Din Rail Mount
DataSheet
CKR24 Series
• Rating from 10A to 30A @ 280VAC
• Slim 22.5mm (width) package
• SCR output for heavy industrial loads
• LED input status indicator
• AC or DC control
• Zero-crossing (resistive loads) or Instantaneous-fire (inductive loads) output
PRODUCT SELECTION
Control Voltage
10A
20A
30A
4-32 VDC Control
110-280 VAC Control
90-140 VAC Control
18-36 VAC Control
CKRD2410
CKRA2410
CKRB2410
CKRA2410E
CKRD2420
CKRA2420
CKRB2420
CKRA2420E
CKRD2430
CKRA2430
CKRB2430
CKRA2430E
AVAILABLE OPTIONS
Series
CKR
Control Voltage
D: 4-32 VDC
B: 90-140 VAC
A: 110-280 VAC
AxxxxE: 18-36 VAC
D
24
Overvoltage Protection
Blank: Not Included
P: Included
10
E
Rated Load Current
Operating
10: 10 Amps
Voltage
24: 24-280 VAC 20: 20 Amps
30: 30 Amps
P
-10
Switching Type
Blank: Zero Voltage Turn-On
-10: Instantaneous Turn-On
Required for valid part number
For options only and not required for valid part number
OUTPUT SPECIFICATIONS (1)
Description
Operating Voltage (47-63Hz) [Vrms]
Transient Overvoltage [Vpk]
Maximum Off-State Leakage Current @ Rated Voltage [mArms]
Minimum Off-State dv/dt @ Maximum Rated Voltage [V/µsec] (2)
Maximum Load Current [Arms]
Minimum Load Current [Arms]
Maximum Surge Current (16.6ms) [Apk]
Maximum On-State Voltage Drop @ Rated Current [Vpk]
Maximum I² t for Fusing (8.3 msec) [A² sec]
Minimum Power Factor (with Maximum Load)
Do not forget to visit us at: www.crydom.com
10A
20A
30A
24-280
600
10
500
10
0.15
120
1.6
60
0.5
24-280
600
10
500
250
1.6
260
0.5
24-280
600
10
500
30
0.15
1200
1.6
6000
0.5
Copyright © 2013 Crydom Inc. Specifications subject to change without notice.
Din Rail Mount
DataSheet
INPUT SPECIFICATIONS (1)
Description
Control Voltage Range
Minimum Turn-On Voltage
Minimum Turn-Off Voltage
Typical Input Current (4)
Maximum Turn-On Time [msec] (3)
Maximum Turn-Off Time [msec]
CKRD24xx
CKRA24xx
CKRB24xx
CKRA24xxE
4.0-32 VDC
4.0 VDC
1.0 VDC
8-12 mA
1/2 Cycle
1/2 Cycle
110-280 Vrms
110 Vrms
10 Vrms
5 mA @ 240 Vrms
10
40
90-140 Vrms
90 Vrms
10 Vrms
5 mA @ 120 Vrms
10
40
18-36 Vrms
18 Vrms
4.0 Vrms
10 mA @ 24 Vrms
10
40
GENERAL SPECIFICATIONS
Description
Parameters
Dielectric Strength, Input/Output/Base (50/60Hz)
Minimum Insulation Resistance (@ 500 V DC)
4000Vrms
10 9 Ohms
8 pF
-40ºC to 80ºC
-40ºC to 125ºC
Green LED
10 oz. (280g)
Thermally Conductive Epoxy
Box Clamp Type
AWG # 10 (3mm)
5.0-6.0 in lb (0.6-0.7 Nm)
0.8 inch (20mm)
Maximum Capacitance, Input/Output
Ambient Operating Temperature Range
Ambient Storage Temperature Range
Status Indicator Display
Weight (typical)
Encapsulation
Terminals
Maximum Wire Size:
Recommended Terminal Screw Torque Range:
Min. Side by Side Spacing
GENERAL NOTES
1) All parameters at 25°C unless otherwise specified.
