831060C3.B9
831060C3.B9
    CROUZET(高诺斯)
    SNSW 10A 1/4 BALL ACTUATOR
831060C3.B9 数据手册
| SWITCHES.CROUZET.COM |1 | MICROSWITCHES | 05/2016 Protected ➜ 83 106 ■ Double break switching ■ Options for operation in stable positions ■ Choice of actuators and mounting accessories Main specifications Standard 83 106 0 Function Connections I (changeover) W3 I (changeover) W1 - W2 R (normally closed) W1 - W2 - W3 C (normally open) W1 - W2 - W3 Electrical characteristics Rating nominal / 250 V AC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Tripping point (mm) Min. overtravel (mm) Mechanical life (operations) Max. permitted overtravel force (N) Rest position max. (mm) Differential travel (mm) Ambient operating temperature (°C) Contact gap (mm) Weight (g) 2 stable lever positions 83 106 4 2 stable plunger positions 83 106 7 83 106 701 83 106 411 83 106 022 ● ● ● ● ● ● ● ● ● 5 17.5 5 17.5 5 17.5 4 1 11.45+ 0.2 -0.25 0.7 107 20 12.75 0.5±0.2 -40 ➞ +85 0.4 x 2 8 0.45 106 -40 ➞ +85 0.4 x 2 9 2 106 -40 ➞ +85 0.4 x 2 8 # Additional specifications Components Material - Case : polyamide UL94V2 (83 106) - Contacts : nickel silver Levers - Mild steel (zinc) - Roller : polyamide - Adjusting screws : self-retaining - Plates : iridescent passivated mild steel (zinc) NB : Fixing holes for these microswitches have metal ferrules. Product adaptations ■ ■ ■ ■ ■ Special levers Reinforced spring Special contacts High operating temperature: 125 °C Approvals : UL - cUL | SWITCHES.CROUZET.COM |2 | MICROSWITCHES | 05/2016 Principles Double break changeover snap-action switch Curves Operating curve for types 83 106 0 / 4 / 7 1 2 3 {~ L = 5 ms R cos ϕ = 0,8 108 5 2 107 5 4 2 106 5 250V~ 380V~ 30V 2 105 0,1 0,2 0,5 1 2 5 10 16 5 B C D E F Number of cycles Resistive circuit Inductive circuit Mechanical life limit Current in Amps Dimensions ➜ Product 83 106 83 106 4 83 106 7 W2 solder W3 for 6.35 mm clips 1 2 B OL = 10.65 Depth 1.2 CØ2 +0.01 +0.65 ➜ Connections W1 screw | SWITCHES.CROUZET.COM |3 | MICROSWITCHES | 05/2016 ➜ Actuators A B Lever cross-section 1 x 6.4 mm Q E Lever cross-section 1 x 6.4 mm B9 Lever cross-section 1 x 6.4 mm V3 F Lever cross-section 1 x 6.4 mm Lever cross-section 1 x 6.4 mm ➜ Mounting accessories O2 2-pole side mounting plate K2 2-pole vertical mounting plate H Horizontal single-pole mounting plate Unless indicated, the thickness of plates is 1.5 mm Y Side plate | SWITCHES.CROUZET.COM |4 | MICROSWITCHES | 05/2016 Actuators and mounting accessories 70500888 Actuators A R49 Operating force - max. Release force - min. Pre-travel - max. Differential travel Total travel max. N N mm mm mm 1.2 0.25 6.2 2.1 ±0.9 7.5 70500828 70500813 ER47 BR49 1.2 0.25 6.2 2.1 ±0.9 8.4 1.2 0.2 6.2 2.1 ±0.9 7.5 70500840 Q 2.8 0.45 3.2 1.05 ±0.4 4.5 70500870 70500170 V3 R15.5 4 0.8 1.45 0.5 ±0.2 1.9 B9 4 1 1.5 0.5 ±0.2 1.9 Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left). 70500206 Mounting accessories Y Side plate Screws: Length 14.5 16 27.5 70500208 H Horizontal single-pole mounting plate 70500218 70500216 O2 2-pole side mounting plate K2 2-pole vertical mounting plate 70599106 70599102 70599110 Other information Mounting - Operation See basic technical concepts To ensure protection against electric shock after installation in the application, please consult us when conductive parts are located less than 3mm from case/cover rear mating surfaces, opposite to button side. | SWITCHES.CROUZET.COM |1 | MICROSWITCHES | 05/2016 Protected ➜ 83 109 ■ ■ ■ ■ Double break switching Front connections Options for operation in stable positions Choice of actuators and mounting accessories Main specifications Outputs on front face 83 109 0 Function Connections I (changeover) W2 R (normally closed) W2 C (normally open) W2 Electrical characteristics Rating nominal / 250 V AC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Tripping point (mm) Min. overtravel (mm) Mechanical life (operations) Max. permitted overtravel force (N) Rest position max. (mm) differential