02/11/2015
www.crouzet.com
0.5 Nm RPT5 3.9 Watts 3.9 W Part number made to order
Torque rating of gearbox : 0.5 Nm, sintered metal gears
Motors : nominal power 3 W, interference suppression for standard stocked products
Speed range : 1 to 895 rpm
Optional encoder built into the motor
Part numbers
82862002
Type
Type
Voltage
Output speed (rpm)
Ratios (i)
3.9 W
828620/2
12 V
140
30,5
Specifications
General characteristics
Motor
Gearbox
Maximum permitted torque from gearmotor under
continuous conditions for 1 million turns (Nm)
Axial load static (daN)
Radial load static (daN)
Max. output power (W)
Nominal output (W)
Gearbox case temperature rise (°C)
Weight (g)
828600
810120 / 810122
0,5
1
8
3,9
3
50
160 / 170
Made to order products, available on request
Motors :
- other supply voltages
- motors with 2 ball bearings
- shaft lengths at front and/or rear
- connection by radial tags or leads
- specific interference suppression
- encoder : 5 pulses per revolution
Gearboxes :
- special shaft, no flat/length
- ball bearings
- special fixings
- other reduction ratios
- special lubrication
Dimensions (mm)
828620
No
Legend
4 across flats
Shaft pushed-in
2 standard tags NFC 20-120, series 2.8 x 0.5 mm
3 holes M3 depth 4.5 mm
Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
02/11/2015
www.crouzet.com
Dimensions (mm)
828622
No
Legend
4 across flats
Shaft pushed-in
Curves
Curve : torque/nominal speed
No
Legend
rpm
Product adaptations
Special supply voltage
Lead output
1 or 5 pulse Hall effect encoder
Special connectors
Special shaft
02/11/2015
www.crouzet.com
Special reduction ratio
Special materials for pinion
Special ball bearings
Special adaptor plate
EMC filter
With shorter 1 W motor
很抱歉,暂时无法提供与“82862002”相匹配的价格&库存,您可以联系我们找货
