83111521
83111521
    CROUZET(高诺斯)
    检测开关
83111521 数据手册
Protected ➜ 83 106 ■ Double break switching ■ Options for operation in stable positions ■ Choice of actuators and fixing positions Main specifications Standard 83 106 0 Function Connections I (changeover) W3 I (changeover) W1 - W2 R (normally closed) W1 - W2 - W3 C (normally open) W1 - W2 - W3 Electrical characteristics Rating nominal / 250 V AC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Tripping point (mm) Min. overtravel (mm) Mechanical life (operations) Max. permitted overtravel force (N) Rest position max. (mm) differential travel (mm) Ambient operating temperature (°C) Contact gap (mm) Weight (g) 1 Components Material - Case : polyamide UL94V2 (83 106) - Contacts : nickel silver Levers - Mild steel (zinc) - Roller : polyamide - Adjusting screws : self-retaining - Plates : iridescent passivated mild steel (zinc) NB : Fixing holes for these microswitches have metal ferrules. Product adaptations ■ ■ ■ ■ 58 2 stable plunger positions 83 106 7 83 106 022 ● ● ● ● ● ● ● ● ● ● ● 5 17.5 5 17.5 5 17.5 4 1 11.45 ±0.2 -0.25 0.7 107 20 12.75 0.5±0.2 -40 ➞ +85 0.4 x 2 8 0.45 106 -40 ➞ +85 0.4 x 2 9 2 106 -40 ➞ +85 0.4 x 2 8 # Additional specifications To order, see page 12 2 stable lever positions 83 106 4 Special levers Reinforced spring Special contacts Approvals : UL - cUL Principles Double break changeover switch Curves Operating curve for types 83 106 0 / 4 / 7 1 2 3 {~ L = 5 ms R cos ϕ = 0,8 108 5 2 107 5 4 2 106 5 250V~ 380V~ 30V 2 105 0,1 0,2 0,5 1 2 5 10 16 5 B C D E F Number of cycles Resistive circuit Inductive circuit Mechanical life limit Current in Amps Dimensions ➜ Product 83 106 83 106 4 83 106 7 W2 solder W3 for 6.35 mm clips 1 1 2 B OL = 10.65 Depth 1.2 CØ2 +0.01 +0.65 ➜ Connections W1 screw 59 ➜ Actuators A B Lever cross-section 1 x 6.4 mm Q E Lever cross-section 1 x 6.4 mm B9 Lever cross-section 1 x 6.4 mm V3 F Lever cross-section 1 x 6.4 mm Lever cross-section 1 x 6.4 mm ➜ Mounting accessories 1 O2 2-pole side mounting plate K2 2-pole vertical mounting plate H Horizontal single-pole mounting plate Unless indicated, the thickness of plates is 1.5 mm 60 Y Side plate Actuators and fixing positions Actuators and fixing positions A R49 Actuators Operating force - max. Release force - min. Pre-travel - max. Differential travel Total travel max. N N mm mm mm 1.2 0.25 6.2 2.1 ±0.9 7.5 BR47 1.2 0.25 6.2 2.1 ±0.9 8.4 ER47 1.2 0.2 6.2 2.1 ±0.9 7.5 Q 2.8 0.45 3.2 1.05 ±0.4 4.5 V3 R15.5 4 0.8 1.45 0.5 ±0.2 1.9 B9 4 1 1.5 0.5 ±0.2 1.9 Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left). Mounting accessories Y Side plate H Horizontal single-pole mounting plate O2 2-pole side mounting plate K2 2-pole vertical mounting plate 1 Other information Mounting - Operation See basic technical concepts 61 Protected ➜ 83 109 ■ ■ ■ ■ Double break switching Front connections Options for operation in stable positions Choice of actuators and fixing positions Main specifications Outputs on front face 83 109 0 Function Connections I (changeover) W2 R (normally closed) W2 C (normally open) W2 Electrical characteristics Rating nominal / 250 V AC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Tripping point (mm) Min. overtravel (mm) Mechanical life (operations) Max. permitted overtravel force (N) Rest position max. (mm) differential travel (mm) Ambient operating temperature (°C) Contact gap (mm) Weight (g) 