79215835
79215835
    CROUZET(高诺斯)
    "D" ACT PLAN R=60 FOR 161
79215835 数据手册
Subminiature Switches Series 83 132 / 83 133 / 83 134 Types General specifications Layout - The NO and NC circuits must both be of the same polarity. Features Components Material - Case : glass filled polyamide - Contacts : silver - Terminals: copper-nickel Actuator - Plain : stainless steel - roller: nylon Accessories : stainless steel Electrical characteristics Current rating at 125-250 V Operating force - max. Release force min. Overtravel max. - force Maximum rest position Tripping point Movement differential Overtravel - min. Operating temperature Mechanical life Contact gap Weight Number of operations { A A Mechanical characteristics Operating curve Resistive circuit: Inductive circuit Nominal Thermal L = 5 ms R cos ϕ = 0.8 Mechanical life N (oz) N (oz) N (oz) mm (in) mm (in) mm (in) mm (in) °C (°F) Operations mm (in) g (oz) Contact Type C (Form C) SPDT-DB Connections 83 132 : solder connection -1- only 83 133 : solder connection -1- only 83 134 : printed circuit board -2- only Rating in Amps Actuators and mounting positions-Factory Mounted Only Part numbers for standard actuators Actuators-Length mm (in) Tripping point Operating force max. Release force min. Pre-travel - max. Movement differential Total travel max. mm (in) N (oz) N (oz) mm (in) mm (in) mm (in) Part numbers for standard actuators Approvals UL (E42016), CSA (LR - 20918) for others, please consult us. Actuators-Length mm (in) Tripping point Operating force - max. Release force - min. Pre-travel - max. Movement differential Total travel max. mm (in) N (oz) N (oz) mm (in) mm (in) mm (in) Other information Also available: 1) Bi-stable operation 2) NC or NO contacts 3) Custom Actuators Please consult us for other actuators. Normally stocked items Catalog products produced to order Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/2 1 83 132 0 83 133 0 83 134 0 Side terminals Base terminals Face terminals 5 11 5 11 5 11 1.6 (5.6) 0.4 (1.4) 10 (35.3) 8.45 (.33) 7.7±0.2 (.30-.008) 0.45 (.018) 0.3 (.012) -20 +125 (-4 to +257) 107 0.3 x 2 (.012 x 2) 1.8 (.06) 1.6 (5.6) 0.4 (1.4) 10 (35.3) 8.45 (.33) 7.7±0.2 (.30-.008) 0.45 (.018) 0.3 (.012) -20 +125 (-4 to +257) 107 0.3 x 2 (.012 x 2) 1.8 (.06) 1.6 (5.6) 0.4 (1.4) 10 (35.3) 8.10 (.32) 7.35±0.25 (.29-.010) 0.45 (.018) 0.3 (.012) -20 +125 (-4 to +257) 107 0.3 x 2 (.012 x 2) 1.8 (.06) 2 C C C 3 3 2 for printed 1 solder tags can accept quick circuit boards connects .11˝ x .02˝ 4 L 70 514 175 C 70 514 194 E 70 514 181 Flat 54A R14.75 (.58) Flat 54A R35.75 (1.41) 83 132 0 83 133 0 83 132 0 83 133 0 83 134 0 9.5 ±0.8 (.374 ±.031) 9.2±0.8 (.362 ±.031) 0.18 (.6) 0.16 (.5) 2.15 (.085) 1±0.3 (.04±.001) 2.8 (.11) B 70 514 559 Simulated Roller 54B R13.7 (.54) 83 132 0 83 133 0 A 12.7 ±0.8 (.5 ±.03) 12.4±0.8 (.49 ±.03) 0.85 (3) 0.18 (.6) 2.05 (.081) 0.95±0.3 (.037±.001) 2.7 (.106) Tip-mounted in-line roller 54E R7.5 (.3) 83 134 0 10 ±1.5 (.413 ±.06) 9.7±0.15 (.382 ±.06) 0.34 (1.2) 0.06 (.2) 5.15 (.203) 2.1±0.65 (.083±.026) 6.8 (.268) 70 514 131 Flat 54A R7.75 (.30) 83 132 0 83 133 0 83 134 0 F 70 514 182 83 134 0 8.2 ±0.3 (.32 ±.01) 7.9±0.3 (.31 ±.01) 1.55 (5.45) 0.3 (1.05) 1.1 (.04) .5±0.15 (.02±.006) 1.5 (.06) 83 132 0 83 133 0 83 132 0 83 133 0 83 134 0 14.2 ±0.3 (.56 ±.012) 13.9±0.3 (.547 ±.012) 1.6 (5.6) 0.32 (1.1) 1.1 (.043) 0.5±0.15 (.02±.006) 1.45 (.057) G 70 514 183 Tip-mounted in-line roller 54E R34.4 (1.35) 83 132 0 83 133 0 Tip-mounted in-line roller 54E R14.1 (.56) 83 134 0 15.5 ±0.8 (.61 ±.031) 15.2±0.8 (.6 ±.031) 0.8 (2.8) 0.17 (.6) 2.05 (.081) 0.95±0.3 (.037±.001) 2.7 (.106) Ø No Actuator 83 134 0 16.1 ±1.4 (.63 ±.05) 15.8±1.4 (.62 ±.05) 0.34 (1.19) 0.07 (.25) 4.9 (1.9) 2±0.6 (.08±.02) 6.6 (.26) Except where otherwise indicated, the actuator is mounted in the position shown in the dimensional drawings (= standard mounting). To order please specify : 1 Switch Type 831320 831330 831340 Example : 831330 C 1 • A L Connection Actuators 1 A 2 B C Example P/N is 831330, SPDT-DB, solder terminals, A actuator mounted on the left. E 2 Contact Type C 3 4 F G Ø L 5 Actuator Position L - Left (Standard) R - Right Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/3 Subminiature Switches Dimensions 83 133 0 83 132 0 83 134 0 = 2.1 0.02 0.05 (.08 0.007 0.02 ) + _ 2.45 (.1) 1 (.04) OL = + _ 2.1 (.08) 1.5 (.06) 7 (2.8) 18.4 (.72) 1 2 tabs 0.7 (.03) 15.24 (.6) 3.6 (.37) 18.1 (.71) 6.4 (.25) 7.6 (.3) 6.4 (.25) 3.2 (.12) 6.4 (.25) 0.6 (.02) 01.5 (.06) 01.5 (.06) 4 (.16) OL fl 1.5 x .7 (fl .06 x .03) 9.3 (.37) + _ + _ 2.1 0.15 (.08 0.006 ) 7.4 (2.9) 5.08 (.2) 7.05 (.28) 3.9 (.15) 10 (3.9) = 03 (.12) 20.4 (.80) 0.6 x 0.5 (.023 x .02) mm(in) Connections 1 2.4 (.09) 2.2 (.08) 2.8 x .0.5 (.11 x .02) 1.2 (.05) 32.8 (1.29) 0.75 (.3) 0.5 (.02) = = 4 7.9 (.31) 9.3 (.37) 9.3 (.37) 1.2 (.05) 4.4 (.17) .82 (.32) 2.2 (.09) 2.42 (.10) 2.1 (.08) 2 R 0.5 (.02) 0.5 (.02) 0.6 x 5.5 (.023 x .02) 2.8 (.11) 2.8 (.11) mm(in) Actuators E 70514181 F 70514182 G 70514183 R=7.5 (.3) R=14.1 (.56) R=34.4 (1.35) F R1.2 (.05) 3.9 (.15) x3 2) 0.5 2x.1 (. Ø5x3 (.2x.12) R 2.1 (.08) R R 70° F 6.9 (.27) = 2.1 (.08) (.27) 6.9 = F R=13.7 (.54) 4.6 (.18) (.47) 12 B 70514559 (0.5x3) .2x.12 Standard mounting A 70514131 R=7.75 (.30) L 70514175 R=14.75 (.58) C 70514194 R=35.75 (1.41) 2.5 (.10) mm(in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/4 3.2x4.2 ) (.125 x .165 Subminiature Switches Actuators and mounting positions – Factory Mounted Only – for Gang Operation Part numbers for standard actuators – Consult factory for part number Actuators-Length mm (in) 3 pole 54A3 R30 (1.18) 2 pole 54A2 R30 (1.18) 83 132 0 83 133 0 Tripping Point Operating Force max Release Force min Pre-travel min Movement differential Total travel max mm (in) N (oz) N (oz) mm (in) mm (in) mm (in) *83 134 0 83 132 0 83 133 0 Side mounting plate (0.4 mm) 54Y *83 134 0 8.8±0,8 (.346±0.03) 1.2 (4.2) 0.24 (.8) 4.3 (.17) 2±0.55 (.08±0.02) 8.8±0,8 (.346±0.03) 0.8 (2.8) 0.16 (.6) 4.3 (.17) 2±0.55 (.08±0.02) Delivered separately *For gang operation with 83 132 0 or 83 133 0. 5.75 (.23) 5.75 (.23) Actuators – For Gang Operation 54A3 54A2 0.5 (0.2) 9.2 (.36) 19.2 .76 (.76) R 9.2 (.36) 12.8 (.5) 3 mm(in) Mounting accessories 83 132 0 - 83 133 0 83 134 0 6 (.24) 5.8 (.23) 6.9 (.26) 6.6 (.26) 1.6 (.063) mm(in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/5 Subminiature Switches Series 83 170 DIN 41 635 B General specifications Layout Types Components Material - Case : polyester UL 94 VO - Button : glass-filled polyamide - Contacts : AgNi, gold-plated AgNi (dual-current) - Terminals : copper-nickel Actuators - flat : stainless steel - roller : stainless steel with polyamide roller Approvals: NF - UL - cUL Operating curve For type 83 170 0 Number of operations Resistive circuit: Inductive circuit 1 2 3 Features Electrical characteristics Current rating at 250 V Nominal Thermal A A Mechanical characteristics For type 83 170 4 Number of operations { Part numbers for standard products (no lever) terminal type c L = 5 ms R a cos ϕ = 0.8 Mechanical life Resistive circuit: Inductive circuit { c L = 5 ms R a cos ϕ = 0.8 Mechanical life Operating force - max. Release force - min. Total travel force - max. Permitted overtravel force - max. Maximum rest position Tripping point Differential travel Overtravel - min. Ambient operating temperature Mechanical endurance Contact gap Weight N (oz.) N (oz.) N (oz.) N (oz.) mm (in.) mm (in.) mm (in.) mm (in.) °C Operations mm (in.) g (oz.) Contact type Rating in Amps Rating in Amps C (Form C) SPDT B (Form B) SPNC not available in PC terminals A (Form A) SPNO not available in PC terminals Connections For type 83 170 9 Number of operations Resistive circuit: Mechanical life Actuators and mounting positions Rating in Amps Part numbers for standard actuators Actuators – Length mm (in.) Mounting positions Coefficient Tripping point mm (in.) Mounting positions Model 83 170 9 is designed to operate equally well on dual-current (1 mA 4 V minimum) or medium-current (5 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life. Except where otherwise indicated, actuators