89830009
89830009
    CROUZET(高诺斯)
    US SHAFT - MOTOR 898300 - 90V 36
89830009 数据手册
MOTION OVERVIEW MOTORS & GEARMOTORS BRUSH BRUSHLESS SYNCHRONOUS STEPPER motors.crouzet.com ABOUT CROUZET The Motion product line provides innovative engineering expertise, high quality service and a complete offer of standard direct drives, geared motors and motion control solutions for applications where performance is key. Our ability to customize solutions as per virtually any customers’ request makes us the right partner to tackle the most demanding projects. Crouzet is a brand of InnoVista Sensors™. With a long-term commitment to technological excellence, the engineering teams have mastered the following core technologies and know-how: ››Electromagnetism ››Thermal dynamics ››Electromechanical systems ››Electronic drives Covering the power range from 1 to 1000 W peak (1/100 to 1HP+) and available with spur, worm or planetary gearboxes, plus adapted controllers, our offer is specifically designed for access control systems, pumps and valves, railway applications, electrical equipment, medical equipment and the industry. Designs & Manufactures InnoVista Sensors™ is a worldwide industrial specialist of sensors, controllers and actuators for automated systems. Through its brand Crouzet, InnoVista Sensors™ offers a wide range of reliable, efficient and customizable components dedicated to the Aerospace & Defense, Transportation and Industrial markets and segments. Thanks to the recognized expertise of its teams and a strong innovation policy, InnoVista Sensors™ brings performance enhancing solutions to its customers worldwide. InnoVista Sensors™: your trusted partner of choice to face industrial challenges of today and tomorrow. www.innovistasensors.com For Aerospace & Defense Transportation Industry MOTORS, CONTROL ELECTRONICS AND GEARBOXES CONTROL ELECTRONICS MOTORS 82830 82890 89800 10 50 89830 89890 80140 180 280 80350 60 70 82510 20 30 40 82340 82330 82910 20 30 40 0.9 / 3 9 ➞ 33 30 ➞ 95 15 ➞ 35 55 / 104 66 ➞ 170 310 ➞ 600 0.3 ➞ 3 0.2 / 0.4 0.5 ➞ 5 12 / 24 Vc 12 ➞ 48 Vc 12 ➞ 48 Vc 12 ➞ 48 Vc 12 ➞ 120 Vc 9 ➞ 75 Vc 9 ➞ 75 Vc 24 ➞ 240 Va 50 ➞ 60 Hz 24 ➞ 240 Va 50 ➞ 60 Hz 3 ➞ 64 Vc CHARACTERISTICS TNi21 Compatible models Speed-torque SMi21 SQ57 External SMi22 BDE 30 SQ75 SQ57 ● Position (c/t) 4096 4096 Ø 47 Ø 35 / 51 Ø 57 / 65 Programming DCmind Soft & DCmind Soft + CANopen DCmind Soft + CANopen Communication bus Optional Standard 10 ➞ 36 Vc 9 ➞ 75 Vc 9 ➞ 75 Vc 18 ➞ 36 Vc 10 ➞ 36 Vc 17 17 75 10 14 Front side (mm) Ø 32 Ø 42 Ø 63 Ø 42 Ø 63 SQ57 SQ75 Nominal speed (rpm) 3700 3000 3000 3000 3000 3000 3000 250 - 600 600 / 720 0 - 1500 2.2 / 7.7 41 ➞ 100 170 / 270 50 ➞ 110 180 / 290 125 ➞ 550 830 ➞ 1900 10 ➞ 110 2.5 ➞ 8 15 ➞ 300 Voltage Maximum current (A) Noise level (dBA) 55 55 55 35 35 45 50 30 45 35 Service life (hrs) 2000 3000 5000 4000 5000 20000 20000 20000 10 M on / off 20000 Adaptations ● BDE 40 ● Ø 35 / 51 Ø 57 / 65 Nominal torque (mNm) Integrated Stepper 82800 10 50 Nominal power (W) Voltage Synchronous 82840 82860 Series CHARACTERISTICS DCmind Brushless Series DCmind Brush Industrial Brush ● ● PWM or 0 ➞ 10 VDC Programs: Custom firmware as per customer specifications GEARBOXES Parallel shafts Planetary Worm 10 models 7 models 2 models Torque (Nm) 0.5 ➞ 6 0.8 ➞ 120 10 ➞ 20 Power (W) 0.2 ➞ 50 8 ➞ 600 25 ➞ 600 1 ➞ 10 50 50 4 ➞ 4500 4 ➞ 308 5 ➞ 100 Certification Gearboxes Connection CHARACTERISTICS Standard Options Service life (Mt*) IP IP20 IP65* IP54 IP65*, IP67* IP69* Ratios IP40 * Except front face & shaft IP30 IP40 Options Shafts: stainless steel, pulleys, pinions, special bearings etc. * Million revolutions LEGENDE EMC filter Worm Ball bearing Interchangeable brushes Planetary Parallel shaft Silent Connector Cable Lead Terminal Optional regenerative energy absorber ACCESSORIES & OPTIONS ADAPTED PRODUCTS All our motor ranges can be accompanied by factory-mounted encoders and