Subminiature Switches Series 83 170 DIN 41 635 B
General specifications
Layout
Types
Components
Material
- Case : polyester UL 94 VO
- Button : glass-filled polyamide
- Contacts : AgNi,
gold-plated AgNi (dual-current)
- Terminals : copper-nickel
Actuators
- flat : stainless steel
- roller : stainless steel with polyamide roller
Approvals: NF - UL - cUL
Operating curve
For type 83 170 0
Number of
operations
Resistive circuit:
Inductive circuit
1
2
3
Features
Electrical characteristics
Current rating at 250 V
Nominal
Thermal
A
A
Mechanical characteristics
For type 83 170 4
Number of
operations
Part numbers for standard products (no lever) terminal type
c L = 5 ms
R
a cos ϕ = 0.8
Mechanical
life
Resistive circuit:
Inductive circuit
c L = 5 ms
R
a cos ϕ = 0.8
Mechanical
life
Operating force - max.
Release force - min.
Total travel force - max.
Permitted overtravel force - max.
Maximum rest position
Tripping point
Differential travel
Overtravel - min.
Ambient operating temperature
Mechanical endurance
Contact gap
Weight
N (oz.)
N (oz.)
N (oz.)
N (oz.)
mm (in.)
mm (in.)
mm (in.)
mm (in.)
°C
Operations
mm (in.)
g (oz.)
Contact type
Rating in
Amps
Rating in
Amps
C (Form C) SPDT
B (Form B) SPNC not available in PC terminals
A (Form A) SPNO not available in PC terminals
Connections
For type 83 170 9
Number of
operations
Resistive circuit:
Mechanical
life
Actuators and mounting positions
Rating in
Amps
Part numbers for standard actuators
Actuators – Length
mm (in.)
Mounting positions
Coefficient
Tripping point
mm (in.)
Mounting positions
Model 83 170 9 is designed to operate equally well on dual-current
(1 mA 4 V minimum) or medium-current (5 A maximum) circuits.
However, a given product should only be used to switch one type of
circuit during its working life.
Except where otherwise indicated, actuators are supplied unmounted.
For factory mounting, specify mounting position L or R.
– To calculate force : take the force quoted for the switch and divide by
the coefficient given in the table.
– To calculate travel : take the travel quoted for the switch and multiply
by the same coefficient.
Mounting accessories for PCB mounting: 5 / 6 / 7 / 8
See page 3/9.
Other information
For other forces, actuators, connections and temperatures,
please consult us.
Normally stocked items
Catalog products produced
to order
Products and specifications subject to change without notice.
Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com
3/6
1
83170.0
831700C1.0
831700C2.0
831700C3.0
83170.4
831704C1.0
831704C2.0
831704C3.0
83170.9
831709C1.0
831709C2.0
831709C3.0
83170.4 SP 4967
831704C2.MBSP
831704C3.MBSP
831704C1.MBSP
83170.4
831704C1.MB
831704C2.MB
831704C3.MB
83170.9
831709C1.MB
831709C2.MB
831709C3.MB
High current
Standard
Low current
High force
Standard
Low current
10
12.5
5
6
0.1
5
6
5
6
0.1
1.5 (5.3)
0.3 (1)
1.8 (6.3)
10 (35.3)
9.2 (.36)
8.4±0.3 (.33±.01)
0.15 (.006)
0.5 (.02)
-20 to130 (-4 to 266)
107
0.4 (.016)
1.7 (.06)
0.6 (2.2)
0.1 (.04)
1 (3.5)
10 (35.3)
9.2 (.36)
8.4±0.3 (.33±.01)
0.15 (.006)
0.5 (.02)
3.107
0.4 (.016)
1.7 (.06)
0.6 (2.2)
0.1 (.04)
1 (3.5)
10 (35.3)
9.2 (.36)
8.4±0.3 (.33±.01)
0.15 (.006)
0.5 (.02)
3.107
0.4 (.016)
1.7 (.06)
1.5 (5.3)
0.3 (1)
1.8 (6.3)
10 (35.3)
10.8 (.425)
9.9±0.3 (.39±.01)
0.15 (.006)
0.5 (.02)
106
0.4 (.016)
1.7 (.06)
0.6 (2.2)
0.1 (.04)
1 (3.5)
10 (35.3)
10.8 (.425)
9.9±0.3 (.39±.01)
0.15 (.006)
0.5 (.02)
106
0.4 (.016)
1.7 (.06)
0.6 (2.2)
0.1 (.04)
1 (3.5)
10 (35.3)
10.8 (.425)
9.9±0.3 (.39±.01)
0.15 (.006)
0.5 (.02)
106
0.4 (.016)
1.7 (.06)
C
B
A
C
B
A
C
B
A
C
B
A
C
B
A
C
B
A
2
3
1
2
3
4
5
6
7
8
4
A 79 253 327
B 79 253 326
C 79 253 328
E 79 218 454
F 79 253 329
Flat 170A R18.3 (.72)
Flat 170A R24 (.94)
Flat 170A R41 (1.61)
Roller 170E R20 (.79)
Dummy roller 170F R19.5 (.77)
L
4
11.1±1.2 (.44±.05)
L
7
13.2 ±2.5 (.52 ±.1)
L
3
15.4 ±1.2 (.61±.05)
L
3
13 ±1.2 (.51±.05)
L
3
10.4±1.2 (.41±.05)
R
1.5
9.2±0.6 (.36±.24)
R
2
9.6±0.6 (.38±.24)
D 79 218 491
L 79 218 493
Screw 170D R20 (.79)
Transverse roller 170L R20 (.79)
R
3.5
10.7 ±1.2 (.42 ±.05)
R
1.5
14.5 ±0.6 (.57±.24)
R
1.5
12 ±0.6 (.47 ±.24)
MB
Ø No
Actuator
Characteristics available upon request.