2) Off-State dv/dt test method per EIA/NARM standard RS-443, paragraph 13.11.1
3) Turn-on time for DC control instantaneous turn-on versions is 0.02 msec
4) Input circuitry for DC control version incorporates active current limiter.
MECHANICAL SPECIFICATIONS
MOUNTING
HOLE/SLOT
0.17 (4.3) DIA.
4/A2
All dimensions are in inches (millimeters)
TU
IN P
U
S
+3/A1
T ST A
CKR SERIES
SOLID STATE
CONTACTOR
2.6
(66.0)
3.2
(81.9)
3.5
(88.9)
OUTPUT
1/L1
2/T1
.5
(12.7)
.890
(22.5)
3.2
(81.3)
Current Rating 20A @ 25°C
30
(99.0)
40
60
80
Caution
High Temperature
HEAT SINK:
BLACK ANODIZED
ALUMINUM
Din Rail Mount
DataSheet
WIRING DIAGRAM
AC control
AC 4
1 AC
AC/DC
Converter
Current
Limiter
Trigger
Circuit
AC 3
2 AC
* With Option “P” suffix
DC control
-DC 4
1 AC
Trigger
Circuit
+DC 3
2 AC
Current
Limiter
THERMAL DERATE INFORMATION
30
CKRX2430
OUTPUT CURRENT (Arms)
25
CKRX2420
15
10
CKRX2410
5
AMBIENT TEMPERATURE (°C)
60
80
AGENCY APPROVALS
Designed in accordance with the requirements of IEC 62314
E116949
Rev. 121113
Din Rail Mount
DataSheet
DANGER / PELIGRO / DANGER /GEFAHR / PERICOLO / 危险
HAZARD OF
ELECTRIC
SHOCK,
EXPLOSION,
OR ARC FLASH.
• Disconnect all
power before
installing or
working with
this equipment.
• Verify all
connections
and replace all
covers before
turning on
power.
Failure to follow
these
instructions will
result in death
or serious injury.
RIESGO DE
DESCARGA
ELECTRICA O
EXPLOSION.
• Desconectar
todos los
suministros de
energia a este
equipo antes
de trabajar
con este equipo.
• Verificar todas
las conexiones
y colocar todas
las tapas antes
de energizer
el equipo.
El
incumplimiento
de estas
instrucciones
puede provocar
la muerte o
lesiones serias.
RISQUE DE
DESCHARGE
ELECTRIQUE
OU EXPLOSION
• Eteindre
toutes les
sources
d'énergie de
cet appareil
avant de
travailler
dessus de cet
appareil
• Vérifier tous
connections, et
remettre tous
couverts en
olace avant de
mettre sous
De non-suivi de
ces instructions
provoquera la
mort ou des
lésions sérieuses
sérieuses.
GEFAHR EINES
ELEKTRISCHE
N SCHLAGES
ODER EINER
EXPLOSION.
• Stellen Sie
jeglichen
Strom ab, der
dieses Gerät
versorgt, bevor
Sie an dem
Gerät Arbeiten
durchführen
• Vor dem
Drehen auf
Energie alle
Anschlüsse
überprüfen
und alle
Abdeckungen
ersetzen.
Unterlassung
dieser
Anweisungen
können zum
Tode oder zu
schweren
Verletzungen
führen.
RISCHIO DI
SCOSSA
ELETTRICA O
DELL’ESPLOSI
ONE.
