LIMIT SWITCHES SELECTION GUIDE
| | SWITCHES.CROUZET.COM
|| 4
| | MICROSWITCHES
| | 10/2019
|| 5
| | MICROSWITCHES
| | 10/2019
10/2019
STANDARD
SPECIAL
HARSH ENVIRONMENT
PANEL MOUNT / DOOR SWITCHES
SEAT SWITCHES
SNAP-ACTION SWITCHES
Approx. body size (mm)
49x30x16
49x39x16
60x27x25
73x56x36
51x87x33
64x25x25
8387
8388
8380
8384
8383
83589
Plastic
housing
Standard
Adjustable
fixing
10 A
10 A
0.6 A
A300
Q150
10 A
10 A
0.6 A
A300
Q150
10 A
500 V
4 kV
10 A
500 V
4 kV
SERIES
TYPE
Max. ratings
ELECTRICAL
Assigned caracteristics
Dual-current version
Thermal rating
Insulation voltage
Impulse withstand voltage
@ 250 V a
@ 24 V c
@ 250 V c
AC15
DC13
Ithe
Ui
Uimp
Prewired Prewired
"EN" size "US" size
10 A
10 A
6A
10 A
10 A
6A
0.8 A
0.8 A
0.5 A
A300
A300
B300
Q150
Q150
R300
1 mA ➝ 5 A 1 mA ➝ 5 A 1 mA ➝ 5 A
10 A
10 A
10 A
500 V
500 V
250 V
2.5 kV
2.5 kV
2.5 kV
13
21
Circuit diagram
Contact configuration
(for 1 pole changeover/SPDT)
SPST-NC / SPST-NO versions
Multipole version
14
22
13
21
14
22
Form Zb
(separated
contacts)
Form Zb
(separated
contacts)
4
4
Zamak
Zamak
3
1
4
2
Form Za
3
1
4
2
Form Za
3
1
Form Za
Protection against electric shock
Class I
Class I
Degree of protection
Solid objects + water
IP66
IP67
IP69
IK07
-40 °C
+70 °C
4
IP66
IP67
IP69
IK07
-40 °C
+70 °C
4
Mechanical impact
Operating temperature
Mud / salt /dust / ice environment
25x31x12
32x24x13
min. Ø 17x40
min. Ø 14x34
min. 100x30x30
Depending on type
38x35x11
83581
83139
SP4257
83777
83778
83770
83771
8399 Ex
8399 Nuc
83523
83528
83161
SP9603/SP9604
+ variants
Sealed
Hermetic
Explosive
atmospheres
Nuclear
applications
Latching +
Auto reset
4A
4A
0.15 A
C300
4A
4A
0.3 A
C300
1A
3A
4 mA 137 V c
C300
1A
3A
0,2 A 137 V c
C300
1 mA ➝ 1 A
4A
250 V
2.5 kV
1 mA ➝ 1 A
4A
250 V
2.5 kV
1 mA ➝ 1 A
3A
250 V
2.5 kV
1 mA ➝ 1 A
3A
250 V
2.5 kV
16 A
16 A
5A
A300
R300
1 mA ➝ 5 A
17 A
250 V
2.5 kV
Premium
Miniature
Low profile
Sub
Plastic
Double
housing miniature
housing
break
8A
8A
0.3 A
B300
R300
1 mA ➝ 5 A
10 A
250 V
2.5 kV
2
4
1
Form C
10 A
10 A
0.3 A
B300
R300
12 A
250 V
2.5 kV
1
2
4
Form C
8A
6A
8A
6A
0.3 A
0.5 A
B300
B300
R300
R300
10 A
11 A
250 V
250 V
2.5 kV
2.5 kV
2
4
1
3
1
Form C
4
2
Form Za
2
4
2
4
1
2 poles**
4
Plastic
Class Il
IP65
-30 °C
+70 °C
Zamak
Zamak
Plastic
Steel
Class I
Class I
IP66
IP66
-40 °C
+70 °C
-40 °C
+70 °C
Class Il
IP66
IP67
IP69
IK04/06
-40 °C
+85 °C
4
Class I
IP66
IP69
-40 °C
+70 °C
4
2 poles**
4
2 poles**
Metal +
Plastic
Class I
Metal +
Plastic
Class I
Class Il
Class Il
IP67
IP69
IP66
IP67
-40 °C
+105 °C
Explosive atmospheres
Min. Operating Force
-40 °C
+105 °C
II2G
Total Travel
Min. Overtravel
Min. Positive Overtravel
Max. Differential Travel
Mechanical life
Operating device
For linear mvt
(cycles)
Plunger
Plunger with roller
Lever with roller
Adjustable lever with roller
Adjustable lever + idle-return roller
For rotary mvt
Roller lever
Multi-direction
Flexible rod
Plunger with ball
Fixing means
Plain holes
Non-adjustable
Tapped holes
Snap-in
Adjustable
Elongated holes
Threaded barrel
Connections
Screw
Terminals
Solder
Fast-on
Pre-wired
Wires
Cable
Integral connector
Approvals
10 N
10 N
0.15 Nm
0.15 Nm
5 mm
5 mm
70°
70°
3 mm
3 mm
35°
35°
1 mm
1 mm
10°
10°
0.7 ; 1.3 mm 0.7 ; 1.3 mm
9° ; 17°
9° ; 17°
10 M
10 M
4
4
4
4
4
4
4
Ø4
4
Ø5
M12 x 0.75
4
4
M12 x 0.75
4
4
CE/IECEx/ATEX
3
1
4
2
Depending on type
83513
83522
83576
839921**
Extensive
range
Double break
Heavy duty
Self adjustable