are supplied unmounted. For factory mounting, specify mounting position L or R. – To calculate force : take the force quoted for the switch and divide by the coefficient given in the table. – To calculate travel : take the travel quoted for the switch and multiply by the same coefficient. Mounting accessories for PCB mounting: 5 / 6 / 7 / 8 See page 3/9. Other information For other forces, actuators, connections and temperatures, please consult us. Normally stocked items Catalog products produced to order Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/6 1 83170.0 831700C1.0 831700C2.0 831700C3.0 83170.4 831704C1.0 831704C2.0 831704C3.0 83170.9 831709C1.0 831709C2.0 831709C3.0 83170.4 SP 4967 831704C2.MBSP 831704C3.MBSP 831704C1.MBSP 83170.4 831704C1.MB 831704C2.MB 831704C3.MB 83170.9 831709C1.MB 831709C2.MB 831709C3.MB High current Standard Low current High force Standard Low current 10 12.5 5 6 0.1 5 6 5 6 0.1 1.5 (5.3) 0.3 (1) 1.8 (6.3) 10 (35.3) 9.2 (.36) 8.4±0.3 (.33±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 107 0.4 (.016) 1.7 (.06) 0.6 (2.2) 0.1 (.04) 1 (3.5) 10 (35.3) 9.2 (.36) 8.4±0.3 (.33±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 3.107 0.4 (.016) 1.7 (.06) 0.6 (2.2) 0.1 (.04) 1 (3.5) 10 (35.3) 9.2 (.36) 8.4±0.3 (.33±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 3.107 0.4 (.016) 1.7 (.06) 1.5 (5.3) 0.3 (1) 1.8 (6.3) 10 (35.3) 10.8 (.425) 9.9±0.3 (.39±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 106 0.4 (.016) 1.7 (.06) 0.6 (2.2) 0.1 (.04) 1 (3.5) 10 (35.3) 10.8 (.425) 9.9±0.3 (.39±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 106 0.4 (.016) 1.7 (.06) 0.6 (2.2) 0.1 (.04) 1 (3.5) 10 (35.3) 10.8 (.425) 9.9±0.3 (.39±.01) 0.15 (.006) 0.5 (.02) -20 to130 (-4 to 266) 106 0.4 (.016) 1.7 (.06) C B A C B A C B A C B A C B A C B A 2 3 1 2 3 4 5 6 7 8 4 A 79 253 327 B 79 253 326 C 79 253 328 E 79 218 454 F 79 253 329 Flat 170A R18.3 (.72) Flat 170A R24 (.94) Flat 170A R41 (1.61) Roller 170E R20 (.79) Dummy roller 170F R19.5 (.77) L 4 11.1±1.2 (.44±.05) L 7 13.2 ±2.5 (.52 ±.1) L 3 15.4 ±1.2 (.61±.05) L 3 13 ±1.2 (.51±.05) L 3 10.4±1.2 (.41±.05) R 1.5 9.2±0.6 (.36±.24) R 2 9.6±0.6 (.38±.24) D 79 218 491 L 79 218 493 Screw 170D R20 (.79) Transverse roller 170L R20 (.79) R 3.5 10.7 ±1.2 (.42 ±.05) R 1.5 14.5 ±0.6 (.57±.24) R 1.5 12 ±0.6 (.47 ±.24) MB Ø No Actuator Characteristics available upon request. 5 To order please specify : Example : 831700 C 2 • C L 1 Switch Type 831700 831704 831709 2 Contact Type A B C To order actuators separately, use the 8 digit P/N 3 4 Connection 1 2 3 4 5 6 7 8 Actuators 5 Actuator Position L - Left (Standard) A E R - Right B F C L D MB Ø MB SP4967 Example P/N is 831700 SPDT solder terminals “C” actuator mounted on the left. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/7 3 Subminiature Switches DIN 41635 B Dimensions 83 170 Symmetric 2.4–0.1 (.09–.001) 83 170 with MB Button 19.8 ±0.2 (.73 ±.008) 7.5 –0.2 (.3.–008) 5–0.1 (.2 –.004) R 3.6 (.14) 2.4 ±0.1 (.1±.009) 0.5 (.02–.001) Ø 2.5 ±0.1 (.1±.004) 7.62 ±0.2 (.30 ±.008) 6.35–0.2 (.25 –.008) (.37 ±.004) 6.35±0.2 (.25 ±.008) 8.9 ±0.2 (.35±.008) = 6.4 –0.2 (.25 –.008) 12.2 ±0.2 (.48 ±.008) Ø2.2 +0.1 0 (Ø .09 ±.004 0 ) 0.5 ±0.03 (x3) (.02±.001) 9.5 ±0.1 Ø 5.5 = 4 –0.1 (.157–.008) 12.2 –0.2 (.48 –.008) 9.5 –0.1 (.37 –.004) 8.9 –0.2 (.35–.008) 7.62 ±0.2 (.30 ±.008) –0.03 (x3) 2.2 ±0.1 (.09 ±.04) fl2.2 +0.1 0 (fl .09 –.004 0 ) 2.2 –0.1 (.09 –.04) fl 2.5 –0.1 (.1–.004) 9.6 –0.2 (.38 –.008) 2.4 –0.1 (.1–.009) R 2.5 (.1) 7.5 ±0.2 (.3.±008) 5±0.1 (.2 ±.004) 9.6 ±0.2 (.38 ±.008) OL = 7.6 (.30) 19.8 –0.2 (.78 –.008) 6.4 ±0.2 (.25 ±.008) 83 170 Asymmetric Mounting by M2 screws Torque : 2 cm daN mm (in) Connections Ø1.3 ±0.2 0 (.11 ±.004) 4.1±0.1 (.16 ±.004) 6.35±0.1 (.35 ±.004) (.25 ±.004) 1.C 4.NO 2.NC 6 8 7.62 ±0.1 (3x2.54) (.3 ±.004) (3x1) Ø 1.6 ±0.1 (.06 ±.004) 7.62 ±0.1 (3x2.54) (.3 ±.004) (3x1) 1.C 4.NO 2.NC mm (in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/8 1.3 ±0.05(.05 ±.002) 1±0.1 (.04 ±.004) 5±0.2 (2 ±.008) Symmetric 4 7 8.9 ±0.1 Ø 1.6 ±0.1 (.06 ±.004) 3.5 ±0.2 (.14 ±.008) 2.8±0.1 (.11 ±.004) Printed circuit board mounting Asymmetric 5 1.3±0.05 (.05 ±.002) 5±0.2 (2 ±.008) 4.5±0.15 (.18 ±.006) 7.1±01 (.28 +.004 ) 2.2±02 (.08 +.008 -0 ) 0 1.3 ±0.1 (.05 ±.004) 1 ±0.1(.04 ±.004) 2.4±0.15 (.1±.006) 3 30° 1.3 ±0.05(.05 ±.002) Side Output PCB Front 1±0.1 (.04 ±.004) 7-8 Side Output PCB Rear 3.4 ±0.2 (.13 ±.008) 5-6 Straight PCB 3.7±02 (.15 +.008 ) 3-4 .11x.02 Quick Connects 4.3 ±0.2 (.17 ±.008) 1 Solder 6 ±0.15 (.236 ±.006) 2 3.5 ±0.2 (.14 ±.008) Subminiature Switches DIN 41 635 B Actuators Actuator mounting positions 5.9 (.23) 11.1 (.44) ABC R TP (Tripping Point) Refer to pages 3/6 & 3/7. 6.3±0.1 (.25±.004) 6.3±0.1 (.25±.004) L 13.4±0.1 (.53±.004) 3.6±0.1 (.14±.004) F E 3 mm (in.) Mounting accessories Mounting pins 2.9 ± 0.1 (.11± .004) Output on unitboîtier side : 5: X2 Sortie côte Sortie côte couvercle Output on cover side : 7 : X3 mm (in.) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/9 Sealed Subminiature Switches Series 83 180 DIN 41 635 B Types General specifications Layout Components Part numbers for standard products with connection of type Material - Case : UL 94VO glass-filled polyester - Button : Polyester - Membrane : silicon - Contacts : AgCdO AgNi (dual current), - Terminals : tinned brass - Cable : PVC (IP 67) - Leads : PVC 1 2 FD0 Features Electrical characteristics Current rating at 250 V Nominal Hp Mechanical characteristics Operating force - max. Release force - min. Total travel force - max. Permitted overtravel force - max. Rest position - max. Tripping point Differential travel Overtravel - min. Ambient operating for tag version temperature for lead / cable version Mechanical durability Contact gap Weight (tag version) Actuators - flat : stainless steel - roller : stainless steel with polyamide roller Approvals 83 180/83 186 : NF. UL - cUL on request Operating curve 250 Va Operations Resistive circuit A 1/ 2 N (oz.) N (oz.) N (oz.) N (oz.) mm (in.) mm (in.) mm (in.) mm (in.) °C (°F) °C (°F) Operations mm (in.) g (oz.) Contact Type C (Form C) SPDT B (Form B) SPNC not available in PC terminals A (Form A) SPNO not available in PC terminals Connections A 2 1 3 4 Actuators and mounting positions Part numbers for standard actuators Actuators - Length Switch rating with DC supply 12 V 24 V Resistive load Inductive L/R 5 ms Resistive load Inductive L/R 5 ms 83 180 10 A 83 181 6A 83 183 3A 83 186 6A 10 A 6A 3A 6A 10 A 6A 3A 6A 5A 5A 3A 5A mm (in.) Mounting position Coefficient Tripping point 83 180 83 181/183/186 mm (in.) Model 83 181 is designed to operate equally well on dual-current (1 mA 4 V minimum) or medium-current (6 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life. Part numbers for standard actuators Actuators - Length Degree of protection - Tag version : Mounting positions Coefficient Tripping point Except where otherwise indicated, actuators are supplied unmounted. For factory mounting, specify fixing position L or R. - To calculate force : take the force quoted for the switch and divide by the coefficient given in the table. - To calculate travel : take the travel quoted for the switch and multiply by the same coefficient. - Lead / cable version : casing terminals outlet / casing = IP67 = IP00 = IP67 mm (in.) Mounting accessories for PCB mounting : 5 / 6 / 7 / 8 See page 3/9. Other information For other forces, actuators, connections and temperatures, please consult us. 3/10 . Normally stocked items Catalog products produced to order 1 83180 831800C1.0 831800C2.0 831800CFD0.0 83181 831810C1.0 831810C2.0 831810CFD0.0 83183 831830C1.0 831830C2.0 831830CFD0.0 83186 831860C1.0 831860C2.0 831860CFD0.0 High current Dual current Medium current Standard 10 12.5 6 7.5 3 4 6 7.5 3.4 (12) 1 (3.5) 5 (17.6) 10 (35.3) 9.3 (.37) 8.4 ±0.3 (.33 ±0.012) 0.10 (.004) 0.6 (.024) -40 +125 (-40 +257) -40 +105 (-40 +221) 106 0.4 (.016) 2 (.07) 2.5 (8.8) 0.8 (2.8) 4.2 (14.1) 10 (35.3) 9.3 (.37) 8.4 ±0.3 (.33 ±0.012) 0.10 (.004) 0.6 (.024) -40 +125 (-40 +257) -40 +105 (-40 +221) 2 x 106 0.4 (.016) 2 (.07) 2.5 (8.8) 0.8 (2.8) 4.2 (14.1) 10 (35.3) 9.3 (.37) 8.4 ±0.3 (.33 ±0.012) 0.10 (.004) 0.6 (.024) -40 +125 (-40 +257) -40 +105 (-40 +221) 2 x 106 0.4 (.016) 2 (.07) 2.5 (8.8) 0.8 (2.8) 4.2 (14.1) 10 (35.3) 9.3 (.37) 8.4 ±0.3 (.33 ±0.012) 0.10 (.004) 0.6 (.024) -40 +125 (-40 +257) -40 +105 (-40 +221) 2 x 106 0.4 (.016) 2 (.07) C B A C B A C B A C B A 2 3 3 5 6 7 8 FD0 FB0 FG0 CD0** CB0** CG0** 4 A 79 253 327 Flat 170A R18.3 (.72) B 79 253 326 Flat 170A R24 (.94) C 79 253 328 Flat 170A R41 (1.61) L R 3 1.5 10.4 ±1.2 (.41±.05) 9.2 ±0.6 (.36±.24) L 4 11.1±1.2 (.44±.05) L 7 13.2 ±2.5 (.52 ±.1) F 79 253 329 Dummy roller 170F R19.5 (.77) D * Screw 170D L 3 13±1.2 (.51±.05) R 2 9.6±0.6 (.38±.024) R 3.5 10.7 ±1.2 (.42±.05) L R 3 1.5 15.4 ±1.2 (.61±.05) 14.5±0.6 (.57±.24) L * Transverse roller 170EL * Ø No Actuator R 1.5 12±0.6 (.47 ±.24) ** Special order, contact us for part number ** Cable version for types 83 181, 83 183 and 83 186 1 E 79 218 454 Roller 170E R20 (.79) Switch Type 831810 831830 831860 831800 2 Contact Type A B C To order actuators separately, use the 8 digit P/N 5 To order please specify : 3 Example : 831810 C 2 • Ø Connection Actuators 1 6 Ø 2 7 A 3 8 B 4 FDØ CDØ C 5 FGØ CBØ D FBØ CGØ E 4 F L 5 Actuator Position L - Left (Standard) R - Right Example P/N is 831810 SPDT solder terminals with no actuator. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/11 Sealed Subminiature Switches DIN 41635 B Dimensions Asymmetric OL Symmetric Fixed by 2 x M2 screws Torque for screw alone: 0.2 Nm (1.75 in. lbs.) screw + washer: 0.3 Nm (2.65 in. lbs.) Connections Terminals 2 Solder 1 Faston 2.8 x 0.5 .110˝ Quick Connects Printed circuit board mounting Asymmetric Symmetric 3, 5, 7 4, 6, 8 3-4 Straight PCB output 5-6 Side output, PCB rear 7-8 Side output, PCB front Mounting on a printed circuit board with mounting pins Asymmetric Symmetric (.11±.004) Lead output Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/12 Cable output CG0 cable output on left CD0 cable output on right CB0 cable output on bottom Conductor cross-section : 83181 / 83183 / 83186 = 3 x 0.5 mm2 (.12 x .02 in2) Common = black NC = brown NO = blue mm (in.) Actuators Mounting positions 3 A, B, C Flat E Roller F Dummy roller mm (in.) Recommendations for operation from the side Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/13 Miniature Switches Series 83 161 DIN 41635 A Types General specifications Layout 2 3 6 Part numbers for standard products with connections of type Components Material - Case : glass-filled polyamide (self-extinguishing version to UL 94 VO and IEC 695-2-1 850° C - available on request) - Button : polyamide - Contacts : nickel silver or gold alloy (dual-current) Actuators - flat : stainless steel - roller : stainless steel, glass-filled polyamide roller - other types of polyamide Approvals: NF - UL/cUL Operating curve For type 83 161 5 - 5 SP 4136 For type 83 161 1 3 Number of operations Number of operations Resistive circuit: Inductive circuit { c L = 5 ms R a cos ϕ = 0.8 831613 Mechanical 831611 durability Resistive circuit: inductive circuit { c L = 5 ms R a cos ϕ = 0.8 Mechanical durability Features Electrical characteristics Current Horsepower Current rating at 125/250 V A HP Mechanical characteristics Operating force - max. Release force - min. Total travel force - max. Permitted overtravel force - max. Rest position - max. Tripping point Differential travel Overtravel - min. (OT) Ambient operating temperature Mechanical durability (for 2/3 OT) Contact gap Weight N (oz.) N (oz.) N (oz.) N (oz.) mm (in.) mm (in.) mm (in.) mm (in.) °C (°F) Operations mm (in.) g (oz.) Contact type C (Form C) SPDT B (Form B) SPNC A (Form A) SPNO Mechanical durability Connections Rating in Amps For type 83 161 8 Rating in Amps For type 83 161 9 SP 4136 Number of operations Number of operations 3 for 1/4˝ Quick Connects Actuators and mounting positions Resistive circuit: Resistive circuit: 2 solder A 79 215 740 Part numbers for standard actuators Actuators-Length mm (in.) Flat 161A R14.2 (.56) Mechanical durability Mechanical durability Mounting positions Coefficient Tripping point (except 83 161 6) Tripping point 83 161 6 Rating in Amps Rating in Amps For types 83 161 8 - 9 SP 4136 dual-current Models 83 161 8 and 83 161 9 SP 4136 are designed to operate equally well on dual-current (1 mA 4 V minimum) or medium-current (5 A maximum) circuits. However, a given product should only be used to switch one type of circuit during its working life. Part numbers for standard actuators Actuators-Length mm (in.) A 2 15.2 ±1(.6±.004) 14.8 ±1(.59±.004) B 1 15.2 ±0.45(.6±.018) 15 ± 0.45(.59±.018) H 79 218 651 Dummy roller 161G R21.8 (.86) Mounting positions A B Coefficient 3 1.8 ±2 ±.08 Tripping point (except 83 161 6) 21.7 (.85 ) 21.7 ±0.7(.85±.03) Tripping point 83 161 6 21.5 ±2(.85±.08) 21.5 ±07(.85±.03) Except where otherwise indicated, flat and roller actuators are supplied unmounted. Other information For other forces, actuators, connections and temperatures, please consult us. Normally stocked items Catalog products produced to order Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/14 1 83161.1(10.1A) 83161.2(15.1A) 83161.3(10.1A) 831611C2.0 831611C3.0 831611C6.0 831612C2.0 831612C3.0 831612C6.0 831613C2.0 831613C3.0 831613C6.0 High Force High Current Standard 10.1 1/2 15.1 1/2 83161.5(4A) 83161.9(0.1A) 83161.5SP4136 83161.9SP4136 ● ● ● 831615C2.0 831615C3.0 831615C6.0 Low Force 10.1 1/2 83161.8(0.1A) 831616C2.0 831616C3.0 831616C6.0 Ultra Light Force 4 1/10 83161.6 831618C2.0 831618C3.0 831618C6.0 Wide Gap 4 1/10 Dual Current 6.1 1/3 0.1 N/A 3 (10.5) 1 (3.5) 4.5 (15.8) 20 (70.5) 16.1 (0.63) 14.7±0.4 (.58±0.16) 0.35 (0.014) 1.1 (0.05) -20 +125 (-4 +257) 107 0.4 (0.016) 5.6 (.2) 0.8 (2.8) 0.2 (0.7) 2 (7.0) 20 (70.5) 16.2 (0.64) 14.7±0.3 (.58±0.16) 0.35 (0.014) 1.2 (0.05) -20 +125 (-4 +257) 2 x 107 0.4 (0.016) 5.6 (.2) 0.8 (2.8) 0.2 (0.7) 2 (7.0) 20 (70.5) 16.2 (0.64) 14.7±0.3 (.58±0.16) 0.35 (0.014) 1.2 (0.05) -20 +125 (-4 +257) 2 x 107 0.4 (0.016) 5.6 (.2) 0.25 (0.9) 0.05 (0.18) 0.35 (1.2) 20 (70.5) 16.3 (0.64) 14.7±0.4 (.58±0.16) 0.35 (0.014) 1.1 (0.05) -20 +125 (-4 +257) 5 x 107 0.4 (0.016) 5.6 (.2) 0.15 (0.54) 0.04 (0.14) 0.2 (0.72) 20 (70.5) 16.3 (0.64) 14.7±0.3 (.58±0.16) 0.35 (0.014) 1.2 (0.05) -20 +125 (-4 +257) 5 x 107 0.4 (0.016) 5.6 (.2) 5 (18) 0.5 (1.8) 6 (21.6) 20 (70.5) 16.1 (0.63) 14.5±0.4 (.58±0.16) 0.8 (0.03) 0.9 (0.035) -20 +125 (-4 +257) 5 x 104 3.2 (0.126) 5.6 (.2) 0.8 (2.8) 0.2 (0.7) 0.2 (.07) 20 (70.5) 16.2 (0.64) 14.7±0.4 (.58±0.16) 0.35 (0.014) 1.2 (0.05) -20 +125 (-4 +257) 2 x 107 0.4 (0.016) 5.6 (.2) C B A C B A C B A C B A C B A C B A C B A 2 3 3 5 screw 6 for 3/16˝ Quick Connects 7 for .11 Quick Connects 4 B 70 507 524 Flat 161A R25.4 (1) A 4 15.2±2.5 (.6±.1) 14.4±2.5(.56±.1) B 2 15.2±1(.6±.04) 14.8±1(.58±.04) E C 1.5 15.2 ±0.8(.6±.03) 14.9 ±0.8(.59±.03) 79 215 742 Roller 161E R13.6 (.54) A 2 20.5±1.5(.81±.06) 20.1±1.5(.79±.06) L B 1 20.5±0.8(.81±.03) 20.3±0.8(.80±.03) V G 70 507 529 Roller 161E R24.1 (.95) A 4 20.5±2.9(.81±.11) 19.7±2.9(.76 ±.11) B 2 20.5±1.5(.81±.06) 20.1±1.5(.79±.06) F 70 507 528 Dummy 161F roller R22.2 (.84) C 1.5 20.5±1.2(.81±.05) 20.2±1.2(.79 ±.05) A 3 20.4±2(.8±.08) 20.2±2(.79±.08) C 70 507 526 B C 1.8 1.5 ±0.7 ±.03 20.5 (.81 ) 20.5±0.9(.81±.035) 20.2±2(.79±.08) 4 D 79 215 835 Flat 161A R50 (1.9) Flat 161A R60 (2.39) 161V ** Telescopic plunger Manual action 161L D Factory Mount only D Factory Mount only B C B C A A 1 6 3 2 7 3.5 2.2 1 21.5 ±1 (.85 ±.04 ) 15.2±6.3 15.2±2 15.2±1.6 15.2±6.9 15.2±2.5 15.2±2.3 18.35 ±0.45 21.5 ±1 (.85 ±.04 ) For factory mounting, specify fixing position A, B or C ** For 83 161 1, 83 161 3, 83 161,6, 83 161 8, mounted in factory (supplied without nut) To order, please specify : 1 Switch Type 831612 831619 831613 831616 831615 831611 831618 2 Contact Type A B C To order actuators seperately, use the 8 digit P/N 3 Connection Example : 831612 C 3 • C A 4 2 3 5 6 7 Example switch is 831612, SPDT, 1/4” Q.C., C actuator mounted in A position 5 Actuators Ø A B C D E F G H L V Actuator Position A B C D A C B (std) D Ø = No actuator 3/15 5 Miniature Switches DIN 41635 A Dimensions ±0.2 (.8 ±.008 ) (.12 +.006 +.002 3 +0.15 +0.05 (.12 +.006 ) +.002 2.8 (.11) ) 10.3 ±0.15 (.41±.006) 20.2 Ø3 +0.15 +0.05 2.8 (.11) 3.9 22.2 ±0.2 (.87 ±.008 ) 2.8 (.11) 15.8 -0.15 -0.1 (.?? +.006 ) +.002 10.3 ±0.1 (.41 ±.004) OL = 13.35 (.53) 2.8 (.11) 83 161 3 (.12) 27.8 ±0.15 (1.09 ±.006) 3.4 (.13) mm (in) Connections 47 ° 17.4 (.69) 47 ° 6.3 (.25) Ø1.4 .06±.002 4.8±0.1 .19 ±.004 3.2 (.13) 20 (.79) max. +.008 2.2 +0.2 ) +0 (.09 -0 3.1 .12 ±.004 ±0.06 4 (.16) 9x6 (.35x.24) +.008 Ø1.3 +0.2 ) +0 (.05 -0 7.1±0.1 .28±.004 7.1±0.1 (.28 ±.004 ) Actuators mm (in) F Force calculation : divide the switch forces by the coefficient in the table. Travel calculation : multiply the switch travel by the same coefficient. 