26231728
26231728
    CROUZET(高诺斯)
    CAPACITOR15UF5%
26231728 数据手册
Reversible synchronous geared motors ➜ 0.5 Nm 3.5 Watts ■ ■ ■ ■ Mechanical strength : 0.5 Nm Constant speed, dependent on supply frequency Wide range of speeds available Direction of rotation controlled by dephasing capacitor ■ Permanent magnet rotor ■ UL, CSA, VDE approved, comply with IEC standards Specifications Type Base speed of motor (rpm) Voltage / Frequency Output speed (250 RPM) Output speed (375 RPM) Ratios (i) 25.00 rpm 37.50 rpm 10 20.00 rpm 30.00 rpm 25/2 13.33 rpm 20.00 rpm 75/4 12.50 rpm 18.75 rpm 20 10.00 rpm 15.00 rpm 25 5.00 rpm 7.50 rpm 50 4.00 rpm 6.00 rpm 125/2 2.50 rpm 3.75 rpm 100 2.00 rpm 3.00 rpm 125 1.00 rpm 1.50 rpm 250 0.33 rpm 0.50 rpm 750 General characteristics Motor Gearbox Maximum permitted continuous rated gearbox output torque for 1 million revolutions of gearbox output shaft (Nm) Axial load static (daN) Radial load static (daN) Absorbed power (W) Motor output (W) Maximum temperature rise (oC) Ambient temperature (oC) Weight (g) Wires length mm (approximately) Protection rating 4 3.5 Watts 82 524 0 250 230-240 V - 50 Hz 3.5 Watts 82 524 4 375 230-240 V - 50 Hz 82 524 001 82 524 002 ● ● 82 524 003 82 524 004 82 524 008 82 524 010 ● ● ● ● ● ● ● ● ● ● 82 524 016 ● 82 520 0 81 021 0 0.5 82 520 4 81 021 0 0.5 1 8 3.5 0.98 50 -5 ➞ +70 140 250 IP40 1 8 3.5 1.12 50 -5 ➞ +70 140 250 IP40 Product adaptations ■ ■ ■ ■ ■ ■ ■ Special supply voltages Special cable lengths Special connectors Special output shafts Special gearbox ratios Special gear wheel material Special output bearing Curves Torque/speed curves 82 524 0 Torque/speed curves 82 524 4 mN.m 400 80 mN.m 500 400 300 200 150 100 80 60 40 500 300 200 150 100 60 40 1 2 3 4 5 8 6 B RPM To order, see page 13 122 15 10 25 20 30 75/2 1 2 3 4 5 8 6 B RPM 15 10 25 20 30 75/2 Accessories Voltages/Frequencies Capacitors for motor 82 520 0 230-240 V - 50 Hz 115 V 60 Hz 24 V - 50 Hz Capacitors motor 82 520 4 230/240 V - 50 Hz 115 V 60 Hz 24 V - 50 Hz 24 V - 60 Hz µF V Code 0.10 ± 10 % 0.33 ± 10 % 8.2 ± 10 % 700 400 70 26 231 941 26 231 801 26 231 711 0.12 ± 10 % 0.39 ± 5 % 15 ± 5 % 12 ± 5 % 600 630 70 63 26 231 903 26 231 924 26 231 728 26 231 145 Dimensions 82 524 0 - 82 524 4 4 3 1 2 B 2 fixing holes Ø 3.2 C Fixing clip D 3.5 across flat E pushed-in shaft Options Shaft 79 200 967 Shaft 79 200 779 1 1 B (pushed-in shaft ← ) B (pushed-in shaft ← ) 4 Shaft 70 999 421 SP1295-10 1 B 5 across flat Connections In parallel Motors 82 520 0 - 82 520 4 1 2 SA SI UN B SA : Clockwise C SI : Anti-clockwise Other information The speed of a motor powered by a 60 Hz supply is 20 % higher than that of a motor powered by a 50 Hz supply. 123 Reversible synchronous geared motors ➜ 2 Nm 3.5 Watts ■ ■ ■ ■ Machanical strength : 2 Nm Constant speed, dependent on supply frequency Wide range of speeds available Direction of rotation controlled by dephasing capacitor ■ Permanent magnet rotor ■ UL, CSA, VDE approved, comply with IEC standards Specifications Type Voltage / Frequency Base speed of motor (rpm) Output speed (250 RPM) Output speed (375 RPM) Ratios (i) 10.00 rpm 15.00 rpm 25 5.00 rpm 7.50 rpm 50 4.00 rpm 6.00 rpm 125/2 2.50 rpm 3.75 rpm 100 1.00 rpm 1.50 rpm 250 0.50 rpm 0.75 rpm 500 0.33 rpm 0.50 rpm 750 5.00 rev/hr 7.50 rev/hr 3000 General characteristics Motor Gearbox Maximum permitted continuous rated gearbox output torque for 1 million revolutions of gearbox output shaft Nm Axial load static (daN) Radial load static (daN) Absorbed power (W) Motor output (W) Maximum temperature rise (oC) Ambient temperature (oC) Weight (g) Wires length mm (approximately) Protection rating 4 3.5 Watts 3.5 watts 82 529 0 230-240 V - 50 Hz 250 82 529 4 230-240 V - 50 Hz 375 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 82 520 0 81 033 0 2.0 82 520 4 81 033 0 2.0 1 10 3.5 0.98 50 -5 ➞ +70 260 250 IP40 1 10 3.5 1.12 50 -5 ➞ +70 350 250 IP40 Product adaptations ■ ■ ■ ■ ■ ■ ■ Special supply voltages Special cable lengths Special connectors Special output shafts Special gearbox ratios Special gear wheel material Special output bearings Curves Torque/speed curves 82 529 0 Torque/speed curves 82 529 4 mN.m 800 mN.m 2000 1500 1000 800 600 400 300 200 1 100 1 5/6 B RPM To order, see page 13 126 15/2 2 15 5/2 5 20 10/3 25/2 2000 1500 1000 600 400 300 200 1 100 1 5/6 B RPM 15/2 2 15 5/2 5 20 10/3 25/2 Accessories Voltages/Frequencies Capacitors for motor 82 520 0 230-240 V - 50 Hz 115 V - 60 Hz 24 V - 50 Hz Capacitors for motor 82 520 4 230/240 V - 50 Hz 115 V - 60 Hz 24 V - 50 Hz 24 V - 60 Hz µF V Code 0.10 ± 10 % 0.33 ± 10 % 8.2 ± 10 % 700 400 70 26 231 941 26 231 801 26 231 711 0.12 ± 10 % 0.39 ± 5 % 15 ± 5 % 12 ± 5 % 600 630 70 63 26 231 903 26 231 924 26 231 728 26 231 145 Dimensions 82 529 0 - 82 529 4 1 4 2 3 5 4 B 2 fixing holes Ø 3.2 C Fixing clip D 5 across flat E (pushed-in shaft ← ) F 3 mounting bosses Ø 7.2 at 120° 4 on radius= 19.5 - 3 holes M3 depth 4 Options Shaft 79 202 573 2 1 B (shaft pushed-in ← ) C 5 across flat Connections In parallel Motors 82 520 0 - 82 520 4 1 2 SA SI UN B SA : clockwise C SI : anti-clockwise Other information The speed of a motor powered by a 60 Hz supply is 20 % higher than that of a motor powered by a 50 Hz supply. 127
26231728 价格&库存
很抱歉,暂时无法提供与“26231728”相匹配的价格&库存,您可以联系我们找货
