25625495
    CROUZET(高诺斯)
    CONN SWITCH SOCKET EDGE SOLDER
25625495 数据手册
Readout module 1 Types 84 217 0 84 217 0 ● Compatible with switch 84 211 Décodages Decoding A8.3 MAN 4640 MC 14511 Display device Decoder (see truth table) Input LT (test) Input EL (storage) Typical consumption per segment Typical decoder consumption at 25° C Display code Technology ● 2 A10.3 MAN 4640 MC 14495 ● ● 7 mA 0.015 µ A Decimal CMOS 24 V Supply voltage ● 7 mA 0.04 µ A Hexadecimal CMOS 24 V Circuit Long L ● ● G ● ● O ● ● ● ● Colour of case Grey Colour of display device Orange (standard) 3 Connections For soldering or for connector 4 Mounting accessories Pair of end caps (with clips) Spacer Separator module (with clips) Grey Grey Grey JE/G MI/G MS/G 79 211 823 79 211 814 79 211 824 79 211 823 79 211 814 79 211 824 Solder terminals Wire-wrap terminals with lugs Wire-wrap terminals without lugs For soldering to printed circuit W2 X2 X2 X3 25 625 493 25 625 494 25 625 492 25 625 495 25 625 493 25 625 494 25 625 492 25 625 495 Mechanical characteristics Width of module Digit height Ambient operating temperature mm mm °C 10 10 0 + 60 10 10 0 + 60 Connectors 5 Dimensions Panel cut-out 84 217 A B Panel thickness (n+1) 10 + J 31 * n = number of modules - Mounting accessories and connectors : See page 3/4 To order, specify : Standard products, non stocked 1 3 2 Type Connection 4 Decoder Accessory 5 Connector Example : Display module 84 217 0 - A10-3 LGOS - 79211823 - 25625493 4/3 4
25625495 价格&库存
很抱歉,暂时无法提供与“25625495”相匹配的价格&库存,您可以联系我们找货
