02/11/2015
www.crouzet.com
831370 With standard rotary action 831370 Part number 83137004
Action with a wire
Very low operating force
Long mechanical life
Part numbers
83137004
Type
Function
Connections
I (changeover)
W3
Specifications
Electrical characteristics
Rating nominal / 250 VAC (A)
Rating thermal / 250 VAC (A)
5
14
Mechanical characteristics
maximum operating force N cm
Minimum release torque N cm
Overtravel torque N cm
Pre-travel- maximum (°)
Maximum differential travel (°)
Min. overtravel (°)
Ambient operating temperature (°C)
Mechanical life (operations)
Contact gap (mm)
Weight (g)
0.12
0.03
0.5
26
14
12
-20 →+125
107
0,8
7,2
Additional specifications
Components
Material
- Case : polyamide.
- Contacts : silver.
Lever
- Stainless steel wire.
Principles
Dimensions (mm)
Product
831370
Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
02/11/2015
No
www.crouzet.com
Legend
2 holes Ø 3.2
Dimensions (mm)
Connections
W2 solder
Dimensions (mm)
Connections
W3 for 6.35 mm clips
02/11/2015
www.crouzet.com
A = 11.3
Curves
Operating curve for type 831370
No
Legend
Number of cycles
Resistive circuit
02/11/2015
www.crouzet.com
Inductive circuit
Mechanical life limit
Current in Amps
Other information
Mounting - Operation
See basic technical concepts
Product adaptations
Special levers
UL approval
很抱歉,暂时无法提供与“83137004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+153.35433
- 5+126.22416
