82862203
82862203
    CROUZET(高诺斯)
    MOTOR 82860 GEARBOX RPT5 (LONG)
82862203 数据手册
D.C. geared motors with brushes ➜ 0.5 Nm 3.9 Watts ■ A range of D.C. geared motors with sintered metal ■ ■ ■ ■ gears. Mechanical rating of gearbox with output shaft stalled : 0.5 Nm. 3.9 Watt motor power Available in either 12 or 24 V D.C. versions. Gearbox ratios options for 1.5 to 441 rpm. Options with magnetic encoder. Specifications 1 Type Voltage Output speed (rpm) Ratios (i) 441 9.76 141 30.6 45 95.4 14 298 5 931 1.5 2910 General characteristics Motor Gearbox Maximum permitted torque from gearmotor under continuous conditions (for 1 millions turns) N.m Axial load static (daN) Radial load static (daN) Max. output (W) Nominal output (W) Gearbox case temperature rise (°C) Weight (g) Product adaptations ■ ■ ■ ■ ■ ■ ■ ■ ■ To order, see page 13 34 Special supply voltages Special cable lengths Optional encoder Special connectors Special output shafts Special gearbox ratios Special gear wheel material Special output bearings Special mounting plate 3.9 Watts 3.9 Watts 82 862 0/2 12 V 82 862 0/2 24 V 82 862 001 82 862 002 82 862 003 82 862 201 82 862 202 82 862 203 82 862 004 82 862 005 82 862 006 82 862 204 82 862 205 82 862 206 82 860 0 81 012 0 / 81 012 2 0.5 82 860 0 81 012 0 / 81 012 2 0.5 1 8 3.9 3 50 160 / 170 1 8 3.9 3 50 160 / 170
82862203 价格&库存
很抱歉,暂时无法提供与“82862203”相匹配的价格&库存,您可以联系我们找货