1 Components Material - Case : polyamide UL94V2 - Contacts : nickel silver Levers - Mild steel (zinc) - Roller : polyamide - Adjusting screws : self-retaining - Plates : iridescent passivated mild steel (zinc) NB : Fixing holes for these microswitches have metal ferrules. Product adaptations ■ ■ ■ ■ 62 ● ● 5 17.5 4 1 11.45 + 0.2 - 0.25 0.7 107 20 12.75 0.5±0.2 - 40 ➞ +85 0.4 x 2 8 # Additional specifications To order, see page 12 83 109 004 Special levers Reinforced spring Special contacts Approvals : UL - cUL Principles Double break changeover switch Curves Operating curve for type 83 109 0 1 2 3 {~ L = 5 ms R cos ϕ = 0,8 108 5 2 107 5 4 2 106 5 250V~ 380V~ 30V 2 105 0,1 0,2 0,5 1 2 5 10 16 5 B C D E F Number of cycles Resistive circuit Inductive circuit Mechanical life limit Current in Amps Dimensions ➜ Product ➜ Connections 83 109 0 W2 solder 1 1 2 B OL = 10.65 Depth 1.2 CØ2 +0.01 +0.65 ➜ Actuators A B Lever cross-section 1 x 6.4 mm E Lever cross-section 1 x 6.4 mm Lever cross-section 1 x 6.4 mm 63 Q B9 V3 F Lever cross-section 1 x 6.4 mm Lever cross-section 1 x 6.4 mm ➜ Mounting accessories O2 2-pole side mounting plate K2 2-pole vertical mounting plate H Horizontal single-pole mounting plate Unless indicated, the thickness of plates is 1.5 mm 1 Actuators and fixing positions Actuators and fixing positions A R49 Actuators Operating force - max. Release force - min. Pre-travel - max. Differential travel Total travel max. N N mm mm mm 1.2 0.25 6.2 2.1 ±0.9 7.5 BR47 1.2 0.25 6.2 2.1 ±0.9 8.4 ER47 1.2 0.2 6.2 2.1 ±0.9 7.5 Q 2.8 0.45 3.2 1.05 ±0.4 4.5 V3 R15,5 4 0.8 1.45 0.5 ±0.2 1.9 B9 4 1 1.5 0.5 ±0.2 1.9 Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left). . Mounting accessories H Horizontal single-pole mounting plate Other information Mounting - Operation See basic technical concepts 64 O2 2-pole side mounting plate K2 2-pole vertical mounting plate Protected ➜ 83 111 ■ ■ ■ ■ Double break switching Rear-fixing via nut or clips Options for operation in stable positions Choice of actuators and fixing positions Main specifications Function Connections I (changeover) W1 - W2 - W3 R (normally closed) W1 - W2 - W3 C (normally open) W1 - W2 - W3 Electrical characteristics Rating nominal / 250 V AC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Tripping point (mm) Min. overtravel (mm) Mechanical life (operations) Max. permitted overtravel force (N) Rest position max. (mm) Maximum differential travel (mm) Ambient operating temperature (°C) Contact gap (mm) Weight (g) 1 Components Material - Case : polyamide UL94V2 - Contacts : nickel silver Levers - Mild steel (zinc) - Roller : polyamide - Adjusting screws : self-retaining - Plates : iridescent passivated mild steel (zinc) NB : Fixing holes for these microswitches have metal ferrules. Product adaptations ■ ■ ■ ■ 70 Rear-fixing with clips 83 111 5 ● ● ● ● ● ● 5 17.5 5 17.5 4 1 11.45 + 0.2 - 0.25 0.7 107 20 0.5±0.2 - 40 ➞ +85 0.4 x 2 8 4 1 11.45 + 0.2 - 0.25 0.7 107 20 0.5±0.2 - 40 ➞ +85 0.4 x 2 8 # Additional specifications To order, see page 12 Rear-fixing with a nut 83 111 0 Special levers Reinforced spring Special contacts Approvals : UL - cUL Principles Double break changeover switch Curves Operating curve for types 83 111 0 - 83 111 5 1 2 3 {~ L = 5 ms R cos ϕ = 0,8 108 5 2 107 5 4 2 106 5 250V~ 380V~ 30V 2 105 0,1 0,2 0,5 1 2 5 10 16 5 B C D E F Number of cycles Resistive circuit Inductive circuit