travel (mm) Ambient operating temperature (°C) Contact gap (mm) Weight (g) 83 109 004 ● ● 5 17.5 4 1 11.45 + 0.2 - 0.25 0.7 107 20 12.75 0.5±0.2 - 40 ➞ +85 0.4 x 2 8 # Additional specifications Components Material - Case : polyamide UL94V2 - Contacts : nickel silver Levers - Mild steel (zinc) - Roller : polyamide - Adjusting screws : self-retaining - Plates : iridescent passivated mild steel (zinc) NB : Fixing holes for these microswitches have metal ferrules. Product adaptations ■ ■ ■ ■ Special levers Reinforced spring Special contacts Approvals : UL - cUL |2 | SWITCHES.CROUZET.COM | MICROSWITCHES | 05/2016 Principles Double break changeover snap-action switch Curves Operating curve for type 83 109 0 1 2 3 {~ L = 5 ms R cos ϕ = 0,8 108 5 2 107 5 4 2 106 5 250V~ 380V~ 30V 2 105 0,1 0,2 0,5 1 2 5 10 16 5 B C D E F Number of cycles Resistive circuit Inductive circuit Mechanical life limit Current in Amps Dimensions ➜ Product ➜ Connections 83 109 0 W2 solder 1 2 B OL = 10.65 Depth 1.2 CØ2 +0.01 +0.65 ➜ Actuators A B Lever cross-section 1 x 6.4 mm E Lever cross-section 1 x 6.4 mm Lever cross-section 1 x 6.4 mm | SWITCHES.CROUZET.COM |3 Q | MICROSWITCHES | 05/2016 B9 V3 F Lever cross-section 1 x 6.4 mm Lever cross-section 1 x 6.4 mm ➜ Mounting accessories O2 2-pole side mounting plate K2 2-pole vertical mounting plate H Horizontal single-pole mounting plate Unless indicated, the thickness of plates is 1.5 mm Actuators and mounting accessories 70500888 Actuators A R49 Operating force - max. Release force - min. Pre-travel - max. Differential travel Total travel max. N N mm mm mm 1.2 0.25 6.2 2.1 ±0.9 7.5 70500828 70500813 BR49 ER47 1.2 0.25 6.2 2.1 ±0.9 8.4 1.2 0.2 6.2 2.1 ±0.9 7.5 70500840 Q 2.8 0.45 3.2 1.05 ±0.4 4.5 70500870 70500170 V3 R15,5 4 0.8 1.45 0.5 ±0.2 1.9 B9 4 1 1.5 0.5 ±0.2 1.9 Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left). . 70500208 Mounting accessories H Horizontal single-pole mounting plate Screws: Length 14.5 70500218 O2 2-pole side mounting plate 70500216 K2 2-pole vertical mounting plate 70599106 Other information Mounting - Operation See basic technical concepts To ensure protection against electric shock after installation in the application, please consult us when conductive parts are located less than 3mm from case/cover rear mating surfaces, opposite to button side. | SWITCHES.CROUZET.COM |1 | MICROSWITCHES | 05/2016 Protected ➜ 83 111 ■ Double break switching ■ Rear-fixing via nuts or clips ■ Choice of actuators Main specifications Rear-fixing by nuts 83 111 0 Function Connections W3 I (changeover) W1 - W2 I (changeover) R (normally closed) W1 - W2 - W3 C (normally open) W1 - W2 - W3 Electrical characteristics Rating nominal / 250 V AC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Tripping point (mm) Min. overtravel (mm) Mechanical life (operations) Max. permitted overtravel force (N) Rest position max. (mm) Maximum differential travel (mm) Ambient operating temperature (°C) Contact gap (mm) Weight (g) Rear-fixing by clips 83 111 5 83 111 525 83 111 001 ● ● ● ● ● ● 5 17.5 5 17.5 4 1 11.45 + 0.2 - 0.25 0.7 107 20 0.5±0.2 - 40 ➞ +85 0.4 x 2 8 4 1 11.45 + 0.2 - 0.25 0.7 107 20 0.5±0.2 - 40 ➞ +85 0.4 x 2 8 # Additional specifications Components Material - Case : polyamide UL94V2 - Contacts : nickel silver Levers - Mild steel (zinc) - Roller : polyamide - Adjusting screws : self-retaining - Plates : iridescent passivated mild steel (zinc) NB : Fixing holes for these microswitches have metal ferrules. Product adaptations ■ ■ ■ ■ Special levers Reinforced spring Special contacts Approvals : UL - cUL | SWITCHES.CROUZET.COM |2 | 05/2016 | MICROSWITCHES Principles Double break changeover snap-action switch Curves Operating curve for types 83 111 0 - 83 111 5 1 2 3 {~ L = 5 ms R cos ϕ = 0,8 108 5 2 107 5 4 2 106 5 250V~ 380V~ 30V 2 105 0,1 0,2 0,5 1 2 5 10 16 5 B C D E F Number of cycles Resistive circuit Inductive circuit Mechanical life limit Current in Amps Dimensions ➜ Product 83 