Large travel
25 A
16 A
5A
A300
Q300
1 mA ➝ 5 A
25 A
250 V
2.5 kV
16 A
16 A
5A
A300
Q300
10 mA ➝ 5 A
17 A
250 V
2.5 kV
10 A
10 A
0.3 A
B300
R300
1 mA ➝ 5 A
12 A
250 V
2.5 kV
Tilting actuator
Customizable
sensitivity
2
4
1
3
1
4
2
2
4
1
4A
4A
0.2 A
C300
R300
1 mA ➝ 4 A
5A
250 V
2.5 kV
2
4
1
Form C
Form C
Form Za
Form C
Form Za
Form C
Form C
4
2 ; 3 poles
4
2 poles
4
4
2 poles
4
2 ; 3 poles
4
2 poles**
4
2 ; 3 poles
4
4
Aluminium
Inox steel
Metal + Plastic
Metal + Plastic
Metal + Plastic
10 N
0.07 Nm
5 mm
60°
3.5 mm
45°
4
4
1.5 ➝ 15 N
0.2 Nm
6 ➝ 11 mm
60°
3,5 ➝ 5 mm
35°
1,5 ➝ 2 mm
15°
0.8 ➝ 2 mm
10°
10 M
4
4
4
4
4
4
4
Ø4
Ø5
0.5 mm
8°
10 M
4
4
1.5 ➝ 15 N
0.2 Nm
6 ➝ 11 mm
60°
3,5 ➝ 5 mm
35°
0.8 ➝ 2 mm
10°
10 M
4
4
4
4
4
4
4
Class I
Class I
Class I
Class I
Class I
Class I
IP66
IP68 (18 m)
IP69
IP66
IP67
IP69
IP66
IP68 (18 m)
IP69
IP40
IP40
IP40
IP40
IP67
-55 °C
+125 °C
4
-55 °C
+250 °C
4
-40 °C
+200 °C
4
-55 °C
+250 °C
4
-40 °C
+125 °C
IK04
-40 °C
+70 °C
-40 °C
+85 °C
d
M16 x 1
4
4
4
4
II2G
5N
3.5 N
60 N
4.5 mm
4mm ; 6 mm
4mm ; 6 mm
4mm ; 6 mm
4.4 mm ; 6.7 mm
1.3 ➝ 5,5 mm
3.5 mm
2,5 mm ; 4 mm 2,5 mm ; 4 mm 2,5 mm ; 4 mm
3.2 mm ; 5.5 mm
1 ➝ 5 mm
0.25 mm
1 mm
1 mm
0.2 mm ; 0.5 mm
0.05 mm ; 0.15 mm
10 M
4
1M
4
4
0.1 M
4
4
0.1 M
4
4
0.05 M
4
4
0.1 M
4
4
M16 x 1
M10 x 0.75
4
max. 6 bar
20 N
0.4 Nm
5.5 mm
60°
4 mm
40° ➝ 50°
max. 6 bar
8 ➝ 30 N
1.1 Nm
2 ➝ 4 mm
80°
0.5 ➝ 3 mm
70°
0.05 mm
2°
0.1 M
4
4
0.05 ➝ 1 mm
2°
0.1 M
4
4
4
4
4
Ø 3 - 3.5 - 4
M5
Ø3
M5
4
4
4
4
4
0.8 ➝ 5 N
4 ➝ 12 N
10 N
3 ➝ 10 N
6 mm
4 mm ; 6 mm
6 mm
10 ➝ 25 mm
3 mm
3 mm ; 3.5 mm
2.5 ➝ 4 mm
4.5 mm
8 ➝ 23 mm
2 mm
0.3 mm
1 mm
0.4 ➝ 1.2 mm
0.9 mm
1 mm
0.06 ➝ 0.20mm
10 M
4
0.1 M
4
4
1M
4
0.1 M
4
1M
4
4
M10 x 0.75 M12 x 0.75 ; M16 x 1 M8/M12/M14 x 0.75
4
4
6 ➝ 30 N
4
Ø3
M3
M12 x 0.75
4
4
4
4
4
4
-60 °C
+200 °C
d
4
-40 °C
+125 °C
(front side)
0.2 mm
M16 x 1
6N ; 15 N
4
Plastic
Class I
Class II
IP66
IP68 (4 m)
IP69
10 N
4
Plastic
Class Il
Class I
max. 6 bar
12 ➝ 30 N
4
6 x 21 mm
Aluminium ; Bronze Aluminium ; Bronze
or Inox steel
or Inox steel
4
4
4
4
4
4
4
M3
M10 x 0.75
4
4
4
M12 x 0.75
4
4
4
28 x 14 cut - out
4
4
4
4
4
4
UL
CCC/EAC
2
4
1
43x32x17
Form C
Linear
Rotary
Linear
Rotary
2
4
1
40x29x15
Form C
Irradiated environment
High pressure environment
2
4
1
27x17x12
or Form C
4
2 poles**
Housing material
ENVIRONMENT
83731
83732
83733
1
Positive opening operation
MECHANICAL
4
2
49x41x22
* Pending
** Consult us
The features presented in this selection guide represent the extent of performance of each Limit switch Series. Not all combinations of
characteristics are feasible at an individual product.
Please refer to relevant product sheet or consult our customer service. For more information see also the "Basic technical concepts".
Note: data contained in product sheets dated 2016 and before may differ from the features shown in this selection guide.
Update is in progress. Please contact us for confirmation.
Warning:
The product information contained in this catalogue is given purely as information and does not constitute a representation, warrantly or any form of contractual commitment. Crouzet Automatismes SAS and its
subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsability of the buyer to establish,
particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any
modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to
the sale of our products.
很抱歉,暂时无法提供与“83832101”相匹配的价格&库存,您可以联系我们找货
