05/02/2015
www.crouzet.com
V3 83161 Dual-current Dual-current 831618 Part number 83161806
Minimum rating 1 mA / 4 VDC
Operating temperature up to +125 °C
Conforming to EN 61058 and UL 1054
Choice of actuators with 4 possible fixing positions
Part numbers
83161806
Type
Function
Connections
Dual-current 831618
I (Changeover)
W3
Specifications
Electrical characteristics
Rating nominal / 250 VAC (A)
Rating thermal / 250 VAC (A)
0,1
6
Mechanical characteristics
Maximum operating force (N)
Min. Release force (N)
Maximum total travel force (N)
Max. permitted overtravel force (N)
Maximum rest position (mm)
Operating position (mm)
Maximum differential travel (mm)
Min. overtravel CRA (mm)
Ambient operating temperature (°C)
Mechanical life for 2/3 CRA (operations)
Contact gap (mm)
Weight (g)
0,8
0,2
2
14,7±0,3
0,35
1,2
-20 →+125
2 x 107
0,4
5,6
Additional specifications
Components
Material
- Housings : polyamide or polyester
- Button : polyamide
- Contacts : gold alloy
Levers
- Flat : stainless steel
- Roller : stainless steel, glass-filled polyamide roller
- Other polyamides
Approvals : NF
Principles
Dimensions (mm)
Product
83161
Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
05/02/2015
No
www.crouzet.com
Legend
OL
Dimensions (mm)
Connections
W2 solder
Dimensions (mm)
Connections
W3 (6.3 x 0.8) for 6.35 mm clips
Dimensions (mm)
Connections
W3R5 (6.3 x 0.8) for 6.35 mm clips
05/02/2015
Dimensions (mm)
Connections
W5 screw
Dimensions (mm)
Connections
W6A5 (4.8 x 0.5) for 4.8 mm clips
Dimensions (mm)
Connections
W6D8 (4.8 x 0.8) for 4.8 mm clips
www.crouzet.com
05/02/2015
www.crouzet.com
Dimensions (mm)
Connections
W7A5 (2.8 x 0.5) for 2.8 mm clips
Dimensions (mm)
Connections
2W7A8 2 x (2.8 x 0.8) for 2.8 mm clips
Dimensions (mm)
Actuator mounting positions
Levers
To calculate force Divide the switch force by the coefficient given in the table. To calculate travel Multiply the switch travel by the same coefficient. Example : 83 161 8 with lever 161 A - R 25.4
position A (coeff. 4) Operating force : 0.8 : 4 = 0.2 N Pre-travel : 1.4 x 4 = 5.6 mm
Dimensions (mm)
05/02/2015
www.crouzet.com
Dimensions (mm)
Actuators
161 E
Dimensions (mm)
Actuators
161 L
05/02/2015
www.crouzet.com
Nut thickness Max. torque 1.5 mm 5 Cm N 2 mm 7 Cm N 2.5 mm 10 Cm N
No
Legend
Thread
Total travel
Dimensions (mm)
Actuators
161 V
Dimensions (mm)
05/02/2015
Actuators
161 F
Dimensions (mm)
Actuators
161 G
Dimensions (mm)
Mounting accessories
Nut 70602118
Dimensions (mm)
Housing 161 J for connections W3 R5
www.crouzet.com
05/02/2015
www.crouzet.com
Curves
Operating curve for type 831618
For types 83 161 8 - 9 and 9 SP 4136 Dual-current These models are designed to operate equally well on dual-current (1 mA 4 V minimum) or medium-current (5 A maximum) circuits. However, a
given product should only be used to switch one type of circuit during its working life.
No
Legend
Number of cycles
Resistive circuit
Mechanical life limit
Current in Amps
Connections
Actuators and fixing positions
05/02/2015
www.crouzet.com
Other information
Mounting - Operation
See basic technical concepts
Product adaptations
Special levers
Special connections
Specific fixing
High operating temperature
Special operating force
Approvals : UL - cUL
很抱歉,暂时无法提供与“70507524”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.039711+0.65177
