| | SWITCHES.CROUZET.COM
|| 1
| | MANUALLY OPER ATED SWITCHES
| | 12/2019
THUMBWHEEL / SELECTOR SWITCHES
8421
› Starwheel or pushwheel models
› Choice of output codes with 10 or 16 switching positions
› Snap-in front panel mounting for easy installation
› Range of standardized dimensions to fit most panel cutouts
› Large display characters for easy reading
› High reliability switching thanks to gold plated contacts
› Very long life
› Choice of mounting accessories: snap-in endcaps,
spacers and connectors
Main specifications
Starwheel
Miniature
84210
Pushwheel
Subminiature
84214
Pushwheel
Large
84212
Pushwheel
Miniature
84211
84212005
84212013
84212001
84212014
84212004
84212011
84212002
84212012
84212006
84212032
84212003
84212024
84211007
84211003
84211008
84211004
84211001
84211024
84211002
84211023
84211013
84211017
84211012
84211030
84214007
84214009
84214005
84214010
79211923
79211947
79211914
79211936
79211924
79211948
25625493
25625495
79211823
79211847
79211814
79211836
79211824
79211848
79214283
79214216
Output code
Switching Readout Code Circuit Case Wheel Connecpositions
tions
M02 C
G
N
S
84210005
M02 C
N
N
S
84210055
BCD
10
0-9
M02 L
G
N
S
84210006
M02 L
N
N
S
84210056
M01 C
G
N
S
84210003
M01 C
N
N
S
84210053
Decimal
10
0-9
M01 L
G
N
S
84210004
M01 L
N
N
S
84210054
M03 C
G
N
S
84210007
M03 C
N
N
S
84210057
BCD +
10
0-9
M03 L
G
N
S
complement
M03 L
N
N
S
84210058
BCD complement
10
0-9
M07 C, L
G, N N
S
84210408
M29 C
G
N
S
0-9, A-F
M29 C,L
G,N
N
S
BCH hexadecimal
16
84210409
M29 C
N
N
S
0-15
M29 C,L
G,N
N
S
Changeover
10
+/M04 C,L
G,N
N
S
S=solder or for connector
C=short G=grey
L=long N=black
Long circuits have track cuts for mounting of additional components in series
Mounting accessories
Pairs of end caps (with clips)
Spacers
Separators (with clips)
Connectors
For securing the block of modules
to the panel
Blank module for creating a space
or filling a gap
Blank module for joining and
securing two blocks
For quick connection and
disconnection of the module
79211709
79211759
79211738
79211745
79211752
79211760
grey
black
grey
black
grey
black
solder lugs
solder pins
Spacers and separators have same dimensions as switch modules. For an illustration, see “Examples of blocks” on last page.
Electrical characteristics
Rating nominal / 48 V AC/DC (A)
0.1
0.1
0.1
0.1
Operating range / 0.1 ➞ 48 V AC/DC (A)
0.0001 ➞ 0.1
0.0001 ➞ 0.1
0.0001 ➞ 0.1
0.0001 ➞ 0.1
Rating thermal (non-switchable) / 48 V AC/DC (A)
1
1
1
1
Digit height - 10 / 16 positions (mm)
4.5 / 2.8
6
4.5
4
Module width - pitch (mm)
8
12.5
10
7.6
Module height - cutout (mm)
31
54
31
22.5
Mounting depth - C / L circuits (mm)
37 / 47
37 / 47
37 / 47
32 / 42
Operating force (N)
3
4
5
5
Ambient operating temperature (° C)
-25 ➞ +70
-25 ➞ +70
-25 ➞ +70
-25 ➞ +70
Ambient storage temperature (° C)
-40 ➞ +85
-40 ➞ +85
-40 ➞ +85
-40 ➞ +85
Mechanical life (operations)
106
106
106
106
Weight (g)
5.5
14
7.5
4
Mechanical characteristics
Standard product
Product made to order
Contact us
cted to tracks
_ _ _
2 4 8 C
10 9 8 7
8 7 6 5
caon
|| 2
| | 12/2019
Additional specifications
- Degree of protection: IP40 (front face)
- Rated insulation voltage Ui: 48 V
- Max. internal resistance: 200 mΩ
- Min. insulation resistance: 105 MΩ
- Dielectric strength: 600 VAC between tracks
2500 VAC between tracks and external parts
- Vibration resistance: 10 g, 10 - 2000 Hz
- Actuator: POM (84210) ; transparent PC (84211/212/214)
- Case: PA66 GB (84210/84211/84212 grey); PPO (84212 black/84214)
- Sliding contacts: gold alloy
- PCB tracks and terminals: gold over nickel
- Mounting features: Assembly of modules through integrated pins
or clips.
