Miniature Switches Series 83 161 DIN 41635 A
Types
General specifications
Layout
2
3
6
Part numbers for standard products with
connections of type
Number of
operations
Resistive circuit:
Inductive circuit
c L = 5 ms
R
a cos ϕ = 0.8
831613 Mechanical
831611 durability
Resistive circuit:
inductive circuit
c L = 5 ms
R
a cos ϕ = 0.8
m
co
Mechanical characteristics
Current
Horsepower
N (oz.)
N (oz.)
N (oz.)
N (oz.)
mm (in.)
mm (in.)
mm (in.)
mm (in.)
°C (°F)
Operations
mm (in.)
g (oz.)
s.
Operating force - max.
Release force - min.
Total travel force - max.
Permitted overtravel force - max.
Rest position - max.
Tripping point
Differential travel
Overtravel - min. (OT)
Ambient operating temperature
Mechanical durability (for 2/3 OT)
Contact gap
Weight
A
HP
Contact type
po
Mechanical
durability
Electrical characteristics
Current rating at 125/250 V
nt
Number of
operations
Features
ne
Components
Material
- Case : glass-filled polyamide (self-extinguishing version to UL 94 VO
and IEC 695-2-1 850° C - available on request)
- Button : polyamide
- Contacts : nickel silver or gold alloy (dual-current)
Actuators
- flat : stainless steel
- roller : stainless steel, glass-filled polyamide roller
- other types of polyamide
Approvals: NF - UL/cUL
Operating curve
For type 83 161 5 - 5 SP 4136
For type 83 161 1 3
C (Form C) SPDT
B (Form B) SPNC
A (Form A) SPNO
m
Rating in
Amps
Rating in
Amps
co
For type 83 161 8
For type 83 161 9 SP 4136
Number of
operations
lin
e
Number of
operations
on
2 solder
3 for 1/4˝ Quick Connects
Actuators and mounting positions
Resistive circuit:
Resistive circuit:
Connections
A 79 215 740
Part numbers for standard actuators
Actuators-Length
mm (in.)
Flat 161A R14.2 (.56)
Mechanical
durability
Mechanical
durability
Mounting positions
Coefficient
Tripping point (except 83 161 6)
Tripping point 83 161 6
Rating in
Amps
Rating in
Amps
For types 83 161 8 - 9 SP 4136 dual-current
Models 83 161 8 and 83 161 9 SP 4136 are designed to operate equally
well on dual-current (1 mA 4 V minimum) or medium-current
(5 A maximum) circuits.
However, a given product should only be used to switch one type of
circuit during its working life.
Actuators-Length
mm (in.)
A
2
15.2 ±1(.6±.004)
14.8 ±1(.59±.004)
B
1
15.2 ±0.45(.6±.018)
15 ± 0.45(.59±.018)
H 79 218 651
Dummy roller 161G R21.8 (.86)
Mounting positions
A
B
Coefficient
3
1.8
21.7 ±2(.85±.08) 21.7 ±0.7(.85±.03)
±2
±.08
21.5 (.85 ) 21.5 ±07(.85±.03)
Except where otherwise indicated, flat and roller actuators are supplied unmounted.
Other information
For other forces, actuators, connections and temperatures,
please consult us.
Normally stocked items
Catalog products produced
to order
Products and specifications subject to change without notice.
Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com
3/14
1
83161.2(15.1A)
83161.3(10.1A)
831611C2.0
831611C3.0
831611C6.0
831612C2.0
831612C3.0
831612C6.0
831613C2.0
831613C3.0
831613C6.0
High Force
High Current
Standard
831615C2.0
831615C3.0
831615C6.0
Low Force
Ultra Light Force
0.8 (2.8)
0.2 (0.7)
2 (7.0)
20 (70.5)
16.2 (0.64)
14.7±0.3 (.58±0.16)
0.35 (0.014)
1.2 (0.05)
-20 +125 (-4 +257)
2 x 107
0.4 (0.016)
5.6 (.2)
0.8 (2.8)
0.2 (0.7)
2 (7.0)
20 (70.5)
16.2 (0.64)
14.7±0.3 (.58±0.16)
0.35 (0.014)
1.2 (0.05)
-20 +125 (-4 +257)
2 x 107
0.4 (0.016)
5.6 (.2)
C
B
A
C
B
A
C
B
A
0.25 (0.9)
0.05 (0.18)
0.35 (1.2)
20 (70.5)
16.3 (0.64)
14.7±0.4 (.58±0.16)
0.35 (0.014)
1.1 (0.05)
-20 +125 (-4 +257)
5 x 107
0.4 (0.016)
5.6 (.2)
po
3 (10.5)
1 (3.5)
4.5 (15.8)
20 (70.5)
16.1 (0.63)
14.7±0.4 (.58±0.16)
0.35 (0.014)
1.1 (0.05)
-20 +125 (-4 +257)
107
0.4 (0.016)
5.6 (.2)
4
1/10
Dual Current
0.1
N/A
0.15 (0.54)
0.04 (0.14)
0.2 (0.72)
20 (70.5)
16.3 (0.64)
14.7±0.3 (.58±0.16)
0.35 (0.014)
1.2 (0.05)
-20 +125 (-4 +257)
5 x 107
0.4 (0.016)
5.6 (.2)
5 (18)
0.5 (1.8)
6 (21.6)
20 (70.5)
16.1 (0.63)
14.5±0.4 (.58±0.16)
0.8 (0.03)
0.9 (0.035)
-20 +125 (-4 +257)
5 x 104
3.2 (0.126)
5.6 (.2)
0.8 (2.8)
0.2 (0.7)
0.2 (.07)
20 (70.5)
16.2 (0.64)
14.7±0.4 (.58±0.16)
0.35 (0.014)
1.2 (0.05)
-20 +125 (-4 +257)
2 x 107
0.4 (0.016)
5.6 (.2)
C
B
A
C
B
A
C
B
A
2
3
3
co
m
C
B
A
831618C2.0
831618C3.0
831618C6.0
6.1
1/3
co
4
1/10
83161.8(0.1A)
Wide Gap
s.
10.1
1/2
83161.6
831616C2.0
831616C3.0
831616C6.0
nt
15.1
1/2
83161.5SP4136
83161.9SP4136
ne
10.1
1/2
83161.5(4A)
83161.9(0.1A)
m
83161.1(10.1A)
5 screw
A
4
15.2±2.5 (.6±.1)
14.4±2.5(.56±.1)
B
2
15.2±1(.6±.04)
14.8±1(.58±.04)
7 for .11 Quick Connects
lin
e
70 507 524
Flat 161A R25.4 (1)
E
on
B
6 for 3/16˝ Quick Connects
C
1.5
15.2 ±0.8(.6±.03)
14.9 ±0.8(.59±.03)
4
79 215 742
Roller 161E R13.6 (.54)
A
2
20.5±1.5(.81±.06)
20.1±1.5(.79±.06)
L
B
1
20.5±0.8(.81±.03)
20.3±0.8(.80±.03)
V
G 70 507 529
Roller 161E R24.1 (.95)
A
4
20.5±2.9(.81±.11)
19.7±2.9(.76 ±.11)
B
2
20.5±1.5(.81±.06)
20.1±1.5(.79±.06)
F 70 507 528
Dummy 161F roller R22.2 (.84)
C
1.5
20.5±1.2(.81±.05)
20.2±1.2(.79 ±.05)
A
3
20.4±2(.8±.08)
20.2±2(.79±.08)
C 70 507 526
B
C
1.8
1.5
20.5±0.7(.81±.03) 20.5±0.9(.81±.035)
±2
±.08
20.2 (.79 )
4
D 79 215 835
Flat 161A R50 (1.9)
Flat 161A R60 (2.39)
161V
** Telescopic
plunger
