84210M02LNNS
84210M02LNNS
    CROUZET(高诺斯)
    DIG SW -M02- LNNS
84210M02LNNS 数据手册
| | SWITCHES.CROUZET.COM || 1 | | MANUALLY OPER ATED SWITCHES | | 12/2019 THUMBWHEEL / SELECTOR SWITCHES 8421 › Starwheel or pushwheel models › Choice of output codes with 10 or 16 switching positions › Snap-in front panel mounting for easy installation › Range of standardized dimensions to fit most panel cutouts › Large display characters for easy reading › High reliability switching thanks to gold plated contacts › Very long life › Choice of mounting accessories: snap-in endcaps, spacers and connectors Main specifications Starwheel Miniature 84210 Pushwheel Subminiature 84214 Pushwheel Large 84212 Pushwheel Miniature 84211 84212005 84212013 84212001 84212014 84212004 84212011 84212002 84212012 84212006 84212032 84212003 84212024 84211007 84211003 84211008 84211004 84211001 84211024 84211002 84211023 84211013 84211017 84211012 84211030 84214007 84214009 84214005 84214010 - ● ● ● - - - ● ● ● 79211923 79211947 79211914 79211936 79211924 79211948 25625493 25625495 79211823 79211847 79211814 79211836 79211824 79211848 79214283 79214216 - Output code Switching Readout Code Circuit Case Wheel Connecpositions tions M02 C G N S 84210005 M02 C N N S 84210055 BCD 10 0-9 M02 L G N S 84210006 M02 L N N S 84210056 M01 C G N S 84210003 M01 C N N S 84210053 Decimal 10 0-9 M01 L G N S 84210004 M01 L N N S 84210054 M03 C G N S 84210007 M03 C N N S 84210057 BCD + 10 0-9 ● M03 L G N S complement M03 L N N S 84210058 ● BCD complement 10 0-9 M07 C, L G, N N S 84210408 M29 C G N S 0-9, A-F ● M29 C,L G,N N S BCH hexadecimal 16 84210409 M29 C N N S 0-15 ● M29 C,L G,N N S ● Changeover 10 +/M04 C,L G,N N S S=solder or for connector C=short G=grey L=long N=black Long circuits have track cuts for mounting of additional components in series ● ● Mounting accessories Pairs of end caps (with clips) Spacers Separators (with clips) Connectors For securing the block of modules to the panel Blank module for creating a space or filling a gap Blank module for joining and securing two blocks For quick connection and disconnection of the module 79211709 79211759 79211738 79211745 79211752 79211760 grey black grey black grey black solder lugs solder pins Spacers and separators have same dimensions as switch modules. For an illustration, see “Examples of blocks” on last page. Electrical characteristics Rating nominal / 48 V AC/DC (A) 0.1 0.1 0.1 0.1 Operating range / 0.1 ➞ 48 V AC/DC (A) 0.0001 ➞ 0.1 0.0001 ➞ 0.1 0.0001 ➞ 0.1 0.0001 ➞ 0.1 Rating thermal (non-switchable) / 48 V AC/DC (A) 1 1 1 1 Digit height - 10 / 16 positions (mm) 4.5 / 2.8 6 4.5 4 Module width - pitch (mm) 8 12.5 10 7.6 Module height - cutout (mm) 31 54 31 22.5 Mounting depth - C / L circuits (mm) 37 / 47 37 / 47 37 / 47 32 / 42 Operating force (N) 3 4 5 5 Ambient operating temperature (° C) -25 ➞ +70 -25 ➞ +70 -25 ➞ +70 -25 ➞ +70 Ambient storage temperature (° C) -40 ➞ +85 -40 ➞ +85 -40 ➞ +85 -40 ➞ +85 Mechanical life (operations) 106 106 106 106 Weight (g) 5.5 14 7.5 4 Mechanical characteristics Standard product Product made to order Contact us cted to tracks _ _ _ 2 4 8 C ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 10 9 8 7 8 7 6 5 caon | | SWITCHES.CROUZET.COM || 2 | | MANUALLY OPER ATED SWITCHES | | 12/2019 Additional specifications - Degree of protection: IP40 (front face) - Rated insulation voltage Ui: 48 V - Max. internal resistance: 200 mΩ - Min. insulation resistance: 105 MΩ - Dielectric strength: 600 VAC between tracks 2500 VAC between tracks and external parts - Vibration resistance: 10 g, 10 - 2000 Hz - Actuator: POM (84210) ; transparent