2mm (.08) A B C D Example : 83 161 3 with B Flat 161A actuator R 25.4 (1) position A (coef. 4) Operating force : 0.8  4 = 0.2 N Pre-travel: 1.4 x 4 = 5.6 mm (.055 x 4 = .22 in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/16 (6.3 ±0.1 7 (2.5x0.5 (.11x.02)) Quick Connects ±0.1 M3x4 (.12x.16) 45° 3 (.118) 6.2 (.244) 6 (4.8x0.5 (.3/16x.02)) Quick Connects 10.7 ±0.2 (.42 ±.008 ) Ø1.7 +0.05 +0 (.067 ±.002) 2.8 ±0.1 (.11 ±.004 ) 3.2 (.13) 9.8 (.286) 5 Screw 4.3 +0.05 -0.15 +.02 ) (.169 -.006 17.4 (.685) 9.3 ±0.2 (.366±.008) 2.8 (.11) 47 ° 6.7 (.264) 1.7 +0.05 +0 (.067 ±.002) 6.3 (.13 ±.012) 3.9x0.8 ±.02) (.15x.03 ±.001) 3.2 (.13) 3.2 ±0.3 12.1±0.2 (.25 ±.03 ) (.248±.004) 3 (6.3x0.8 (1/4x.03)) Quick Connects 2 Solder Miniature Switches DIN 41635 A Actuator Mounting Positions Actuators E-G A-B-C-D L V 3 F H Accessories Nuts 70 602 118 for L type actuator Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/17 Miniature Positive Break Switches Series 83 160 DIN 41635 A 1 Types General specifications Layout 83 160 7 POF TTF V A A V SPDT* 250 6 10 250 4 (14.1) 1.5 (3.5) 18 (63.5) 200 (70.5) 15.7 (.62) 14.8±0.3 (.58±0.012) 13.5 (.53) 1.3 (0.047) 0.5 (1.64) 5 -40+85 (-40+185) 107 1.2 (0.05) 7 (0.25) 4 (14.1) 1.5 (3.5) 18 (63.5) 200 (70.5) 15.7 (.62) 14.8±0.3 (.58±0.012) 13.5 (.53) 1.3 (0.047) 0.5 (1.64) 5 -40+85(-40+185) 107 1.2 (0.05) 7 (0.25) Mechanical characteristics Operating force - max. Release force - min. Min. positive opening force Permitted overtravel force - max. Maximum rest position Tripping point Maximum positive opening position Overtravel - min. Operating speed max. Operating rate max. Operating temperature Mechanical durability Contact gap Weight N (oz.) N (oz.) N(oz.) N (oz.) mm (in.) mm (in.) mm (in.) mm (in.) m/s (ft/sec) (operation/s) °C (°F) Operations mm (in.) g (oz.) 2 Contact Type B B (NC) C (SPDT)* C 3 Connections 3 for 1/4˝ Quick Connects 2 solder 6 for 3/16˝ Quick Connects 4 Dimensions Actuators** 22.2 (.87) 2.8 (.11) Ø=no Actuator 20.2 (.8) 3 (.12) (Flat) E (Roller) L (Pushbutton) 3.4 (.13) 27.8 (1.09) RF 4 (.16) 10 (.39) OL A Ø 3.2 (Ø .125) DT PT TP X1 for printed circuit board Actuators and mounting positions OT OF Assigned working voltage (Ue) Assigned working current (Ie) Thermal current rating (Ith) Assigned circuit voltage (Ui) NC 250 6 10 250 15.8 (.62) Definitions P.O.F. Minimum Positive Opening Force. The operating force that has to be applied to the operating device to produce the positive opening action. P.O.P. Maximum Positive Opening Position. The position of the operating device at the moment when positive opening of the contacts occurs. For other definitions, see "Basic concepts". Electrical characteristics 3.2 (.125) Electrical characteristics Short-circuit test (from IEC 947-5-1 § 8.34) - Current peak 1000 A at 250 V a 0.5 < cos ϕ < 0.7 - Short-circuit protection (SCPD) : fuse 10 A gG - (IEC 60) (1.2/50 µs) : 2500 V Electrical life Max. operations : 20 cycles/min Resistive load at 250 V~ 16 A : 105 cycles Inductive load (IEC 947.5.1) : AC 15 : 250 V~ 6A : 0.3 x 105 operations DC 13 : 24 V c 20 W L/R = 40 ms : 3 x 105 operations 120 V c 20 W L/R = 40 ms : 5 x 105 operations With positive break operation 10.3 (.41) Components Material - Case : glass-filled polyamide - Cover : transparent polycarbonate - Contacts : nickel silver - Positive rocker : high temperature thermoplastic Actuators : stainless steel - polyamide roller Features OL=13.1 (.52) The contact conforms to NFC 63 143 and IEC 947.5.1 *The SPDT version conforms to standard IEC 947.5.1 if only the normally closed contact is used. The switch operating principle forces the contacts open even in the event of welding (positive break operation). RLP NC NO mm (in) Other information To order, specify : Example : 831607 B 3 • Ø For other accessories, connections : please consult us 1 *NO – contact is not positive break Switch Type 831607 ** Consult us for actuator length, forces and positions 2 Contact Type B C 3 Connection 2 3 6 X1 Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/18 4 Actuator Type A L E Ø = No Actuator Miniature Side Rotary (High Sensitivity) Switches Series 83 137 1 Types General specifications Layout 83 137 0 Standard Features Electrical characteristics Nominal Thermal Current rating at 125-250 V Components Material - Case : glass filled polyamide - Contacts : silver Actuators - Stainless steel wire Operating curve Number of operations Resistive circuit: Inductive circuit { L = 5 ms R cos ϕ = 0.8 Mechanical life A A 5 14 N cm (in. oz) N cm (in. oz) N cm (in. oz) ° ° °C (F°) Operations mm (in) g (oz) 0.12 (.17) 0.03 (.042) 0.5 (.71) 10±0.4 12 -20 to 125 (-4 to 257) 107 0.8 (.031) 7.2 (.25) Mechanical characteristics Maximum operating force Minimum release torque Overtravel torque Movement differential Overtravel - min. Operating temperature Mechanical life Contact gap Weight 2 Contact Type C (Form C) SPDT B (Form B) SPNC A (Form A) SPNO C B A 3 Connections 2 solder 3 for 1/4” Quick Connects Rating in Amps Dimensions 29.6 (1.17) 5 0± r 10 4±.2) (3.9 Standard setting With special types, α can be varied from 0 to 360° Datum point for special lever setting 11 (.43) 8°30' Ø 0.7 (Ø .03) 15 (.6) 15.4 (.61) 4.3 (.17) 0 5.65 (.222) 8°30' 11 Ø4 (Ø .16) α Pre travel angle max. Movement differential angle 15.5 5.5 (.22) 18 (.17) Direction of measurement for α = 12.4 (.47) Actuator setting in α 12 (.47) = = 2.8 8.5 (.11) (.33) 16.4 (.65) 24 (.95) = 15.5 (.61) mm (in) Overtravel angle min. Dimensions connections 3 2 5.2 (.2) 1.7 (.07) 6.35 (.25) 5 (.2) 3 (.12) 0.8 (.03) Ø 3.2 (Ø.125) 4.3 (.17) For other connections, actuators, approvals accessories…Please consult factory 3.2x0.8 (.125x.03) 5.65 5.5 (.222) (.216) Approvals CSA (LR-20418), ASE, Semko, UTE & VDE. 10 (.4) A mm (in) To order, please specify : Example : 831370 C 3 • W 1 Switch Type 831370 Example switch is: 831370, SPDT, 1/4” Q.C. 2 Contact Type A B C 3 Connection 2 3 Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/19 3 Standard Switches (Double Break) Series 83 106 / 83 109 / 83 112 / 83 154 Types General specifications Layout 83 106 0 - The NO and NC circuits must both be of the same polarity. Components Material - Case : polyamide (83 106 to 83 112) - Case : Diallyl-Phthalate (83 154) - Contacts : nickel silver Actuators - passivated mild steel - roller : nylon - adjustable screws : self-retaining - plates : passivated mild steel (zinc) Note : Fixing holes for these switches have metal ferrules. Approvals: UL - cUL Features Standard Electrical characteristics Nominal c Nominal a Thermal Current rating at 250 V A — A 10 17.5 N (oz.) N (oz.) N (oz.) mm (in.) mm (in.) mm (in.) mm (in.) °C (°C) Operations mm (in.) g (oz.) 4 (14.1) 1 (3.5) 20 (70.5) 12.75 (.5) 11.45+0.2 -0.25(11.45+0.2 -0.25) 0.5 ±0.2 (0.02 ±.008) 0.7 (.28) -20 +85 (-4 +185) 107 0.4 x 2 8 Mechanical characteristics Operating force - max. Release force - min. Permitted overtravel force - max. Maximum rest position Tripping point Differential travel Overtravel - min. Ambient operating temperature Mechanical durability Contact gap Weight Contact type C (Form C) SPDT B (Form B) SPNC A (Form A) SPNO Operating curve Number of operations Connections Resistive circuit: Inductive circuit { L = 5 ms R cos ϕ = 0,8 Mechanical life Rating in Amps 83 154 C Actuators and mounting positions Part numbers for standard actuators A 70 500 888 Actuators-Length mm (in.) Flat R49 (1.92) Operating force - max. Release force - min. Pre-travel - max. Differential travel Total travel max. N (oz.) N (oz.) mm (in.) mm (in.) mm (in.) 1.2 (4.2) 0.25 (.9) 6.2 (.24) 2.1 ±0.9 (.083 7.5 (.3) ) ±.035 Except where otherwise indicated, the flat and roller actuators are mounted as shown in the dimensional drawings (mounted on the left). Assemblies Other information For other forces, actuators, connections and temperatures, please consult us. Normally stocked items Catalog products produced to order Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/20 1 83 109 0 83 112 0 83 106 4 83 106 7 83 111 0 83 111 5 83 154 0 Face terminals Enclosed screws Bistable, 2 actuator positions Bistable, 2 push button positions Base mounting by screws Base mounting by clips Magnetic blow-out switch — — — — — — 5 10 17.5 10 17.5 10 17.5 10 17.5 10 17.5 10 17.5 17.5 4 (14.1) 1 (3.5) 20 (70.5) 12.75 (.5) 11.45+0.2 -0.25 (.45+.008) 0.5 ±0.2 (.02 ±.008) 0.7 (.29) -20 +85 (-4 +185) 107 0.4 x 2 (.016 x .08) 8 (.3) 4 (14.1) 1 (3.5) 20 (70.5) 12.75 (.5) 11.45+0.2 -0.25 (.45+.008) 0.5 ±0.2 (.02 ±.008) 0.7 (.29) -20 +85 (-4 +185) 107 0.4 x 2 (.016 x .08) 14.5 (.3) 0.45 (1.62) 2 (7.19) 4 (14.1) 1 (3.5) 20 (70.5) 4 (14.1) 1 (3.5) 20 (70.5) 4 (14.1) 1 (3.5) 20 (70.5) 11.45+0.2 -0.25 (.45+.008) 0.5 ±0.2 (.02 ±.008) 0.7 (.29) -20 +85 (-4 +185) 107 0.4 x 2 (.016 x .08) 8 (.3) 11.45+0.2 -0.25 (.45+.008) 0.65 ±0.25 (.02 ±.008) 0.7 (.29) -40 +125 (-4 +257) 107 0.5 x 2 (.016 x .08) 11 (.3) C B A C B A -20 +85 (-4 +185) 106 0.4 x 2 (.016 x .08) 9 (.32) -20 +85 (-4 +185) 106 0.4 x 2 (.016 x .08) 8 (.3) 11.45+0.2 -0.25 (.45+.008) 0.5 ±0.2 (.02 ±.008) 0.7 (.29) -20 +85 (-4 +185) 107 0.4 x 2 (.016 x .08) 8 (.3) C B A C B A C B A — 2 Contact type C C 3 2 solder 3 for 1/4˝ Quick Connects 1 screw 4 B 70 500 828 E 70 500 813 R49 (1.92) Flat R47 (1.85) Lever R26 (1.02) R15.5 (.61) 1.2 (4.2) 0.25 (.9) 6.2 (.24) 2.1 ±0.9 (.083 8.4 (.33) 1.2 (4.2) 0.25 (.9) 6.2 (.24) 2.1 ±0.9 (.083 7.5 (.31) 2.8 (9.9) 0.45 (1.6) 3.2 (.125) 1.05 ±0.4 (.041 4.5 (.18) 4 (14.1) 0.8 (2.8) 1.45 (.057) 0.5 ±0.2 (.02 ±.008) 1.9 (.075) ) ±.035 Q 70 500 840 ) ±.035 T 70 500 870 ) ±.016 B9 21 416 364 Operation B9 Plate Mounting Screw 4 (14.1) 1 (3.5) 1.5 (.059) 0.5 ±0,2 (.02 ±.008) 1.9 (.075) Y 70 500 206 H 70 500 208 O2 70 500 218 Y Side plate H Horizontal single-pole mounting plate O2 2-pole side mounting plate K2 2-pole vertical mounting plate To order, specify : 1 Switch Type 831060 831090 831120 831540 2 Contact Type C B A 3 Connection 1 2 3 Example : 831810 C 2 • Ø 4 To order actuators separately, use the 8 digit P/N Actuators A B E Q 5 T B9 Ø = No actuator Actuator Position L - Left (Standard) R - Right Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/21 3 Standard Switches Dimensions 24 (.94) 2Ø 2.5± 0.1 (.1±.004) Ø 7.5 (.3) 13 ± 0.1(.51±.004) Ø2 L –0 + 0.01 + 0.65 1.9 (.07) 8 (.31) 1 (.04) 10.5 (.41) 3) .9 (1 7.8 (.31) 16.6 (.65) (.1) 8± 0.1 (.31±.004) 12.8 (.5) 2.4 (.1) 2.4 OL=10.65 (.42) 4 (.16) 83 106 7 7.5 (.3) 83 106 4 6 (.24) 6.4 (.25) 83 106 - 83 109 - 83 154 Prof. 1.2 +0 Products 83 106 / 109 / 111 83 154 L 32 (1.26) 40 (1.57) 4.6 (.18) 4 (.16) Ø8 (.31) 6 (.24) 16.6 (.65) 8.15 (.32) 7.6 (.30) 6.5 (.26) 8.8 (.35) 1.6 (.06) 23 (.91) 15.9 (.63) 83 112 83 111 5 2 (.08) 7.6 (.30) 83 111 0 13.6 (.54) 12.6 (.5) 7.2 (.28) Ø 2 – 0.05 (.08 + .002 ) 39.2 (1.54) 12.6 (.5) 46.4 (1.83) 13.6 (.54) 23 (.91) mm (in) 36 (1.42) Connections 6 (.24) (.11) 8 (.315) (Ø.125) (Ø.06) (Ø.06) mm (in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/22 (.206) (.32) (.315) (.032) 2.8 (.11) (.25) 23.6 (.93) 6.2 (.24) (.45) 8 (.315) (.315) 8 (.315) (.24) 3 2 (83 109) 0.8 (.032) 2 (83 106) (.032) 1 Standard Switches Actuators Cross-section of actuators 1 x 6.4 mm (.039 x .252 in.) A R Ø8 (.315) x5 (.2) 47 (1 .85 ) ) 93 (1. 49 F 3 (.12) R 3 (.12) 6x (.24) 8.5 (.33) 12.2 (.48) 8 11.5 (.45) M 2.5x12 7.5 (.3) 3) 1.9 9( R4 E (.32) 7.5 (.3) B Q B9 T 6x8.5 (.24x.33) 19.4 (.76) Ø8x5 (.315x.2) (.315x.2) R 26 .5 15 R .61) ( (1.0 2) (.24x.33) 3 mm (in.) Assemblies 02 Y K2 20 (.78) 52 (2.05) 20 (.787) 62 (2.44) 5.9 17.2 (.68) (.23) 34.2 (1.35) 17.2 (.68) 4.6 (.18) H 29.4 (1.16) ép. 1.5 (.059) M2 2.1 (.08) Ø 4.2 (.165) 33 (1.30) 25 (.98) Ø 4.2 (.165) 5.5 (.22) 13 (.51) 22.4 (.88) 4.7 7.3 (.185) (.29) 25 (.98) Ø 4.2 (.165) 33 (1.30) Unless indicated, the thickness of plates is 1.5 mm (.059 in). mm (in.) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/23 Sealed Double Break Switches Series 83 139 - IP 67 - Explosion Proof EEX d IIC T6 Types General specifications Layout Components 83 139 0 - 1- 5 Material - Case : polyester - Contacts : silver - Membrane : nitrile on 83 139 0 - silicone on 83 139 1 - 2 - 5 Actuators : - stainless steel - rollers : polyamide 83 139 2 Features Electrical characteristics Current rating at 125-250 V Nominal A Mechanical characteristics - The NO and NC circuits must both be of the same polarity. Characteristics specific to 83 139 1 - Conform to standards EN 50 014 and 50 018 - Group II classified for explosive atmospheres other than mines subject to firedamp - Temperature class T6, max. surface temperature 85°C - LCIE certificate 880022U - These switches can be enclosed in an envelope of a certified material, particularly to provide mechanical protection - Degree of protection IP 67. Operating force - max. Release force - min. Max. total travel force Overtravel max. - force Maximum rest position Tripping point Movement differential Overtravel - min. Operating temperature Mechanical life Contact gap Weight N (oz) N (oz) N (oz) N (oz) mm (in) mm (in) mm (in) mm (in) °C (F°) Operations mm (in) g (oz) Contact Type C (Form C) SPDT Mounting Holes 4 holes = A standard 2 holes = B Operating curve Number of operations Connections Resistive circuit: Inductive circuit { L = 5 ms R cos ϕ = 0.8 Mechanical life Lead position bottom - standard Lead position right Lead position left Actuators Part numbers for standard actuators Actuator-Length mm (in) Operating force - max. Release force - min. Movement differential N (oz) N (oz) mm (in) Rating in Amps Part numbers for standard actuators Actuator-Length mm (in) Operating force - max. Release force - min. Movement differential N (oz) N (oz) mm (in) Other information For other forces, actuators, connections and temperatures, lead lengths, please consult factory. Normally stocked items Catalog products produced to order Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/24 1 83 139 0 83 139 5 83 139 2 83 139 1 Standard Low temperature Double insulation to NFC 20030 standard classe II Explosion proof EEX d 11C T6 5 5 5 5 3 (10.6) 0.6 (2.1) 4 (14.1) 10 (35.3) A = 8.8 (.35) B = 9.8 (.39) A:7.7+0.4 (.30+.016) B:8.7+0.4 (.32+.016) 0.35±0.1 (.014±.004) 0.3 (.012) 0 to 85 (32 to 185) 107 0.3 x 2 (.012 x .008) 37 (1.3) 3 (10.6) 0.6 (2.1) 4 (14.1) 10 (35.3) A = 8.8 (.35) B = 9.8 (.39) A:7.7+0.4 (.30+.016) B:8.7+0.4 (.32+.016) 0.35±0.1 (.014±.004) 0.3 (.012) 0 to 85 (32 to 185) 5 x 107 0.3 x 2 (.012 x .008) 37 (1.3) 3 (10.6) 0.6 (2.1) 4 (14.1) 10 (35.3) B = 9.8 (.39) 8.7+0.4 (.32+.016) 0.35±0.1 (.014±.004) 0.3 (.012) -40 to 85 (-40 to 185) 5 x 106 0.3 x 2 (.012 x .008) 45 (1.6) 3 (10.6) 0.6 (2.1) 4 (14.1) 10 (35.3) B = 9.8 (.39) A:7.7+0.4 (.30+.016) B:8.7+0.4 (.32+.016) 0.35±0.1 (.014±.004) 0.3 (.012) -40 to 85 (-40 to 185) 5 x 106 0.3 x 2 (.012 x .008) 37 (1.3) C C C C A B A B B B 4 flexible leads ø 2.8 x 0.75 mm2 length 0.50 m 4 flexible leads ø 2.8 x 0.75 mm2 length 0.50 m 3 lead cable 3 x 0.75 mm2 length 0.50 m 4 flexible leads ø 2.8 x 0.75 mm2 length 0.50 m B R L B R L B B R L 2 3 4 5 6 A 79 215 740 R P B 79 507 524 E 79 215 742 G 70 507 529 Flat 139 AX R29.7 (1.17)** Roller 139 EX R28.7 (1.13)** Flat 161A R14.2 (.56) – R25.4 (1.0) Roller 161 E R13.6 (.54) – R24.1 (.94) 1.5 (5.3) 0.2 (.7) 1.5 (.06) F 79 218 581 1.5 (5.3) 0.2 (.7) 1.5 (.06) 79 218 651 2.6 (9.2) 0.35 (1.2) 0.7 (.028) 2.6 (9.2) 0.35 (1.2) 0.7 (.028) H 1.7 (6) 0.2 (.7) 1.25 (.05) 1.7 (6) 0.2 (.7) 1.25 (.047) Note : When mounting actuators, a light greasing of the switch push-button is recommended. Flat 161F R22.3 (1.17) Dummy roller 161 G R21.8 (.86) 2 (7.1) 0.2 (.7) 1.1 (.043) Ø No Actuator For more actuators, see 83161 2 (7.1) 0.2 (.7) 1.1 (.043) ** Factory mounted only To order, please specify : Example : 831390 C A B 5 • A 1 Switch Type 831390 831391 831392 831395 2 Contact Type C 3 Mounting Holes A B 4 Connection B R L 5 Lead Length 6 Actuators .5 - 1/2 meter (std) 1 - 1 meter 2 - 2 meter Example switch is: 831390, DBDT, 4 mounting holes, leads exit bottom, .5 meter cable with A actuator. A F P B H R E Ø G To order actuators seperately, use 8 digit P/N. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/25 3 Sealed Switches - IP 67 Dimensions 6.7 (.26) 8.7 ±0.4 (.314±.016) Tripping Point R:1.5 (.06) 8.8 (.35) 5.7 (.22) 14±0.1 (.55±.004) Ø2 (.079) R: 1.5 (.06) spherical 14±0.1 (.55±.004) Ø2 (.079) R: 1.5 (.06) spherical R:1.5 (.06) 6.7 (.26) Ø2 (.079) R:1.5 (.06) 8.7 ±0.4 (.314±.016) Tripping Point Tripping Point 16 (.63) 7 (.28) R: 1.5 (.06) spherical 83 139 2 83 139 0 - 1 - 5 - Mounting B = 2 holes 83 139 0 - 5 - Mounting A = 4 holes 2 x Ø3.2 (Ø.125) 1 2 4 34 (1.34) Lead reference on casing 3 1 4 2 3 1 2 4 1 24±0.2 (.94±.008) Actuators Factory Mounted Only Actuators mounting position (type 139) 9.4 (.37) 3.7 (.15) 4.7 (.185) 9.4 (.37) Lead position - right Lead position - left 3 1 3 1 2 4 4 2 Numbering : 1 = black lead 2 = brown lead 3 = grey lead 4 = blue lead Numbering : 1 = black lead 2 = brown lead 3 = grey lead 4 = blue lead Standard lead position colour black colour black 3 1 3 1 2 4 4 2 0.5x3.8 (.02x.15) R 0.5x3.8 (.02x.15 ) P F Ø 4.8x4.8 (Ø .19x.18) Lead position - right Lead position - left Standard lead position R R F mm (in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/26 2 0 9 -0.2 (.35 +0 ) -.008 (.35 +0 ) -.008 3 4 4 2 Cable 3 x 0.75 mm2, length 0.5 1 = black lead 2 = brown lead 4 = blue lead 24±0.2 (.94±.008) 24±0.2 (.94±.008) mm (in) 3 1 4 2 0 9 -0.2 (.35 +0 ) -.008 3 2 x Ø3.1 (Ø.125) 24 (.94) 25 (.98) Lead reference on casing 3 1 0 9 -0.2 2 x Ø3.1 (Ø.125) 2 x Ø2.2 (Ø.087) Sealed Switches - IP 67 Actuators User or Factory Mounted Actuators mounting position (type 161) 9 (.35) 4.7 (.185) 3.7 (.15) 9 (.35) Lead position - right Lead position - left 3 1 3 1 2 4 3 1 4 2 3 1 2 4 4 2 Standard lead position colour black E-G F F R R 8 (.315) Ø 4.8 (Ø .187) 4.3 (.17) 4.3 (.17) F 0.5x7 (.02x.28) R F 6.3 (.25) R: 2.5 (.1) 3 5 (.2) A-B H ) 5 (.2 .8 0.5x7 8) (.02x.2 21 R 4.3 (.17) (.8 6) Ø mm (in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/27 Sealed Miniature Switches Series 83 169 - IP67 - DIN 41 635 A Types General specifications Layout Features 83 169 Electrical characteristics Nominal Current rating at 125-250 V Mechanical characteristics Components Material - Case : polyester UL 94 VO - Contacts : nickel silver gold alloy (low current) - Membrane : Fluoro - silicone Actuators - stainless steel - rollers : polyamide - Plunger : stainless steel Operating force - max. Release force - min. Maximum overtravel force Overtravel max. - force Maximum rest position Tripping point Movement differential Overtravel - min. Temperature Endurance Contact gap Weight Operating curve 83 169 0 C (Form C) SPDT Number of operations Resistive circuit: Inductive circuit { L = 5 ms R cos ϕ = 0.8 N (oz) N (oz) N (oz) N (oz) mm (in) mm (in) mm (in) mm (in) °C (F°) Operations mm (in) g (oz) Contact Type 83 169 4 Number of operations A Resistive circuit: Inductive circuit { Connections L = 5 ms R cos ϕ = 0.8 Mechanical life Mechanical life Flexible leads ø 3 x 1 mm2 long 0.50 m Lead position - right Lead position - left 3 lead cable - 3 x 0.75 mm2 length 0.50 m, left output only Actuators and mounting positions-user or factory mounted P Part numbers for standard actuators Actuator-Length Rating in Amps Rating in Amps mm (in.) Mounting positions Operating force - max. Release force - min. Movement differential ** Flat 139 AX R29.7 (1.17) D N (oz) N (oz) mm (in) 2.5 (8.8) 0.4 (1.4) 1.2-0.5 (.047-.02) Part numbers for standard actuators Operating characteristics 83 169 8 and 83 169 9 low current Intended for use from 1 to 100 mA at 4 to 30 V DC. Under these conditions, electrical life exceeds mechanical life. Degree of protection IP 67 Mounting positions N (oz) Operating force - max. N (oz) Release force - min. mm (in) Movement differential Unless indicated, flat actuators and roller actuators are delivered unmounted ** Factory Mounted Only Approvals: UL, cUL (CSA Equivalent) Note : When mounting actuators a light greasing of the switch push-button is recommended. Other information For other forces, actuators, connections and temperatures, please contact factory. Normally stocked items Catalog products produced to order Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/28 1 83 169 0 83 169 4 83 169 8 83 169 9 Standard Reduced differential movement Low current Low current, reduced differential movement 10 5 0.1 0.1 4 (14.1) 1 (3.5) 8 (28.2) 20 (70.5) 15.9 (.63) 14.7+0.5 (.58±.02) 0.35 (.014) 1 (.04) -20 to 85 (-4 to 185) 5 x 106 0.4 (.016) 30 (1.06) 4 (14.1) 1 (3.5) 8 (28.2) 20 (70.5) 15.9 (.63) 14.7+0.5 (.58±.02) 0.07 (.003) 0.4 (.016) -20 to 85 (-4 to 185) 5 x 106 0.4 (.016) 30 (1.06) 4 (14.1) 1 (3.5) 8 (28.2) 20 (70.5) 15.9 (.63) 14.7+0.5 (.58±.02) 0.35 (.014) 1 (.04) -20 to 85 (-4 to 185) 5 x 106 0.4 (.016) 30 (1.06) 4 (14.1) 1 (3.5) 8 (28.2) 20 (70.5) 15.9 (.63) 14.7+0.5 (.58±.02) 0.07 (.003) 0.4 (.016) -20 to 85 (-4 to 185) 5 x 106 0.4 (.016) 30 (1.06) C C C C 2 3 R R L C R L C L C(1) R L C (1) 83 169 0 Cable limits current to 8 Amps 4 B 70 507 524 A 79 215 740 R **Roller 139 EX R28.7 (1.13) D A 2.5 (8.8) 0.5 (1.8) 0.8 (.032) F 79 218 581 B 4.2 (14.8) 1 (3.5) 0.4 (.016) A B C 1.4 (4.9) 2.5 (8.8) 3.5 (12.3) 0.25 (.88) 0.5 (1.8) 0.6 (2.1) 1.6 (.063) 0.8 (.032) 0.6 (.024) A 2.5 (8.8) 0.5 (1.8) 0.8 (.032) B 4.2 (14.8) 1 (3.5) 0.4 (.016) A B C 1.4 (4.9) 2.5 (8.8) 3.5 (12.3) 0.25 (.88) 0.5 (1.8) 0.6 (2.1) 1.6 (.063) 0.8 (.032) 0.6 (.024) H 79 218 651 Dummy roller 161 G R21.8 (.86) Flat 161 F R22.3 (.88) A 1.5 (5.3) 0.25 (.9) 16 (.63) Roller 161 E R13.6 (.54) - R24.1 (.95) Flat 161 A R14.2 (.56) - R25.4 (1) 2.5 (8.8) 0.4 (1.4) 1.2-0.5 (.047-.02) G 70 507 529 E 79 215 742 B 2.6 (9.2) 0.5 (1.8) 0.8 (.032) A 1.5 (5.3) 0.25 (.9) 16 (.63) Ø No Actuator B 2.6 (9.2) 0.5 (1.8) 0.8 (.032) For more actuators see 83161 5 To order, please specify : Example : 831690 C R .5 • Ø 1 Switch Type 831690 831694 831698 831699 2 Contact Type C 3 Cinnections R L C Example switch is: 831690, SPDT, leads exit right, .5 meter leads, with no actuator. 4 Leangth of Leads .5 - 1/2 meter (std) 1 - 1 meter 2 - 2 meter 5 6 Actuator Ø A B H Actuator Position E F G P R D A B C To order actuators seperately, use the 8 digit P/N. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/29 3 Sealed Miniature Switches Dimensions Output cable Output wires 5 (.2) 13 (.51) 2 (.079) 10.5 (.41) 83169 0 & 8 83169 4 & 9 OL = Ø3 +0.15 +0.05 (.12 +.006 -.002 ) 13.1 (.52) 13.8 (.54) 3 +0.15 +0.05 (.12 +.006 -.002 ) 20.2 ±0.2(.8 ±.008 ) Ø2 (.079) Ø3.4 (.134) 2.8 (.11) 3x1mm 2 Leads 1 = black lead (common) 2 = brown lead (NC) 4 = blue lead (NO) 22.2 ±0.1(.87±.004 ) 31 (1.22) 3x0.75mm 2 cable 1 = black lead (common) 2 = brown lead (NC) 4 = blue lead (NO) 10.3 ±0.1 (.41±.004 ) 6.5 (.26) Output left Ø 4.8 (Ø .187) 6.3 (.25) F R R 0.5 (.02) 6.5 (.26) R P 0.5x3.8 (.02x.15) mm (in) Actuators Mounting position for factory mounted actuators 8 (.315) D E-G A-B F B C 6.3 F (.25) R 8 (.315) 10.3 (.41) A 0.6 (.24) D R 4.3 (.17) 8.7 (.34) 4.4 (.17) 0.5x7 (.02x.28) 14.4 (.57) Ø 4.8 (Ø .187) Mounting position for factory or customer mounted actuators 22.2 (.87) H F .2 0.5x7 (.02x.28) 5 (.2) 7) (.8 90° 4.3 (.17) 22 R 5 ) (.2 R 5 Ø 2) (. R: 2.5 (.1) F mm (in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/30 Low Force Position Detectors Series 81 290 ■ Conforms to standard DIN 43365 Form A ■ Low activation force < 1.7 oz. (50 g @ at 6 bars) at 90 psi ■ No continuous consumption of compressed air 1 Part numbers (Form B) SPNC (Form A) SPNO Contact type 81 290 501 - 81 290 001 Symbol Characteristics Orifice diameter Operating pressure Flow at 60 psi(4 bars) Activation force at 90 (6 bars) Permissible fluid: air, inert gases Max/min. of fluid temperatures operating storage Mechanical life at 90psi (6 bars) Response on activation time on release Barb connection for semi-rigid tubing Weight Principle of NC operation Deactivated inches(mm) psi(bar) cfm(NI/min) ounces(g) 5/64" 30 > 120 4.5 +120 +20> +140 +20> +160 (2) (2 > 8) (130) (< 50) 5/64" 30 > 120 2.5 +50) (-10 > +60) (-40 > +70) +20> +120 +20> +140 +20> +160 (2) (2 > 8) (>70) (< 50) ● ● 10 million ≤ 15 ≤ 15 0.106”I.D.x 5/32”O.D. 8.5 (-10 > +50) (-10 > +60) (-40 > +70) 10 million ≤ 15 ≤ 15 0.106”I.D.x 5/32”O.D. 8.5 (2.7x4) (2.7x4) Activated exhaust 2 x S (1) (2) (1) 2 Operation accessories Unless otherwise requested, flat and roller-ended actuators are supplied loose. 