Manual action
161L
D Factory Mount only
B
C
B
C
A
A
1
6
3
2
7
3.5
2.2
1
21.5 ±1 (.85 ±.04 )
±6.3
±2
±1.6
±6.9
±2.5
±0.45
15.2
15.2
15.2
15.2
15.2
15.2±2.3
18.35
21.5 ±1 (.85 ±.04 )
For factory mounting, specify fixing position A, B or C
** For 83 161 1, 83 161 3, 83 161,6, 83 161 8, mounted in factory (supplied without nut)
To order, please specify :
1
Switch Type
831612 831619
831613 831616
831615 831611
831618
2
Contact Type
A
B
C
To order actuators seperately, use the 8 digit P/N
3
Connection
Example : 831612 C 3 • C A
4
2
3
5
6
7
Example switch is 831612, SPDT, 1/4” Q.C., C actuator mounted in A position
5
Actuators
Ø
A
B
C
D
E
F
G
H
L
V
Actuator Position
A
B C
D
A
C
B (std) D
Ø = No actuator
3/15
5
Miniature Switches DIN 41635 A
Dimensions
(.8 ±.008 )
+.006
+.002
3 +0.15
+0.05
(.12 +.006
+.002
3 (.12)
27.8 ±0.15 (1.09 ±.006)
3.4
(.13)
co
2.8 (.11)
10.3 ±0.15 (.41±.006)
(.12
m
±0.2
20.2
Ø3 +0.15
+0.05
2.8
(.11)
3.9
22.2 ±0.2 (.87 ±.008 )
2.8
(.11)
15.8 -0.15
-0.1
(.?? +.006
+.002
10.3 ±0.1
(.41 ±.004)
s.
mm (in)
nt
Connections
3.2
(.13)
±0.06
Ø1.4
.06±.002
17.4
(.69)
6.3
(.25)
47
+.008
Ø1.3 +0.2
+0 (.05 -0
7.1±0.1
.28±.004
7.1±0.1
(.28 ±.004 )
Actuators
mm (in)
F
Force calculation : divide the switch forces by the coefficient in the table.
Travel calculation : multiply the switch travel by the same coefficient.
2mm
(.08)
A
B C
D
Example :
83 161 3 with B Flat 161A actuator R 25.4 (1) position A (coef. 4)
Operating force : 0.8 4 = 0.2 N
Pre-travel: 1.4 x 4 = 5.6 mm (.055 x 4 = .22 in)
3/16
(6.3 ±0.1
3 (.118)
+.008
2.2 +0.2
+0 (.09 -0
3.1
.12 ±.004
2.8 ±0.1
(.11 ±.004 )
±0.1
4
(.16)
9x6
(.35x.24)
7 (2.5x0.5 (.11x.02)) Quick Connects
6 (4.8x0.5 (.3/16x.02)) Quick Connects
10.7 ±0.2 (.42 ±.008 )
Ø1.7 +0.05
+0
(.067 ±.002)
6.2
(.244)
co
9.8
(.286)
M3x4
(.12x.16)
on
45°
lin
e
20 (.79)
max.
5 Screw
4.3 +0.05
-0.15
+.02 )
(.169 -.006
17.4 (.685)
47
2.8 (.11)
3.2 (.13)
9.3 ±0.2
(.366±.008)
m
47
6.7 (.264)
ne
po
1.7 +0.05
+0
(.067 ±.002)
6.3
(.13 ±.012)
3.9x0.8 ±.02)
(.15x.03 ±.001)
3.2 (.13)
3.2 ±0.3
12.1±0.2
(.25 ±.03 )
(.248±.004)
3 (6.3x0.8 (1/4x.03)) Quick Connects
2 Solder
4.8±0.1
.19 ±.004
OL = 13.35 (.53)
2.8 (.11)
83 161
m
Actuator Mounting Positions
E-G
co
Actuators
L
ne
nt
s.
A-B-C-D
po
V
lin
e
co
m
3
H
on
F
Accessories
Nuts 70 602 118 for L type actuator
3/17
很抱歉,暂时无法提供与“831613C6.L”相匹配的价格&库存,您可以联系我们找货