PC (84211/212/214) - Case: PA66 GB (84210/84211/84212 grey); PPO (84212 black/84214) - Sliding contacts: gold alloy - PCB tracks and terminals: gold over nickel - Mounting features: Assembly of modules through integrated pins or clips. Front mounting on panel ; fastening by the snap-in endcaps. - Certification marks: Product adaptations › Special codes: hexadecimal + complement (M28: 84210), Kelvin-Varley (M17: 84210/211/212), … › Special circuits: long without track cuts, with overlap (make before break), ... › Red wheel (R) › Connections for PCB (X3): 0.6 x 0.5 x 5 tin-plated solder pins › Lockout stops for restricting the setting range Principles Standard coding tables M01 Decimal Common C connected to tracks 0 1 2 3 4 5 6 7 8 9 C 0 ● 1 ● 2 ● 3 ● Dial 4 ● seng 5 ● 6 ● 7 ● 8 ● 9 ● 84210/211/212 11 10 9 8 7 6 5 4 3 2 12 84214 11 10 9 8 7 6 5 4 3 2 1 Terminal locaon C conn. to M04 Changeover 1 2 C + ● ● + ● ● Dial + ● seng ● + ● ● + ● ● 84210/211/212 9 8 2 84214 3 7 5 Terminal locaon 0 1 2 3 Dial 4 seng 5 6 7 8 9 84210/211/212 84214 C connected to _ _ _ _ 1 2 4 8 C 0 ● ● ● ● 1 ● ● ● 2 ● ● ● 3 ● ● Dial 4 ● ● ● seng 5 ● ● 6 ● ● 7 ● 8 ● ● ● 9 ● ● 84210/211/212 4 11 2 10 3 84214 9 7 5 3 1 Terminal locaon M07 BCD compl. Other codes: please consult us Curves Electrical life for 82410, 84211, 84212 and 84214 48 Va /c 0.1 A 106 cycles M02 BCD C connected to 1 2 4 8 C ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 8 7 6 5 9 8 7 6 5 1 Terminal locaon M29 BCH Hexadec. 0 1 2 3 4 5 6 Dial 7 seng 8 9 A/10 B/11 C/12 D/13 E/14 F/15 84210/211/212 Common C connected to tracks _ _ _ _ 1 2 4 8 1 2 4 8 C 0 ● ● ● ● 1 ● ● ● ● 2 ● ● ● ● 3 ● ● ● ● Dial 4 ● ● ● ● seng 5 ● ● ● ● ● ● 6 ● ● 7 ● ● ● ● 8 ● ● ● ● 9 ● ● ● ● 84210/211/212 6 5 4 3 11 10 9 8 7 84214 4 3 2 1 9 8 7 6 5 Terminal locaon M03 BCD + compl. C connected to 1 2 4 8 C ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 11 9 2 4 7 Terminal locaon ● C conn. to M04 Changeover 1 2 C + ● ● + ● ● Dial + ● seng ● + ● ● + ● ● 84210/211/212 9 8 2 84214 3 7 5 Terminal locaon s 8 | | SWITCHES.CROUZET.COM || 3 | | MANUALLY OPER ATED SWITCHES | | 12/2019 Dimensions Products 84210 84211 Ø1 1 1 1 2 3 C Ø1 2,54 1 2 3 12 12 * 0,8 0,8 L* 84212 84214 8 1 Ø1 1 2 3 12 18,5 pitch 2: for M01 pitch 5: for M02, M04, M07 pitch 2.5: for M03 0,8 L* B Terminal location * Long circuits have track cuts for mounting components in series, except for common C. Hole spacings: 84210/211/212: 5.5, 8 and 10.5 mm 84214: 7.5 and 10 mm B Panel cutouts 84210 84211 84212 84214 A (n+1) 8 + J (n+1) 10 + J (n+1) 12.5 + J (nx7.62) + 3.5 B 31 31 54 22.5 A n: number of modules J: clearance: 1 mm for 1 ≤ n ≤ 10 1.5 m for 11 ≤ n ≤ 20 | | SWITCHES.CROUZET.COM || 4 | | MANUALLY OPER ATED SWITCHES Panel thickness 84210/211/212 | | 12/2019 84214 1➝4 mm Clips have two mounting positions according to panel thickness. Connectors Solder lugs Solder pins Installation recommendations See “Basic technical concepts” How to order Use the 8 digit part numbers when they are defined Other cases, precise: Type of thumbwheel switch - Code - Circuit - Case - Wheel - Connections - Adaptation* + Mounting accessories* + Connector* * if needed Example: 84212 M07 L N N S + 79211947 + 25625493 Examples of blocks 2 3 4 1 2 2 1 3 4 2 1- Switch module 2- End caps 3- Spacer 4- Separator Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warrantly or any form of contractual commitment. Crouzet Automatismes SAS and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsability of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
84210M02LNNS 价格&库存
很抱歉,暂时无法提供与“84210M02LNNS”相匹配的价格&库存,您可以联系我们找货