• Spenga tutta
l'alimentazion
e che fornisce
questa
apparecchiatu
ra prima del
lavorare a questa
apparecchiatu ra
存在电击、
爆炸或电弧
闪烁危险
在操作此设
备之前请先
关闭电源。
若不遵守这些说明,
可能会导致严重的
人身伤害甚至死亡。
• Verificare tutti
i collegamenti
e sostituire
tutte le coperture
prima della
rotazione
sull'alimentazi one
L'omissione di
seguire queste
istruz ioni
provocherà la
morte o di
lesioni serie
WARNING / AVERTISSEMENT / WARNUNG /ADVERTENCIA / AVVERTENZA / 警告
RISK OF MATERIAL DAMAGE AND HOT
ENCLOSURE
RISQUE DE DOMMAGE MATERIEL ET DE
SURCHAUFFE DU BOITIER
GEFAHR VON MATERIALSCHÄDEN UND
GEHÄUSEERHITZUNG
• The product's side panels may be hot, allow
the product to cool before touching.
• Follow proper mounting instructions including
torque values.
• Do not allow liquids or foreign objects to enter
this product.
• Les panneaux latéraux du produit peuvent être
chauds. Laisser le produit refroidir avant de le
toucher.
• Respecter les consignes de montage, et
notamment les couples de serrage.
• Ne pas laisser pénétrer de liquide ni de corps
étrangers à l'intérieur du produit.
• Die Seitenwände können heiß sein. Lassen Sie
das Produkt abkühlen, bevor Sie es berühren.
• Beachten Sie die Montageanweisungen,
• Führen Sie keine Flüssigkeiten oder
Fremdkörper in das Produkt ein.
Le non-respect de cette directive peut entraîner,
Failure to follow these instructions can result in des lésions corporelles graves ou des
serious injury, or equipment damage.
dommages matériels.
Die Nichtbeachtung dieser Anweisung kann
Körperverletzung oder Materialschäden
zur Folge haben.
RIESGO DE DAÑOS MATERIALES Y DE
SOBRECALENTAMIENTO DE LA UNIDAD
RISCHIO DI DANNI MATERIALI E D'INVOLUCRO
CALDO
材料损坏和高温外壳的危险性
• Los paneles laterales del producto pueden
estar calientes. Esperar que el producto se
enfríe antes de tocarlo.
• Respetar las instrucciones de montaje, y en
particular los pares de apretado.
• No dejar que penetren líquidos o cuerpos
extraños en el producto.
• I pannelli laterali dell'apparecchio possono
scottare; lasciar quindi raffreddare il prodotto
prima di toccarlo.
• Seguire le istruzioni di montaggio corrette.
• Non far entrare liquidi o oggetti estranei in questo
apparecchio.
Si no se respetan estas precauciones pueden
producirse graves lesiones, daños materiales.
La mancata osservanza di questa precauzione può
causare gravi rischi per l'incolumità personale o
danni alle apparecchiature.
• 产品的一侧面板可能很热,在其冷却前请
不要触碰。
• 遵照正确的安装说明,包括扭矩值。
• 请勿让液体及其他异物进入本产品。
如不能正确执行这些操作说明,
极有可能造成严重人体伤害或者设备的损坏。
Din Rail Mount
DataSheet
ANNEX - ENVIROMENTAL INFORMATION
The environmental information disclosed in this annex including the EIP Pollution logo are in compliance with People’s Republic of China
Electronic Industry Standard SJ/T11364 – 2006, Marking for Control of Pollution Caused by Electronic Information Products.
Part
Name
Toxic or hazardous Substance and Elements
Lead
(Pb)
Mercury
(Hg)
Cadmium
(Cd)
Hexavalent
Chromium
(Cr (VI))
Polybrominated
biphenyls
(PBB)
Polybrominated
diphenyl ethers
(PBDE)
Semiconductor die
Solder
附件 - 环保信息
此附件所标示的包括电子信息产品污染图标的环保信息符合中华人民共和国电子行业标准 SJ/T11364 - 2006,
电子信息产品污染控制标识要求。
部件
名称
铅
汞
镉
有毒有害物质或元素
六价铬
多溴联苯
(Pb)
(Hg)
(Cd)
(Cr (VI))
半导体芯片
焊接点
50
(PBB)
多溴二苯醚
(PBDE)
很抱歉,暂时无法提供与“CKRD2410”相匹配的价格&库存,您可以联系我们找货
