6.2
2.1 ±0.9
8.4
1.2
0.2
6.2
2.1 ±0.9
7.5
70500840
Q
2.8
0.45
3.2
1.05 ±0.4
4.5
70500870
70500170
V3 R15.5
4
0.8
1.45
0.5 ±0.2
1.9
B9
4
1
1.5
0.5 ±0.2
1.9
Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left).
70500206
Y Side plate
Screws: Length
14.5
16
27.5
70500208
H Horizontal single-pole
mounting plate
70500218
70500216
O2 2-pole side
mounting plate
K2 2-pole vertical
mounting plate
70599106
70599102
70599110
Other information
Mounting - Operation
See basic technical concepts
To ensure protection against electric shock after installation in the application, please consult us when conductive parts are located less than 3mm
from case/cover rear mating surfaces, opposite to button side.
|1
| MICROSWITCHES
| 05/2016
Protected
➜ 83 109
Front connections
Main specifications
Outputs on front face
83 109 0
Function
Connections
I (changeover)
W2
R (normally closed)
W2
C (normally open)
W2
Tripping point (mm)
differential travel (mm)
Contact gap (mm)
Weight (g)
83 109 004
5
17.5
4
1
11.45 + 0.2 - 0.25
0.7
107
0.5±0.2
- 40 ➞ +85
0.4 x 2
8
Components
Material
Levers
- Mild steel (zinc)
Product adaptations
Special levers
Reinforced spring
Special contacts
|2
| MICROSWITCHES
| 05/2016
Principles
Curves
Operating curve for type 83 109 0
1
2
3
L = 5 ms
R
cos ϕ = 0,8
108
5
2
107
5
4
2
106
5
250V~
380V~
30V
2
105
0,1 0,2 0,5 1 2
5 10 16
5
B
C
D
E
F
Number of cycles
Resistive circuit
Inductive circuit
Current in Amps
Dimensions
➜ Product
➜ Connections
83 109 0
W2 solder
1
2
B OL = 10.65
Depth 1.2
CØ2
+0.01 +0.65
➜ Actuators
A
B
E
|3
Q
| MICROSWITCHES
| 05/2016
B9
V3
F
O2
K2
H
1.5 mm
70500888
Actuators
A R49
Pre-travel - max.
Differential travel
Total travel max.
N
N
mm
mm
mm
1.2
0.25
6.2
2.1 ±0.9
7.5
70500828
70500813
BR49
ER47
1.2
0.25
6.2
2.1 ±0.9
8.4
1.2
0.2
6.2
2.1 ±0.9
7.5
70500840
Q
2.8
0.45
3.2
1.05 ±0.4
4.5
70500870
70500170
V3 R15,5
4
0.8
1.45
0.5 ±0.2
1.9
B9
4
1
1.5
0.5 ±0.2
1.9
Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left). .
70500208
mounting plate
Screws: Length
14.5
70500218
O2 2-pole side
mounting plate
70500216
K2 2-pole vertical
mounting plate
70599106
Other information
|1
| MICROSWITCHES
| 05/2016
Protected
➜ 83 111
■ Rear-fixing via nuts or clips
Main specifications
Rear-fixing by nuts
83 111 0
Function
Connections
W3
I (changeover)
W1 - W2
I (changeover)
R (normally closed)
W1 - W2 - W3
C (normally open)
W1 - W2 - W3
Tripping point (mm)
Maximum differential travel (mm)
Contact gap (mm)
Weight (g)
Rear-fixing by clips
83 111 5
83 111 525
83 111 001
5
17.5
5
17.5
4
1
11.45 + 0.2 - 0.25
0.7
107
0.5±0.2
- 40 ➞ +85
0.4 x 2
8
4
1
11.45 + 0.2 - 0.25
0.7
107
0.5±0.2
- 40 ➞ +85
0.4 x 2
8
Components
Material
Levers
- Mild steel (zinc)
Product adaptations
Special levers
Reinforced spring
Special contacts
|2
| 05/2016
| MICROSWITCHES
Principles
Curves
Operating curve for types 83 111 0 - 83 111 5
1
2
3
L = 5 ms
R
cos ϕ = 0,8
108
5
2
107
5
4
2
106
5
250V~
380V~
30V
2
105
0,1 0,2 0,5 1 2
5 10 16
5
B
C
D
E
F
Number of cycles
Resistive circuit
Inductive circuit
Current in Amps
Dimensions
➜ Product
83 111 0
83 111 5
➜ Connections
W1 screw
W2 solder
|3
| MICROSWITCHES
| 05/2016
➜ Actuators
A
B
E
Q
B9
V3
F
70500888
Actuators
A R49
Pre-travel - max
Differential travel
Total travel max.
N
N
mm
mm
mm
1.2
0.25
6.2
2.1 ±0.9
7.5
70500828
BR49
1.2
0.25
6.2
2.1 ±0.9
8.4
70500813
ER47
1.2
0.2
6.2
2.1 ±0.9
7.5
70500840
Q
2.8
0.45
3.2
1.05 ±0.4
4.5
70500870
V3 R15.5
4
0.8
1.45
0.5 ±0.2
1.9
Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left)..
Other information
70500170
B9
4
1
1.5
0.5 ±0.2
1.9
|1
| MICROSWITCHES
| 05/2016
Protected
➜ 83 112
Built-in screw connections
Choice of actuators and mouniting accessories
Main specifications
Built-in screw
connections
83 112 0
Function
Connections
I (changeover)
W1
Tripping point (mm)
Contact gap (mm)
Weight (g)
83 112 001
5
17.5
4
1
11.45 + 0.2 - 0.25
0.7
107
0.5±0.2
-40 ➞ +85
0.4 x 2
14.5
Components
Material
Levers
- Mild steel (zinc)
Product adaptations
Special levers
Reinforced spring
Special contacts
|2
| MICROSWITCHES
| 05/2016
Principles
Curves
Operating curve for type 83 112 0
1
2
3
L = 5 ms
R
cos ϕ = 0,8
108
5
2
107
5
4
2
106
5
250V~
380V~
30V
2
105
0,1 0,2 0,5 1 2
5 10 16
5
B
C
D
E
F
Number of cycles
Resistive circuit
Inductive circuit
Current in Amps
Dimensions
➜ Product
83 112 0
1
21
B Connection
C OL = 10.65
➜ Actuators
A
B
Q
E
B9
V3
F
|3
| MICROSWITCHES
| 05/2016
O2
K2
H
1.5 mm
70500888
Actuators
A R49
Pre-travel - max.
Differential travel
Total travel max.
N
N
mm
mm
mm
1.2
0.25
6.2
2.1 ±0.9
7.5
70500828
70500813
70500840
BR47
ER47
Q
1.2
0.25
6.2
2.1 ±0.9
8.4
1.2
0.2
6.2
2.1 ±0.9
7.5
2.8
0.45
3.2
1.05 ±0.4
4.5
70500170
70500870
V3 R15,5
4
0.8
1.45
0.5 ±0.2
1.9
B9
4
1
1.5
0.5 ±0.2
1.9
70500208
mounting plate
Screws: Length
14.5
70500218
O2 2-pole side
mounting plate
70500216
K2 2-pole vertical
mounting plate
70599106
Other information
Warning:
The product information contained in this catalogue is given purely as information and does not constitute a representation, warrantly or any form of contractual commitment. Crouzet Automatismes SAS and its subsidiaries reserve the
right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsability of the buyer to establish, particularly through all the appropriate
tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other
electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
很抱歉,暂时无法提供与“83106022”相匹配的价格&库存,您可以联系我们找货
