83181002
83181002
    CROUZET(高诺斯)
    检测开关 单刀双掷 DC24V AC250V
83181002 数据手册
18/06/2013 www.crouzet.com V4 8318 Sealed High-current 83180 Part number made to order IP 67 protection Nominal ratings 0.1 A to 10 A / 250 VAC Minimum rating 1 mA / 4 VDC Operating temperature -40 °C to +125 °C Choice of actuators with 2 possible fixing positions Part numbers 831800 Type Function Connections High-current 83180 I (changeover) X1A* - X1S* - X2A* - X2S* - X3A* - X3S* - FB0 - FG0 - CD0** - CB0** - CG0** Specifications Electrical characteristics Rating nominal / 250 VAC (A) Rating thermal / 250 VAC (A) 10 12,5 Mechanical characteristics Maximum operating force (N) Min. Release force (N) Maximum total travel force (N) Max. permitted overtravel force (N) Maximum rest position (mm) Operating position (mm) Maximum differential travel (mm) Min. overtravel (mm) Ambient operating temperature for blade version (°C) Ambient operating temperature for wires/cable version (° C) Mechanical life (operations) Contact gap (mm) Weight (g) (tags version) 3,4 1 5 10 9,3 8,4 ±0,3 0,1 0,6 -40 →+125 -40 →+105 106 0,4 2 Comments * Type 83180 available on request ** Cable version for types 83181, 83183 and 83186 Additional specifications Components Material - Case : polyester UL 94VO - Button : polyester - Membrane : silicon - Contacts : AgCdO or AgSnO2 gold-plated AgNi (dual-current) - Terminals : silver-plated, tinned brass - Cable/Lead : PVC Levers - Flat : stainless steel - Roller : stainless steel, polyamide roller Principles Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 18/06/2013 www.crouzet.com Dimensions (mm) Product Symmetrical version types 83180 / 181 / 183 / 186 No Legend OL = 7.6 max. Dimensions (mm) Product Asymmetrical version types 83180 / 181 / 183 / 186 Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm Dimensions (mm) Connections W2S Solder Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 18/06/2013 Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm Dimensions (mm) Connections W7S Faston 2.8 x 0.5 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 18/06/2013 Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm Dimensions (mm) Connections X1A Straight PCB output Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm Dimensions (mm) Connections X1S Straight PCB output Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 18/06/2013 Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm Dimensions (mm) Connections X2A - X2S Side outputs, PCB rear Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm Dimensions (mm) Connections X3A - X3S Side outputs, PCB front Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 18/06/2013 www.crouzet.com Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm Dimensions (mm) Drilling Printed circuit board mounting Asymmetrical X1A, X2A, X3A Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm No Legend 1.C 4.NO 2.NC Dimensions (mm) Drilling Printed circuit board mounting Symmetrical X1S, X2S, X3S Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 18/06/2013 www.crouzet.com Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm No Legend 1.C 4.NO 2.NC Dimensions (mm) Drilling Mounting on a printed circuit board with fixing pins Asymmetrical Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm Dimensions (mm) Drilling Mounting on a printed circuit board with fixing pins Symmetrical Fixed by 2 M2 screws Torque with screw only : 0.2 Nm, with screw + washer : 0.3 Nm Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 18/06/2013 www.crouzet.com Dimensions (mm) Connections Lead outputs FG0 lead output on left - FD0 lead output on right Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 0.5 mm2 83180 = 0.75 mm2 No Legend FG0 FD0 Standard 500 mm Dimensions (mm) Connections Lead/cable output CB0 cable output on bottom Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 0.5 mm2 83180 = 0.75 mm2 No Legend Standard 500 mm Dimensions (mm) Connections Cable outputs CG0 cable output on left - CD0 cable output on right Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 18/06/2013 www.crouzet.com Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 3 x 0.5 mm2 No Legend CG0 CD0 Standard 500 mm Dimensions (mm) Actuator mounting positions Fixing position Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 3 x 0.5 mm2 Dimensions (mm) Actuators 170 A Flat Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 18/06/2013 Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 3 x 0.5 mm2 Dimensions (mm) Actuators 170 E Roller Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 3 x 0.5 mm2 Dimensions (mm) Actuators 170 F Dummy roller Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 18/06/2013 Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 3 x 0.5 mm2 Dimensions (mm) Actuators Recommendations for operation from the side Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 18/06/2013 www.crouzet.com Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 3 x 0.5 mm2 Dimensions (mm) Mounting accessories Fixing pins Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 3 x 0.5 mm2 No Legend X2 output Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 18/06/2013 www.crouzet.com Dimensions (mm) Mounting accessories Fixing pins Black = Common Grey = NC Blue = NO Conductor cross-section : 83181 / 83183 / 83186 = 3 x 0.5 mm2 No Legend X3 output Curves Operating curve 250 VAC Model 83181 is designed to operate equally well on dual-current (1 mA 4 V minimum) or medium-current (6 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life. No Legend Number of cycles Resistive circuit Current in Amps Curves Switch rating with DC supply Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 18/06/2013 www.crouzet.com Model 83181 is designed to operate equally well on dual-current (1 mA 4 V minimum) or medium-current (6 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life. Connections Actuators and fixing positions Other information Mounting - Operation See basic technical concepts Degree of protection - Tag version : →casing = IP67 →terminals = IP00 - Lead/cable version : →output/casing = IP67 To calculate force : divide the switch force by the coefficient in the table. To calculate travel : multiply the switch travel by the same coefficient. Product adaptations Special levers Specific fixings Special leads, cables, cable harnesses NF - UL - cUL approvals Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
83181002 价格&库存
很抱歉,暂时无法提供与“83181002”相匹配的价格&库存,您可以联系我们找货