mechanical brakes: To meet your expectations, Crouzet offers you custom products matching your requirements, in the following areas: ››Brakes from 0.25 N.m to 4.5 N.m ››Encoders from 1 to 3600 points/rev ››Special connectors ››Special output shaft ››Control electronics ››Motor characteristics ››Gearboxes ››IP65, IP67, IP69 ›› ADAPTATION WHEEL To meet market expectations and provide customers with the right solutions within the shortest timeframes, Crouzet has structured all company processes around the different types of product: standard products, adapted products or products specially developed for a customer. Introducing the adaptation wheel... SPECIAL PRODUCTS STANDARD PRODUCTS When the adaptation is no longer suitable, we focus our design, manufacturing and qualification expertise on developing a new product designed to meet your requirements. We offer a full range of motors and geared motors, including AC synchronous, brush and brushless DC and stepper motors. Our products are available immediately so you can quickly implement your projects. 1 4 PRODUCTS WITH ADDED VALUE ADAPTED PRODUCTS All our standard products can be complemented by factory-installed extras, accessories or programs including connectors, special contacts, software etc., to assist integration into your equipment, simplify your logistics and maximize the reliability of your installations. All projects are different, so we adapt the performance and functionality of each product to your requirements, ensuring the success of your most complex applications. 3 2 ACTUAL EXAMPLES Releasable linear actuator for gas boilers equipped with a stepper motor: ››Gas flow adjustment ››Automatic closing in the event of a power failure ››Gas-tightness measured on the production line Gear pump equipped with a brushless motor: ››Rotor with leak tight seal ››Application-specific electronics ››Shortened motor Brushless motor with integrated electronics for Access Control in public transportation applications: ››Autonomous torque, speed and position control ››Specific firmware with integrated emergency mode ››Reinforced gearbox ››CANopen communication ››High resistance against vandalism AUTOMATION & CONTROL MOTION AMERICAS EUROPE / MIDDLE EAST / AFRICA ASIA / PACIFIC CANADA BELGIUM SWITZERLAND CHINA Tel.: +1 (855) 929-5465 americas.custserv@crouzet.com Tel.: +32 (0) 2 620 06 05 Fax: +32 (0) 2 461 00 23 klantenservice@crouzet.com Tel.: +41 (0) 225 67 57 90 Fax: +41 (0) 565 88 02 75 kundenservice@crouzet.com Tel.: +86 (21) 8025 7166 Fax: +86 (21) 6107 1771 china@crouzet.com MEXICO FRANCE THE NETHERLANDS INDIA Tel.: +1 (855) 929-5465 americas.custserv@crouzet.com Tel.: +33 (0) 475 802 101 Fax: +33 (0) 475 828 900 relationclient@crouzet.com Tel.: +31 (0) 20-654 52 20 klantenservice@crouzet.com Tel.: +91 (80) 6762 4501/500 india@crouzet.com USA GERMANY / AUSTRIA UNITED KINGDOM SOUTH KOREA +1 (855) 929-5465 americas.custserv@crouzet.com Tel.: +49 (0) 2103/9385930 Fax: +49 (0) 2103/980-222 kundenservice@crouzet.com Tel.: +44 (0) 2076 600 025 customer.relation@crouzet.com Tel.: +82 (2) 2679 8312 Fax: +82 (2) 2679 9888 korea@crouzet.com COUNTRIES NOT LISTED ITALY COUNTRIES NOT LISTED EAST ASIA PACIFIC +1 (855) 929-5465 americas.custserv@crouzet.com Tel.: +39 (02) 38 594 099 Fax: +39 (02) 82 952 104 assistenzaclienti@crouzet.com Tel.: +33 (0) 475 802 102 Fax: +33 (0) 475 828 900 customer.relation@crouzet.com Tel.: +86 (21) 8025 7177 Fax: +86 (21) 6107 1771 eap@crouzet.com Tel.: +34 (91) 215 80 95 Fax: +34 (93) 2 20 02 05 atencionalcliente@crouzet.com Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet Automatismes SAS and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products. motors.crouzet.com www.innovistasensors.com Ref.: 67523001C EN | 01/2019 - Photos: Ginko SPAIN / PORTUGAL
89830009 价格&库存
很抱歉,暂时无法提供与“89830009”相匹配的价格&库存,您可以联系我们找货
  • 1+1376.97171
  • 3+1311.52311
  • 10+1251.81774
  • 24+1197.42032
  • 70+1147.50866
库存:76