161 A flat 79 215 741 161 E roller 79 215 743 161 A 161 E +0.08 (4.3 +0.2) 0.169 1" (25 .4) .134 (3.4) .51 (12.95) .874 (22.2) in (mm) .23 (5.8) Use (metric) dimensions for critical data Other information On request : To order, specify : Standard products Wide range of actuators Connectable exhaust 1 2 Part number Accessory Example : Low force position detector 81 290 501 Flat actuator 79 215 741 Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/32 0.31" (8) (ø4.8) 5 0.19" dia 0 .9 .118+0.06 -.002 (3+0.15 -0.05) ) 5.4 " (2 0.134" (3.4) .15 (3.8) .126 (3.2) .118+.006 +.002 +0.15 (3+0.05 ) (2.4) .788 (20) 1.18 (30) 0.09" 0.125" (6.3) .608 (10.3) .197 .466 (5) (11.8) 2.5 Total travel .098 (26) Operating position .154 (3.9) .59+0.02 (14.7+0.5) .63 (16) .65 (16.5) Reset position .43 (10.7) Dimensions Snap Action Switches – Technical Guide Switch construction These basic principles apply to all our precision switches. The specific characteristics of each model are given in more detail in the relevant production sections. Single-pole changeover switch (i.e. 83 161) Push button Mounting hole Case Introduction Our switches are high-precision, snap-action switches and these are a few of the key features which distinguish our switches: - High ratings with small dimensions - Very short travels - Low operating forces - Highly dependable force and travel values - Long life - Large range of actuators for easy adaptation to the most varied applications Terminal NC nº2 Return spring Contact mobile Contact fixed Terminal NO nº4 Mounting hole Common terminal C nº1 Pivot point Blade Electrical function SPDT (C) Normally closed (NC) 2 1 1 Normally open (NO) 1 2 4 4 Double-pole changeover switch (i.e. 83 132 0) Push button Blade Case Contact fixed Terminal NO nº3 Terminal NO nº4 Terminal NC nº1 Contact mobile Terminal NC nº2 Mounting hole Mounting hole Return spring Electrical function SPDT (C) 3 1 4 2 Normally closed (NC) 1 2 Normally open (NO) 3 The NO and NC circuits must both be of the same polarity. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/104 4 Snap Action Switches – Technical Guide Mechanical characteristics Terminology - Forces - Positions - Travel TTF DT PT OT RF RP TP OL RLP Electrical circuit Position of pushbutton OF OF Operating Force TTF Total travel force Force required to displace the operating device from its rest position RP to its overtravel limit position. (We only specify this value if it is higher than the operating force. When not quoted, it is equal to or less than the operating force). RF Release force Force to which the operating force must be reduced to allow the snap-action mechanism to return to its release position RLP. MOF Maximum overtravel force The maximum force which can be applied to the operating device, without damaging it, in the end of travel position where it is in abutment internally or against the face of the case. RP Rest position Position of the operating device when no external mechanical force is applied. Also described as "height at rest". TP Tripping point Position of the operating device relative to the fixing point (hole, face) at the moment when the microswitch trips. PT Pre-travel Distance between the rest position RP and the tripping point TP. Travel Positions Forces Maximum force which must be applied to the operating device to displace the rest position RP to the tripping point TP. OL Overtravel limit Position of the operating device when an extreme force has moved it to the effective end of the available travel. OT Overtravel Distance between the tripping point TP and the overtravel limit OL. 3 RLP Release position Position of the operating device at the moment when the snap-action mechanism trips on its return to its original position. DT Differential travel Distance between the tripping point TP and the release position RLP. The reference point for the figures given for travel and forces is a point F situated on the button in the case of a plain microswitch, or, generally, 3 mm in from the end of a plain actuator. The reference point for the positions is one of the fixing holes, unless otherwise indicated. Graphs of forces vs. travel Operating force (external) applied to the operating device Contact force Force after depression: return outward depression return Button movement Contact force Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/105 Snap Action Switches – Technical Guide Mechanical characteristics Environmental conditions Changeover time Resistance to shocks and vibrations This is the time taken by the mobile contact when moving from one fixed contact to another until it becomes fully stable (contact bounce included). This time is a function of the contact gap, the mechanical characteristics of the snap action and the mass of the mobile element. However, thanks to the snap-action mechanisms employed, the time is largely independent of the speed of operation. It is normally less that 20 milliseconds (including bounce times of less than 5 ms). Resistance to impact and vibration depends on the mass of the moving parts and on the forces holding the contacts together. Generally speaking, for a switch without an actuator : - Vibration >10 G 10 at 500 Hz - Impact > 50 G 11 ms 1/2 sine-wave Further information on request. Ambient operating temperature The maximum and minimum temperatures at which the mechanical and electrical characteristics of the switch will remain substantially unaltered. Bounce time Changeover time about Mechanical durability This is an average value indicating the purely mechanical performance of a switch when not subject to any electrical load. It may be useful for evaluation purposes in cases where the power levels involved are very low and the electrical life is thus close to the mechanical life. Degree of protection Maximum speed and rate of operation 1st numeral Protection equipment provides against the entry of solid foreign bodies Protection for persons against access to dangerous parts 0 4 5 6 (not protected) 1 mm Ø wire 1 mm Ø wire 1 mm Ø wire Our switches will work at speeds of operation varying over a very wide range : normally from 1 mm/min to 1 ms. The maximum rate of operation with a low electrical load may be as high as 10 operations/second. Mounting - Operation • To conform to the leakage paths and air gaps in the standard EEC24 - EN/IEC 61058 EN/IEC 60947: - An insulation pad must be inserted between the switch and the fixing surface if the latter is metal. - Manual operation of a metal actuator must only be carried out with the help of a secondary actuator made of insulating materials. • The installer must ensure adequate protection against direct contact with the output terminals. Fixing - Screw torque • Unless otherwise indicated in the mechanical characteristics table, the torque required for the fixing screws must conform to the following values : Ø of fixing screw 2 Screw torque maximum 25 in cm.N minimum 15 2.5 35 25 3 60 40 3.5 100 60 Under the IEC 529 or NFC 20010 classification scheme, standards employ an IP code to define the degree or class of protection which electrical equipment provides against access to live components, the entry of solid foreign bodies and ingress of water. (not protected) diameter ≥ 1 mm protected against dust sealed against dust 2nd numeral Protection equipment provides against ingress of water 0 4 5 6 (not protected) splashed water hosed