D.C. geared motors
High quality, all-metal integral-type gearboxes
Basic speed range : 7.3 to 616 rpm
■ Torque rating : 5 Nm, for long life
■ Motors : maximum usable power 9 to 33 W
Types
Applications
80 815 0
80 815 0
80 815 0
12 V
24 V
48 V
2600
2600
2600
Nominal voltage
Motor-driven blinds and shutters
Opening and closing doors
Photocopiers : staplers, collators
Equipment for medical
rehabilitation
- X-ray equipment
- Agro-foodstuffs industry
- Motorised point-of-sale displays
Standard motor speed (rpm)
Output speeds (rpm)
2600
616
385
339.5
212
170
106
68
53
42.5
21
10.5
Ratios (i)
1800
426
266
235
147
118
73
47
37
29.4
14.7
7.4
Part numbers
4.22
6.75
7.66
12.25
15.31
24.5
38.28
49
61.25
122.5
245
Standard gearbox shaft : see dimensions
General characteristics
1
Made to order products,
available on request
Motor :
- other supply voltages
- shaft lengths at front and/or rear
- integrated interference suppression
82 830
- encoders
- other front and rear fixing plates
- "high power" motors
Gearboxes :
- special shaft
- special lubrication
- other reduction ratios
Motor
Gearbox
Maximum permitted torque on
gearbox for continuous rating
Axial load (dynamic)
Radial load (dynamic)
Maximum usable power
Nominal usable power
Gearbox case temperature rise
Weight
82 810 0
81 035 0
82 810 0
81 035 0
82 810 0
81 035 0
N.m
5
5
5
daN
daN
W
W
°C
g
6
6
10.3
9.4
45
820
6
6
9.5
8.7
46
820
6
6
9
8.2
45
820
Options : for standard products non stocked
Output shaft Ø 8 mm 79 290 064
Ball bearings on gearbox output shaft (81 035 5)
Nominal speed and torque curves
mN.m
The shaded zone represents the operating
range of the geared motor.
The horizontal line marks the maximum
torque available in continuous duty cycle for a
given life.
For higher torque ratings, service life will be
reduced.
5000
1000
100
1 2 5 10
Other information
For basic principles see pages 1/7.
1/32
rpm
100
500
24 V
48 V
12 V
24 V
48 V
2600
2600
2600
1800
1800
1800
Dimensions
2
80 815 0 - 80 805 0
3
4 fixing holes Ø 4.2
13
4
80 835 012
80 835 009
56
80 835 013
80 835 004
65,1 max.
80 835 002
80 835 003
80 835 014
80 835 015
80 835 008
80 835 006
80 835 005
80 835 016
80 835 017
80 835 018
82 800 0
81 035 0
82 800 0
81 035 0
82 800 0
81 035 0
82 830 0
81 035 0
82 830 0
81 035 0
82 830 0
81 035 0
5
5
5
5
5
5
6
6
16.3
15.7
44
920
6
6
17
15.6
40
920
6
6
16.7
15
45
920
6
6
33
27
50
1540
6
6
33
27
50
1540
6
6
33
27
50
1540
6,9
15
14,3
50,5
22,7 max.
(shaft pushed-in ←)
Types
80 815 0
80 805 0
22,7 max. (shaft pushed-in ←)
3,5
Lead length 200 mm
mN.m
1000
1000
Non stocked product : gearbox shaft 79 290 064
(shaft pushed-in ←)
73,5 max.
rpm
100
500
100
1 2 5 10
rpm
100
Ø 16±0,05
5000
Ø 8-0,022
mN.m
500
To order, specify :
Standard products
4
Part number
Example : D. C. geared motor - 80 835 012
Standard products,
non stocked
1
2
3
4
Type
Nominal voltage
Output speed
Standard speed
Example : D. C. geared motor 80 815 0 - 12 V - 2600 rpm - 170 rpm - output shaft 79 290 064
1/33
5
Option
± 0,05
56
17,5
65,1
13
142,5 max.
56
65,1 max.
16
Ø 8 - 0,022
15
7 across flat
L max (mm)
113.5
128.5
80 835 0
5
3,5
L max.
100
1 2 5 10
2 tags IEC 760
series 4.8 x 0.5
12 V
1
Ø 16±0,05
80 835 0
7 across flat
80 835 0
Ø 8-0,022
80 835 0
56
80 805 0
65,1 max.
80 805 0
17,5
80 805 0
1
很抱歉,暂时无法提供与“80835002”相匹配的价格&库存,您可以联系我们找货