Mechanical life limit Current in Amps Dimensions ➜ Product 83 111 0 83 111 5 1 ➜ Connections W1 screw W2 solder W3 for 6.35 mm clips 71 ➜ Actuators A B Lever cross-section 1 x 6.4 mm E Lever cross-section 1 x 6.4 mm Q Lever cross-section 1 x 6.4 mm B9 V3 F Lever cross-section 1 x 6.4 mm 1 Lever cross-section 1 x 6.4 mm Actuators and fixing positions Actuators and fixing positions A R49 Actuators Operating force - max. Release force - min. Pre-travel - max Differential travel Total travel max. N N mm mm mm 1.2 0.25 6.2 2.1 ±0.9 7.5 BR47 1.2 0.25 6.2 2.1 ±0.9 8.4 ER47 1.2 0.2 6.2 2.1 ±0.9 7.5 Q 2.8 0.45 3.2 1.05 ±0.4 4.5 V3 R15.5 4 0.8 1.45 0.5 ±0.2 1.9 Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left).. Other information Mounting - Operation See basic technical concepts 72 B9 4 1 1.5 0.5 ±0.2 1.9 Protected ➜ 83 112 ■ ■ ■ ■ Double break switching Flush-mounted connections Options for operation in stable positions Choice of actuators and fixing positions Main specifications Flush-mounted connections 83 112 0 Function Connections I (changeover) W1 Electrical characteristics Rating nominal / 250 V AC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Maximum operating force (N) Min. Release force (N) Tripping point (mm) Min. overtravel (mm) Mechanical life (operations) Max. permitted overtravel force (N) Rest position max. (mm) differential travel (mm) Ambient operating temperature (°C) Contact gap (mm) Weight (g) 1 Components Material - Case : polyamide UL94V2 - Contacts : nickel silver Levers - Mild steel (zinc) - Roller : polyamide - Adjusting screws : self-retaining - Plates : iridescent passivated mild steel (zinc) NB : Fixing holes for these microswitches have metal ferrules. Product adaptations ■ ■ ■ ■ 66 5 17.5 4 1 11.45 + 0.2 - 0.25 0.7 107 20 12.75 0.5±0.2 -40 ➞ +85 0.4 x 2 14.5 # Additional specifications To order, see page 12 83 112 001 Special levers Reinforced spring Special contacts Approvals : UL - cUL Principles Double break changeover switch Curves Operating curve for type 83 112 0 1 2 3 {~ L = 5 ms R cos ϕ = 0,8 108 5 2 107 5 4 2 106 5 250V~ 380V~ 30V 2 105 0,1 0,2 0,5 1 2 5 10 16 5 B C D E F Number of cycles Resistive circuit Inductive circuit Mechanical life limit Current in Amps Dimensions ➜ Product 83 112 0 1 1 21 B Connection C OL = 10.65 ➜ Actuators A B Lever cross-section 1 x 6.4 mm Q E Lever cross-section 1 x 6.4 mm B9 Lever cross-section 1 x 6.4 mm V3 F Lever cross-section 1 x 6.4 mm Lever cross-section 1 x 6.4 mm 67 ➜ Mounting accessories O2 2-pole side mounting plate K2 2-pole vertical mounting plate H Horizontal single-pole mounting plate Unless indicated, the thickness of plates is 1.5 mm Actuators and fixing positions Actuators and fixing positions 1 A R49 Actuators Operating force - max. Release force - min. Pre-travel - max. Differential travel Total travel max. N N mm mm mm 1.2 0.25 6.2 2.1 ±0.9 7.5 BR47 1.2 0.25 6.2 2.1 ±0.9 8.4 ER47 1.2 0.2 6.2 2.1 ±0.9 7.5 Q 2.8 0.45 3.2 1.05 ±0.4 4.5 V3 R15,5 4 0.8 1.45 0.5 ±0.2 1.9 B9 4 1 1.5 0.5 ±0.2 1.9 Except where otherwise indicated, the flat and roller levers are mounted as shown in the dimensional drawings (mounted on the left). . Mounting accessories H Horizontal single-pole mounting plate Other information Mounting - Operation See basic technical concepts 68 O2 2-pole side mounting plate K2 2-pole vertical mounting plate
83111521 价格&库存
很抱歉,暂时无法提供与“83111521”相匹配的价格&库存,您可以联系我们找货