water high-pressure hosed water 7 temporary immersion 8 prolonged immersion Under this classification, our switches come within the following categories : - Plain switches = IP 00 - Protected switches = IP 40 with isolated connection - Sealed switches = IP 66 or IP 67 4 150 100 Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/106 Snap Action Switches – Technical Guide Circuit types Dielectric characteristics Current rating Resistive circuit This is the current the switch is capable of making and breaking which forms the basis for the life tests. For a circuit with alternating voltage, this is in phase with the current : Cos ϕ = 1. Thermal rating This is the current the switch will withstand when not being operated, for a temperature rise of not more than 60 °C. τ=L Inductive circuit R Switch rating AC voltages: see the current rating. With DC voltages the switch rating is very much dependent on the voltage, the contact gap (CG) and the nature of the load being switched. There is a risk of prolonged or indeed permanent arcing if the following limits are exceeded: M Limit of constant current D.C. Resistive load Inductive load L/R = 5 ms Lamp and capacitance circuit 220 110 24 ➛ EC=0.4 mm CG=0.4 mm EC=3 mm CG=3 mm ➛ 48 A circuit of this type with direct current is characterised by a time constant. An inductive circuit, with alternating voltage, for example, incorporating a motor (cos ϕ < 1) can cause current surges up to 6 times the normal current. For certain switches, we give electrical endurance curves with L = 5 ms in DC R and cos ϕ = 0.8 in AC. ➛ The currents at the time when the circuit is closed are very high in this case, being up to 10 times the nominal figure. 12 Internal resistance 0.3 0.5 1 2 5 10 16 For special applications, please enquire. Operating curves These indicate the electrical life of the switches, under standard conditions (20 °C, 1 cycle/2 seconds), by showing the number of switching operations which can be performed with given types of load. Number of operations This consists of the intrinsic resistance (fixed) of the parts carrying current and the contact resistance (variable). Close to the tripping point and release position, the force holding the contacts together drops considerably and this may cause a rise in internal resistance. Insulation resistance The insulation resistance of the switches is generally greater than 50,000 MΩ measured at 500 V DC. Resistive circuit Inductive circuit Dielectric strength The dielectric strength of our switches is generally better than: - 1500 volts between live parts and earth - 1000 volts between contacts - 600 volts between contacts for switches whose contact gap is less than 0.3 mm. Rating in Amps Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/107 3 Snap Action Switches – Technical Guide Contact materials Electrical recommendations Choice of contact material Inductive circuits To choose the best material for the contacts there are various factors to be considered: - the current and voltages levels - the type of load - the number of operations - the switching frequency - the environmental conditions. To increase the life of contacts and their DC rating, arcing on opening can be cut down by using the following circuits: - for DC Fast diode V R > 5 x V nominal I nominal > 10 x I winding Contacts for general-purpose use Our switches are normally fitted with silver contacts. These are suitable for the majority of applications and provide the best compromise between electrical performance, thermal performance and life. A - for DC or AC A - RC circuit across inductor B - RC circuit across switch B C C (nF) ~100 x I nominal (A) V insulation > V peak R(Ω) ~ load resistance (Ω) Contacts for low-power circuits E < 20 V and/or I < 100 mA The contacts used in this case are plated with gold (or a gold alloy) for good reliability even in corrosive atmospheres. D C - Varistor circuit across load D - Varistor circuit across switch V > V peak supply P (V.A.) E (J) ≥ ––––––– 100 Contacts for special applications We can supply special contacts suitable for particular applications, such as: - Ag CdO contacts for very high drawn currents, - Cross Bar gold-plated Ag Ni contacts which allow a very wide range of applications to be covered by a single type of switch. Very low power circuits In very low power circuits (I > 1 mA, V ≤ 5 V), switching is highly sensitive to environmental conditions (the atmosphere, pollution). If the supply is powerful enough, adding a passive resistor to increase the current broken by the switch to a few milliamps will substantially improve reliability of operation. R - Load resistance C - Very low current load Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/108 Snap Action Switches – Technical Guide Methods of actuation Standards - Approvals Direct operation Preferably, force should be directly applied to the device – the plunger – along its axis for operation. However, the majority of our microswitches will accept skewed operation provided the angle of application is not more than 45°. The device used to apply the force must never hamper the travel of the plunger to the tripping point (TP). It must under all circumstances move the plunger through at least 0.5 times the overtravel (OT) quoted. Steps must also be taken to see that it does not cause the overtravel limit (OL) or maximum overtravel force (MOF) quoted to be overrun or exceeded. Our switches are designed according to international recommendations (IEC), American standards (UL) and/or European standards (EN). Proof of compliance with these standards and recommendations is demonstrated by: - the manufacturer's declaration of conformity (drafted in accordance with the ISO/IEC 22 guidelines), or - approval granted directly by an accredited body, or by application of the CCA (Cenelec Certification Agreement). More detailed information on the approval for a particular type of microswitch can be obtained on request. Operation by actuator When operation is by a roller lever, force should preferably be applied in the direction shown on the left. + Where the movements involved are fast, the ramp should be so designed as to ensure that the operating device is not subjected to any violent impact or abrupt release. 3 The 83170 switch as an example An 83 170 4 switch marked with the symbols for the European (according to CCA/MC12) and American approvals it holds. Quality Quality is built into our switches from the initial design stage right through to the point where they are put into action at the customer's premises. All departments of the company are guided by the Quality Manual and the stipulations of the ISO 9000 international standard. The location where the switches are manufactured (the la Plaine works at Valence) holds ISO 9001 certification, guaranteeing a high standard of quality. Control procedures Manufacturing quality of our switches is controlled systematically during assembly operations and on final completion. All our products are subjected to a final inspection, either at 100% on important characteristics, or according to the statistical sampling rules of French standards X 06-222 and X 06-023. The quality levels applied, for normal use such as defined in previous paragraphs are for the following defects, according to the standards : - critical fault : NQA : 0.40 - major fault : NQA : 1 - minor fault : NQA : 2.5 Rules and regulations EC directives Our switches are compatible with European Community technical directive (Low Voltage) 73/23 and can be used within the framework of Machinery directive 83/392. Environmental protection The modern concept of protection of the environment is an integral part of the manufacture of our switches, from product design through to packaging. At the customer's request, and for certain ranges of our products which must meet specific needs expressed in the specifications, it is always possible to adapt or create an inspection specification of a standard product. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/109
79215835 价格&库存
很抱歉,暂时无法提供与“79215835”相匹配的价格&库存,您可以联系我们找货
    • 1000+11.757301000+1.52550