111 0 83 111 5 ➜ Connections W1 screw W2 solder W3 for 6.35 mm clips | SWITCHES.CROUZET.COM |3 | MICROSWITCHES | 05/2016 ➜ Actuators A B Lever cross-section 1 x 6.4 mm E Lever cross-section 1 x 6.4 mm Q Lever cross-section 1 x 6.4 mm B9 V3 F Lever cross-section 1 x 6.4 mm Lever cross-section 1 x 6.4 mm Actuators and mounting accessories 70500888 Actuators A R49 Operating force - max. Release force - min. Pre-travel - max Differential travel Total travel max. N N mm mm mm 1.2 0.25 6.2 2.1 ±0.9 7.5 70500828 BR49 1.2 0.25 6.2 2.1 ±0.9 8.4 70500813 ER47 1.2 0.2 6.2 2.1 ±0.9 7.5 70500840 Q 2.8 0.45 3.2 1.05 ±0.4 4.5 70500870 V3 R15.5 4 0.8 1.45 0.5 ±0.2 1.9 Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left).. Other information Mounting - Operation See basic technical concepts 70500170 B9 4 1 1.5 0.5 ±0.2 1.9 |1 | SWITCHES.CROUZET.COM | MICROSWITCHES | 05/2016 Protected ➜ 83 112 ■ ■ ■ ■ Double break switching Built-in screw connections Options for operation in stable positions Choice of actuators and mouniting accessories Main specifications Built-in screw connections 83 112 0 Function Connections I (changeover) W1 Electrical characteristics Rating nominal / 250 V AC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Tripping point (mm) Min. overtravel (mm) Mechanical life (operations) Max. permitted overtravel force (N) Rest position max. (mm) differential travel (mm) Ambient operating temperature (°C) Contact gap (mm) Weight (g) 83 112 001 5 17.5 4 1 11.45 + 0.2 - 0.25 0.7 107 20 12.75 0.5±0.2 -40 ➞ +85 0.4 x 2 14.5 # Additional specifications Components Material - Case : polyamide UL94V2 - Contacts : nickel silver Levers - Mild steel (zinc) - Roller : polyamide - Adjusting screws : self-retaining - Plates : iridescent passivated mild steel (zinc) NB : Fixing holes for these microswitches have metal ferrules. Product adaptations ■ ■ ■ ■ Special levers Reinforced spring Special contacts Approvals : UL - cUL | SWITCHES.CROUZET.COM |2 | MICROSWITCHES | 05/2016 Principles Double break changeover snap-action switch Curves Operating curve for type 83 112 0 1 2 3 {~ L = 5 ms R cos ϕ = 0,8 108 5 2 107 5 4 2 106 5 250V~ 380V~ 30V 2 105 0,1 0,2 0,5 1 2 5 10 16 5 B C D E F Number of cycles Resistive circuit Inductive circuit Mechanical life limit Current in Amps Dimensions ➜ Product 83 112 0 1 21 B Connection C OL = 10.65 ➜ Actuators A B Lever cross-section 1 x 6.4 mm Q E Lever cross-section 1 x 6.4 mm B9 Lever cross-section 1 x 6.4 mm V3 F Lever cross-section 1 x 6.4 mm Lever cross-section 1 x 6.4 mm |3 | SWITCHES.CROUZET.COM | MICROSWITCHES | 05/2016 ➜ Mounting accessories O2 2-pole side mounting plate K2 2-pole vertical mounting plate H Horizontal single-pole mounting plate Unless indicated, the thickness of plates is 1.5 mm Actuators and mounting accessories 70500888 Actuators A R49 Operating force - max. Release force - min. Pre-travel - max. Differential travel Total travel max. N N mm mm mm 1.2 0.25 6.2 2.1 ±0.9 7.5 70500828 70500813 70500840 BR47 ER47 Q 1.2 0.25 6.2 2.1 ±0.9 8.4 1.2 0.2 6.2 2.1 ±0.9 7.5 2.8 0.45 3.2 1.05 ±0.4 4.5 70500170 70500870 V3 R15,5 4 0.8 1.45 0.5 ±0.2 1.9 B9 4 1 1.5 0.5 ±0.2 1.9 Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left). . 70500208 Mounting accessories H Horizontal single-pole mounting plate Screws: Length 14.5 70500218 O2 2-pole side mounting plate 70500216 K2 2-pole vertical mounting plate 70599106 Other information Mounting - Operation See basic technical concepts To ensure protection against electric shock after installation in the application, please consult us when conductive parts are located less than 3mm from case/cover rear mating surfaces, opposite to button side. Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warrantly or any form of contractual commitment. Crouzet Automatismes SAS and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsability of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
831060C3.B9 价格&库存
很抱歉,暂时无法提供与“831060C3.B9”相匹配的价格&库存,您可以联系我们找货
