| | 11/2020
››GN Series
Classic Solid State Relays
Panel Mount - AC Output Single Phase
››Output current of 10, 25, 50, 75, 100 and 125 Amps
››Output voltage of 24-280 Va and 48-660 Va
››Control voltage of 4-32 Vc, 18-36 Vz, 20-265 Va and 90-260 Va
››Zero cross or instantaneous (resistive or inductive loads)
››Integrated IP20 touch-safe removable covers
››Built-in overvoltage protection (only Zero Cross)
››LED input status indicator
Zero Cross
Version
Instantaneous
Version
Product Selection - Zero Cross (Resistive Loads)
Rated Load Current
10A
Output Voltage
25A
50A
75A
100A
125A
24-280 Va
24-280 Va
48-660 Va
48-660 Va
48-660 Va
48-660 Va
48-660 Va
84137000N
84137010N
84137110N
84137120N
84137130N
84137140N
84137180N
84137131N
84137141N
84137181N
Control Voltage
4-32 Vc
84137012N
18-36 Vz
84137001N
20-265 Va
84137011N
84137122N
84137111N
84137121N
Product Selection- Instantaneous (Inductive Loads)
Rated Load Current
25A
Output Voltage
50A
24-280 Va
75A
48-660 Va
48-660 Va
Control Voltage
4-32 Vc
84137210N
84137320N
90-260 Va
84137211N
84137321N
84137330N
PART NUMBERING SYSTEM
Series
8413: Single Phase
8413
Output Voltage
0: 280 Va / Zero Cross
1: 660 Va / Zero Cross
2: 280 Va / Random
3: 660 Va / Random
7
Cover/Layout
7: Included
Generation
N: New Generation
1
Output Current
0: 10 A
1: 25 A
2: 50 A
3: 75 A
4: 100 A
8: 125 A
N
Control Voltage
0: 4-32 Vc
1: 20-265 Va
2: 18-36 Vz
Do you need an adapted or customized solution? Contact us on www.crouzet.com
Description:
Crouzet Solid State Relays are designed to be used in almost any application, offering very long life expectancy and are easy to install, easy to use,
robust and multipurpose.
RÉFÉRENCEMENT
For more information about Crouzet’s Solid State relays, please visit www.crouzet.com.
Série
8413: Monophasé
Tension de sortie
0: 280 Va / Synchrone
1: 660 Va / Synchrone
2: 280 Va / Instantanée
Génération
N: Nouvelle
génération
| | WWW.CROUZET.COM
|| 2
| | GN Series
| | 11/2020
Accessories
Type
Description
Heatsink
0.9 °C/W Thermal Resistance
26532752N
Heatsink
1.1 °C/W Thermal Resistance
26532753N
Heatsink
1.2 °C/W Thermal Resistance
26532754N
Heatsink
1.75 °C/W Thermal Resistance
26532755N
Heatsink
2.2 °C/W Thermal Resistance
26532756N
Adapter
DIN Rail
26532764N
Thermal Pad
Pre-cut Thermal Pad
26532720N
Thermal Pad
Self-Adhesive Thermal Pad
26532722N
Screws
Screw Mounting Kit
26532001
Thermal Grease
Thermal Grease for Heatsink mounting
26532003
Part-Number
Output Specifications(1)
Description
10A
25A
50A
Maximum Load Current [Arms](3)
10
25
Minimum Load Current [mArms]
5
Min / Max Operating Voltage
(47-63Hz) [Vrms]
24-280 Va
48-660 Va
Transient Voltage [Vpeak](2)(Random
version)
600
1200
(600)
(1600)
75A
50
75
100A
125A
100
125
Maximum Off-State Leakage Current @
Rated Voltage [mArms]
1
(Random version)
(5)
Minimum Off-State dV/dt @ Maximum
Rated Voltage [V/µsec]
500
1 Second Surge Current (Apk. Ta=25 °C)
50/60 Hz
45
100
125
230
347
613
Maximum 1 Cycle Surge Current (50/60 Hz)
[Apeak]
Typ @ 50 Hz
120/126
(min)
270/284
(min)
280/_ (min)
700/_ (min)
1100/_ (min)
2000/_
(min)
160 (typ)
340 (typ)
500 (typ)
750 (typ)
1200 (typ)
2100 (typ)
1.23
1.25
1.38
1.34
(1.08)
(1.37)
(1.37)
(1.34)
1.7
0.55
0.4
0.3
(0.7)
(0.7)
(0.4)
(0.3)
487/600
720/1250
2450/2800
