83731319
83731319
    CROUZET(高诺斯)
    检测开关 AC250V
83731319 数据手册
Automotive Limit Switches Series 83 731 / 83 732 / 83 733 Conform to the following standards : IEC 356.1 - EN 60204.1 NFC 20030 : Class I - 83 731 - 83 732 Class III - 83 733 Degree of protection : IP 56 - IP 66 depending on type Version : 1 pole Function : 3-terminal single break twoway contact element (form C: inverter). Principle : Electrical characteristics : 83 731 3 Control mechanisms Top-mounted plunger Top-mounted plunger with roller Mechanical characteristics Minimum operating N (oz.) force Minimum total travel N (oz.) force Minimum operating travel mm (in.) 83 732 3 83 733 3 ● ● ● 15 (53) 15 (53) 6 (21.2) 35 (123.4) 35 (123.4) 25 (88.2) 2 (.079) 2 (.079) 1.5 (.059) Differential travel Max. total travel mm (in.) 0.2 (.008) 0.2 (.008) 0.2 (.008) mm (in.) 6 (.236) 6 (.236) 4 (.157) Mechanical life Temperature limits Degree of protection Weight Operations °C (°F) °C (°F) g (oz.) 106 - 5 + 70 IP 66 110 (3.9) 106 - 5 + 70 IP 66 110 (3.9) 106 - 5 + 70 IP 56 70 (2.5) Dimensions Assigned operating current (Ie) 83 731 - 83 732 : 5 A 250 V 83 733 : 5 A 50 V Thermal rating (Ith) : 12 A 1 Types 83 731 3 mm 83 732 3 83 733 3 Operating curve : Operations Resistive circuit Inductive circuit L = 5 ms R a cos ϕ = 0.8 c { A Connections : PVC cable (A05 - VV - F) 0.50 m long 3 conductors cross-section 0.75 mm2 Sheathed, ext. Ø : 7.6 mm Core connections : 1 : black (common) 2 : brown (NC) 4 : blue (NO) Electrical protection : Earthing terminal for version 83 731 and 83 732. Approvals : CSA A300. Other information For other versions, functions and special contacts or special modes of operation : please consult us. To order, specify : 1/2 meter cable 83731316 83732323  83733315 Standard products, non stocked 1 meter cable 83731319 83732315 83733314 2 meter cable 83731310 83732327 83733310 1 Type Example : Limit switch - 83 731 319 Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/46
83731319 价格&库存
很抱歉,暂时无法提供与“83731319”相匹配的价格&库存,您可以联系我们找货