Front mounting on panel ; fastening by the snap-in
endcaps.
- Certification marks:
Product adaptations
› Special codes: hexadecimal + complement (M28: 84210), Kelvin-Varley (M17: 84210/211/212), …
› Special circuits: long without track cuts, with overlap (make before break), ...
› Red wheel (R)
› Connections for PCB (X3): 0.6 x 0.5 x 5 tin-plated solder pins
› Lockout stops for restricting the setting range
Principles
Standard coding tables
M01
Decimal
Common C connected to tracks
0 1 2 3 4 5 6 7 8 9 C
2
3
Dial
4
seng
5
6
7
8
9
84210/211/212 11 10 9 8 7 6 5 4 3 2 12
84214 11 10 9 8 7 6 5 4 3 2 1
Terminal locaon
C conn. to
M04
Changeover 1 2 C
Dial
seng
84210/211/212 9 8 2
84214 3 7 5
Terminal locaon
2
3
Dial
4
seng
5
6
7
8
9
84210/211/212
84214
C connected to
_ _ _ _
1 2 4 8 C
2
3
Dial
4
seng
5
6
7
8
9
84210/211/212 4 11 2 10 3
84214 9 7 5 3 1
Terminal locaon
M07
BCD compl.
Other codes: please consult us
Curves
Electrical life for 82410, 84211, 84212 and 84214
48 Va /c 0.1 A 106 cycles
M02
BCD
C connected to
1 2 4 8 C
8 7 6 5 9
8 7 6 5 1
Terminal locaon
M29
BCH Hexadec.
2
3
4
5
6
Dial
7
seng
8
9
A/10
B/11
C/12
D/13
E/14
F/15
84210/211/212
_ _ _ _
1 2 4 8 1 2 4 8 C
2
3
Dial
4
seng
5
6
7
8
9
84210/211/212 6 5 4 3 11 10 9 8 7
84214 4 3 2 1 9 8 7 6 5
Terminal locaon
M03
BCD + compl.
C connected to
1 2 4 8 C
11 9 2 4 7
Terminal locaon
C conn. to
M04
Changeover 1 2 C
Dial
seng
84210/211/212 9 8 2
84214 3 7 5
Terminal locaon
s
8
|| 3
| | 12/2019
Dimensions
Products
84210
84211
Ø1
1
1
1
2
3
C
Ø1
2,54
1
2
3
12
12
0,8
0,8
L*
84212
84214
8
1
Ø1
1
2
3
12
18,5
pitch 2: for M01
pitch 5: for M02, M04, M07
pitch 2.5: for M03
0,8
L*
B Terminal location
* Long circuits have track cuts for mounting components in series, except for common C.
Hole spacings: 84210/211/212: 5.5, 8 and 10.5 mm
84214: 7.5 and 10 mm
B
Panel cutouts
84210
84211
84212
84214
A
(n+1) 8 + J
(n+1) 10 + J
(n+1) 12.5 + J
(nx7.62) + 3.5
B
31
31
54
22.5
A
n: number of modules
J: clearance: 1 mm for 1 ≤ n ≤ 10
1.5 m for 11 ≤ n ≤ 20
|| 4
Panel thickness
84210/211/212
| | 12/2019
84214
1➝4 mm
Clips have two mounting positions according to panel
thickness.
Connectors
Solder lugs
Solder pins
Installation recommendations
See “Basic technical concepts”
How to order
Use the 8 digit part numbers when they are defined
Other cases, precise:
Type of thumbwheel switch - Code - Circuit - Case - Wheel - Connections - Adaptation* + Mounting accessories* + Connector*
* if needed
Example: 84212 M07 L N N S + 79211947 + 25625493
Examples of blocks
2
3
4
1
2
2
1
3
4
2
1- Switch module
2- End caps
3- Spacer
4- Separator
Warning:
The product information contained in this catalogue is given purely as information and does not constitute a representation, warrantly or any form of contractual commitment.
Crouzet Automatismes SAS and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our
products and it is the responsability of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty
apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any
other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
很抱歉,暂时无法提供与“84210056”相匹配的价格&库存,您可以联系我们找货