5
To order please specify :
Example : 831700 C 2 • C L
1
Switch Type
831700
831704
831709
2
Contact Type
A
B
C
To order actuators separately, use the 8 digit P/N
3
4
Connection
1
2
3
4
5
6
7
8
Actuators
5
Actuator Position
L - Left (Standard)
A
E
R - Right
B
F
C
L
D
MB
Ø
MB SP4967
Example P/N is 831700 SPDT solder terminals “C” actuator mounted on the left.
3/7
3
Subminiature Switches DIN 41635 B
Dimensions
83 170 Symmetric
2.4–0.1
(.09–.001)
83 170 with MB Button
19.8 ±0.2
(.73 ±.008)
7.5 –0.2
(.3.–008)
5–0.1
(.2 –.004)
R 3.6
(.14)
2.4 ±0.1
(.1±.009)
0.5
(.02–.001)
Ø 2.5 ±0.1
(.1±.004)
7.62 ±0.2
(.30 ±.008)
6.35–0.2
(.25 –.008)
(.37 ±.004) 6.35±0.2
(.25 ±.008)
8.9 ±0.2
(.35±.008)
6.4 –0.2
(.25 –.008)
12.2 ±0.2
(.48 ±.008)
Ø2.2 +0.1
(Ø .09 ±.004
0 ) 0.5 ±0.03 (x3)
(.02±.001)
9.5 ±0.1
Ø 5.5
4 –0.1
(.157–.008)
12.2 –0.2
(.48 –.008)
9.5 –0.1
(.37 –.004)
8.9 –0.2
(.35–.008)
7.62 ±0.2
(.30 ±.008)
–0.03 (x3)
2.2 ±0.1
(.09 ±.04)
fl2.2 +0.1
(fl .09 –.004
0 )
2.2 –0.1
(.09 –.04)
fl 2.5 –0.1
(.1–.004)
9.6 –0.2
(.38 –.008)
2.4 –0.1
(.1–.009)
R 2.5 (.1)
7.5 ±0.2
(.3.±008) 5±0.1
(.2 ±.004)
9.6 ±0.2
(.38 ±.008)
OL = 7.6 (.30)
19.8 –0.2
(.78 –.008)
6.4 ±0.2
(.25 ±.008)
83 170 Asymmetric
Mounting by M2 screws
Torque : 2 cm daN
mm (in)
Connections
Ø1.3 ±0.2
(.11 ±.004)
4.1±0.1
(.16 ±.004)
6.35±0.1
(.35 ±.004)
(.25 ±.004)
1.C
4.NO
2.NC
6
8
7.62 ±0.1
(3x2.54)
(.3 ±.004)
(3x1)
Ø 1.6 ±0.1
(.06 ±.004)
7.62 ±0.1
(3x2.54)
(.3 ±.004)
(3x1)
1.C
4.NO
2.NC
mm (in)
3/8
1.3 ±0.05(.05 ±.002)
1±0.1 (.04 ±.004)
5±0.2 (2 ±.008)
Symmetric
4
7
8.9 ±0.1
Ø 1.6 ±0.1
(.06 ±.004)
3.5 ±0.2
(.14 ±.008)
2.8±0.1
(.11 ±.004)
Printed circuit board mounting
Asymmetric
5
1.3±0.05 (.05 ±.002)
5±0.2 (2 ±.008)
4.5±0.15 (.18 ±.006)
7.1±01 (.28 +.004 )
2.2±02
(.08 +.008
-0 )
1.3 ±0.1
(.05 ±.004)
1 ±0.1(.04 ±.004)
2.4±0.15
(.1±.006)
3
30°
Side Output PCB Front
1±0.1 (.04 ±.004)
7-8
Side Output PCB Rear
3.4 ±0.2 (.13 ±.008)
5-6
Straight PCB
3.7±02 (.15 +.008 )
3-4
.11x.02 Quick Connects
4.3 ±0.2 (.17 ±.008)
1
Solder
6 ±0.15 (.236 ±.006)
2
3.5 ±0.2
(.14 ±.008)
Subminiature Switches DIN 41 635 B
Actuators
Actuator mounting positions
5.9
(.23)
11.1
(.44)
ABC
R
TP (Tripping Point)
Refer to pages 3/6 & 3/7.
6.3±0.1
(.25±.004)
6.3±0.1
(.25±.004)
L
13.4±0.1
(.53±.004)
3.6±0.1
(.14±.004)
F
E
3
mm (in.)
Mounting pins
2.9 ± 0.1
(.11± .004)
Output on
unitboîtier
side : 5: X2
Sortie
côte
Sortie
côte
couvercle
Output on
cover
side : 7 : X3
mm (in.)
3/9
很抱歉,暂时无法提供与“831704C2.ER”相匹配的价格&库存,您可以联系我们找货