6000/7200
(512/882)
(512/882)
(2450/2500)
(6000/7200)
1.3
2.08
0.84
0.52
(2.6)
(2.6)
(0.84)
(0.52)
Maximum On-State Voltage Drop @ Rated
Current [Vpeak]
(Random version)
1.2
Thermal Resistance Junction to Case
(Rjc) [°C/W]
(Random version)
2.3
Maximum 1/2 Cycle I² t for Fusing @ 50 Hz
(min. / typical) [A² sec]
(Random version)
78/128
Minimum Heat Sink for Rated Current
@ 40 °C [°C/W]
(Random version)
5.3
1.45
1.15
0.25
6000/7200
20000/
22000
0.23
0.29
Input Specifications
Description
Input Voltage Range
4-32 Vc
4-32 Vc (4)
18-36 Vz
18-36 Vz
Maximum Reverse Voltage
-32 Vc
N/A
Minimum Turn-On Voltage
3 Vc
18 Vz
20-265 Va
20-265 Va
90-260 Va
90-260 Va
90 Va
Must Turn-Off Voltage
1 Vc
5 Vz
5 Va
Minimum Input Current (for on-state)
10 mA
5 mA AC / 4 mA DC
6.5 mA
10 mA
Maximum Input Current [mA]
14 mA
Nominal Input Impedance [Ohms]
Current Limited
Maximum Turn-On Time [msec]
1/2 Cycle(5)
Maximum Turn-Off Time [msec]
1/2 Cycle
(5)
< 0.1
| | WWW.CROUZET.COM
|| 3
| | GN Series
| | 11/2020
General Specifications
Description
10A
25A
Dielectric Strength, Input to Output (50/60 Hz)
4000 Vrms
Dielectric Strength, Input/Output to Ground
(50/60 Hz)
2500 Vrms
Minimum Insulation Resistance (@ 500 Vc)
109Ω
Maximum Capacitance, Input/Output
0.8 pF
Ambient Operating Temperature Range
-40 to 80 °C
Ambient Storage Temperature Range
-40 to 100 °C
Weight (typical)
80 g
Housing Material
UL94 V-0
Baseplate Material
Aluminum
Input Terminal Screw Torque Range (in-lb/Nm)
11-18 /1.2-2.0
Load Terminal Screw Torque Range (in-lb/Nm)
18-26 / 2-3
SSR Mounting Screw Torque Range (in-lb/Nm)
11-16 /1.2-1.8
Humidity per IEC60068-2-78
40-85 %
LED Input Status Indicator
Green
MTBF (Mean Time Between Failures) at 40 °C
ambient temperature(5)(years)
72
MTBF (Mean Time Between Failures) at 60 °C
46
50A
75A
100A
125A
4000 Vrms
General Notes
(1)
All parameters at 25 °C unless otherwise specified
(2)
Output will self trigger between 450-600 Vpk not suitable for capacitive loads
(3)
Heat sinking required, see derating curves
(4)
Increase minimum voltage by 1 V for operations from -20 to -40 °C
(5)
All parameters at 50 % power rating and 100 % duty cycle (contact tech support for detailed report)
Diagrams
Wiring
GN
Recommended Wire Size
AC
V
TERMINALS
1
1 (a)
2 (a)
4 (-/a)
WIRE SIZE
SOLID
Load
Terminal Screw
Torque (N.m)
Input
18..14 AWG (0.75..2.5 mm²)
2 x 18..14 AWG (0.75..2.5 mm²)
1.2 - 2
Output
16..8 AWG (1.5..10 mm²)
2 x 16..8 AWG (1.5..10 mm²)
16..8 AWG (1.5..6 mm²)
2 x 16..10 AWG (1.5..6 mm²)
2-3
3 (+/a)
For the random (instantaneous) models, external overvoltage protection is recommended: TVS Diode
B
STRANDED
| | WWW.CROUZET.COM
|| 4
| | GN Series
| | 11/2020
Diagrams
Equivalent Circuit Block
Input current vs Input Voltage
GN Series 4-32 Vc control (Thyristors) - All out 660 Va
Standard Regulated DC inputs
Current Limiter
14
12
OUTPUT
10
Input Current (mA)
INPUT
8
6
4
2
4
6
8
10
12
14
16
18
24
26
28
30
32
24
26
28
30
32
Input Voltage (V)
GN Series 4-32 Vc control (Triac) - 10 A /25 A (280 Va)
Current Limiter
14
12
OUTPUT
10
Input Current (mA)
INPUT
8
6
4
2
4
6
8
10
12
14
16
18
Input Voltage (V)
GN Series 18-36 Vz control
Standard Regulated AC/DC inputs
Current Limiter
7
6
OUTPUT
Input Current (mA)
INPUT
5
4
3
2
1
60
80
100 120 140 160 180 200 220 240 260 280
Input Voltage (V)
GN Series 20-265 Va control
Standard Regulated AC inputs
Current Limiter
7
6
OUTPUT
Input Current (mA)
INPUT
5
4
3
2
1
60
80
Input Voltage (V)
| | WWW.CROUZET.COM
|| 5
| | GN Series
| | 11/2020
GN Series 4-32 Vc control instantaneous
Current Limiter
14
12
OUTPUT
10
Input Current (mA)
INPUT
8
6
4
2
4
6
8
10
12
14
16
18
24
26
28
30
32
Input Voltage (V)
GN Series 90-260 Va control instantaneous
Current Limiter
9
INPUT
8
OUTPUT
7
Input Current (mA)
6
5
4
3
2
1
60
80
100
120
140
Input Voltage (V)
Diagrams
Dimensions (mm)
GN front view
GN side view
28
2 M5
3
47,6
59,4
16,3
29,1
Ø4,7
44,5 (±0,3)
4,7
25,4
2 M4
160
180
200
220
240
260
| | WWW.CROUZET.COM
|| 6
| | GN Series
| | 11/2020
Curves
Surge Current Information
150
300
125
250
100
200
Itsm (Apeak)
GN - 25 A
Itsm (Apeak)
GN - 10 A
75
50
25
100
50
0,01
0,1
T (s)
1
0,01
No Repetitive Surge Current
GN - 75 A
800
1200
Itsm (Apeak)
Itsm (Apeak)
1
10
1
10
1
10
900
500
400
300
800
700
600
500
400
300
200
200
100
100
0,1
T (s)
1
10
0,01
0,1
T (s)
GN - 100 A
GN - 125 A
1200
2200
1100
2000
1000
1800
900
1600
800
Itsm (Apeak)
Itsm (Apeak)
10
1000
600
1400
700
1200
600
1000
500
400
800
600
300
200
400
100
200
0,01
0,1
T (s)
1
0,01
0,1
T (s)
GN - 25 A Instantaneous
GN - 50 A Instantaneous
350
800
300
700
600
Itsm (Apeak)
250
Itsm (Apeak)
1
1100
700
T (s)
GN - 50 A
200
150
100
500
400
300
200
50
100
0,1
T (s)
1
10
0,01
0,1
T (s)
| | WWW.CROUZET.COM
|| 7
| | GN Series
| | 11/2020
GN - 75 A Instantaneous
1200
1100
1000
Itsm (Apeak)
900
800
700
600
500
400
300
200
100
0,1
1
T (s)
10
Curves
Thermal Derating Curves
GN - 10 A
GN - 25 A
14
GN - 50 A
30
55
50
12
25
45
10
40
6
4
Current (Arms)
Current (Arms)
Current (Arms)
8
15
10
2
5
25
10
5
40
50
60
70
80
Ambient Temperature (°C)
5
30
3
3
2,2
2,2
2
C°/W
70
65
60
55
45
Current (Arms)
Current (Arms)
50
40
35
30
25
10
5
40
50
60
70
80
110
105
100
95
90
85
80
75
70
65
60
55
50
45
40
35
30
25
10
5
1,1
1
1,5
0,9
0,7
0,5
1,5
1,75
1,5
2
30
40
50
60
70
80
1,2
1,1
1
0,9
0,7
0,5
10
60
70
80
2
1,75
C°/W
1,1
0,9
1,75
2,2
40
50
60
70
80
1
0,9
0,7
0,5
0,3
55
50
45
25
40
35
30
25
10
5
40
50
60
70
80
1,5
0,9
60
2,2
0,7
65
30
1
70
5
50
80
75
10
5
70
80
Current (Arms)
15
60
35
Current (Arms)
Current (Arms)
C°/W
40
40
1,5
1,2
45
30
135
130
125
120
115
110
105
100
95
90
85
80
75
70
65
60
55
50
45
40
35
30
25
10
5
50
25
40
55
C°/W
30
10
C°/W
C°/W
GN - 125 A
1,75
70
Current (Arms)
75
10
60
GN - 100 A
80
C°/W
GN - 75 A
2
1,5
1
0,7
C°/W
0,9
40
50
60
70
80
1,75
2,2
1,75
1,5
1,2
C°/W
0,9
0,7
0,5
|| | WWW.CROUZET.COM
WWW.CROUZET.COM
|| |88
|| 1| 11/2020
0/2020
|| | GN
G N Series
Series
Standards Specifications
ZERO CROSS
IEC/EN61000-4-4 (bursts)
IEC/EN61000-4-5 (surge)
VIBRATION resistance IEC 60068-2-6
SHOCK resistance IEC 60068-2-27
2 kv crit B
2 kv crit B
10 g
50 G (11 ms)
RANDOM
ES16951
4 kv crit A
4 kv crit A
10 g
50 G (11 ms)
REG 10102*
* VDE ONLY 84137000N / 84137110N / 84137120N / 84137130N / 84137140N / 84137180N / 84137210N / 84137211N / 84137320N / 84137321N / 84137330N
Warning:
The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to
modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate
tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction
with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
