83843701
83843701
    CROUZET(高诺斯)
    检测开关 DC24V AC250V
83843701 数据手册
|   CROUZET.COM |  1 |   LIMIT SWITCHES |   10/2020 |   CROUZET.COM |  2 |   LIMIT SWITCHES |   10/2020 UNIVERSAL LIMIT SWITCHES 8384 standard › › › › Metal case 3 cables entries Heads have 4 possible positions at 90° All heads protected by nitrile boot and/or ring Main specifications Steel plunger Housing Action Metal Snap action General characteristics Sequence Snap action Reinforced lever with plastic roller 83 840 001 1-2 3-4 1-2 3-4 Mechanical characteristics Max. operating force (N) Max. operating torque (N.m) Max. total travel force (N) Max. total travel torque (N.m) Mechanical life (operations) Operating temperature (°C) Weight (g) Comments Accessories for 83 843 0 (see Dimensions - Accessories) Galvanized, passivated steel lever Thermoplastic roller Supplied with nut, washer and locating block loose General characteristics 0 2,5 Stepped adjustment roller lever 83 841 001 6 mm 0,7 10 22 107 -10 ➞ +70 310 1-2 3-4 1-2 3-4 0 3 0,7 15 25 107 -10 ➞ +70 310 Adjustable roller lever with idle-return 83 842 101 83 842 201 83 842 001 6 mm 1-2 3-4 1-2 3-4 0 6 1,5 8 15 107 -10 ➞ +70 310 Conformity to standards IEC / EN 60947-5-1, including Annex K for version with positive break operation Version Degree of protection IEC 60529 Connections Wire max. cross-section Electrical protection Cable entry Single-pole IP66 Saddle washer and screw M3.5 2 mm2 Internal earth terminal 3 entries for No. 13 sealing gland, 20.4 Ø, 1.411 pitch (supplied with 2 screw plugs) 4000 500 10 A300 = AC15 240 V 3 A / 120 V 6 A Alternating current Q150 = DC13 125 V 0.55 A Direct current Assigned impulse voltage (Uimp) V Assigned insulation voltage (Ui) V Thermal current (Ith) A Assigned working characteristics (EN 60 947.5.1) Adjustable roller lever 11 mm 1-2 3-4 1-2 3-4 0 6 11 mm 1-2 3-4 1-2 3-4 1,5 8 15 107 -10 ➞ +70 310 1,5 0 0.2 0.33 107 -20 ➞ +70 310 Operating curve for standard version 1 2 3 {~ L = 5 ms R cos 0,8 4 30V 2 250V~ 6 10 5 380V~ 2 5 10 2 4 10 0,1 0,2 Contact us 1-2 3-4 1-2 3-4 Curves 7 Product made to order 11 mm 25° 7° 0,5 1 2 5 1016 5 B C D E F Number of operations Resistive circuit Inductive circuit Mechanical life limit Current in Amps Flexible metal lever 83 845 001 60° 1-2 3-4 1-2 3-4 0 2,5 0,7 10 22 107 -10 ➞ +70 300 Function Four-terminal double break two-way contact element (form Za). The contacts must be of the same polarity. 5 Standard product 83 843 001 Principles 5 › -40 °C operating temperature (silicone version) › Steel roller levers › UL approval : consult us 6 8 15 107 -10 ➞ +70 310 10 Product adaptations 0 Steel roller plunger Rotary head, momentary action to right and left 83 846 001 6 mm 1-2 3-4 1-2 3-4 0 1.5 2.5 107 -10 ➞ +70 310 10° 3° 15° |   CROUZET.COM |  3 |   LIMIT SWITCHES |   10/2020 |   CROUZET.COM |  4 83 845 0 Dimensions |   LIMIT SWITCHES |   10/2020 83 846 0 Product Body 1 2 B Axis of heads C No. 13 sealing gland 83 840 0 83 841 0 83 842 0 Accessories 79 210 997 Adjustable in 8° steps 83 842 1 83 842 2 83 843 0 (for 83 843 0) 79 210 998 (for 83 843 0) Lever angular settings 1 1 B Block Adjustable in 90° steps B Block turned Adjustable in 6° steps Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products. |   CROUZET.COM |  1 |   LIMIT SWITCHES |   10/2020 |   CROUZET.COM |  2 |   LIMIT SWITCHES |   10/2020 UNIVERSAL LIMIT SWITCHES 8384 with positive break operation › › › › Metal case 3 cables entries Heads have 4 possible positions at 90° All heads protected by nitrile boot and/or ring Main specifications Steel plunger Housing Action Metal Snap action General characteristics Sequence Snap action Reinforced lever with plastic roller 83 840 701 1-2 3-4 1-2 3-4 Mechanical characteristics Max. operating force (N) Max. operating torque (N.m) Minimum positive opening force (N) Min. positive opening torque (N.m) Minimum total travel force (N) Minimum total travel torque (N.m) Mechanical life (operations) Operating temperature (°C) Weight (g) 0 2,5 0,7 10 10 22 107 -10 ➞ +70 310 4 6 mm 1-2 3-4 1-2 3-4 0 3 4,5 0,7 15 15 25 107 -10 ➞ +70 310 83 842 801 83 842 901 6 mm 1-2 3-4 1-2 3-4 0 6 9 11 mm 1-2 3-4 1-2 3-4 1,5 8 10 15 107 -10 ➞ +70 310 0 Version Degree of protection IEC 60529 Connections Wire max. cross-section Electrical protection Cable entry Single-pole IP66 Saddle washer and screw M3.5 2 mm2 Internal earth terminal 3 entries for No. 13 sealing gland, 20.4 Ø, 1.411 pitch (supplied with 2 screw plugs) 4000 500 2.5 C300 = AC15 240 V 0.75 A / 120 V 1.5 A Alternating current R300 = DC13 250 V 0.11 A / 125 V 0.22 A Direct current Conforms to IEC 60947.5.1 paragraph 8.34 1000 A at 250 VAC 0.5 < cos ϕ < 0.7 Fuse 10 AgG Product adaptations 1,5 11 mm 1-2 3-4 1-2 3-4 0 6 1,5 8 10 15 107 -10 ➞ +70 310 Curves Operating curve for positive break version 1 2 3 {~ L = 5 ms R cos 0,8 4 7 10 30V 5 250V~ 380V~ 2 6 10 5 2 5 10 2 4 › -40 °C operating temperature (silicone version) › Steel roller levers › UL approval : consult us Product made to order 9 8 10 15 107 -10 ➞ +70 310 5 Standard product 6 9 Rotary head, momentary action to right and left Steel roller plunger 83 843 701 11 mm 1-2 3-4 1-2 3-4 0 0.2 0.2 0.33 107 -20 ➞ +70 310 25° 45° 60° 7° 83 845 701 1-2 3-4 1-2 3-4 0 2,5 4 6 mm 0,7 10 10 22 107 -10 ➞ +70 300 Function Four-terminal double break two-way contact element (form Za) with positive break operation on NC contacts (1-2) according to IEC/EN60947-5-1 Annex K. The contacts must be of the same polarity. IEC / EN 60947-5-1, including Annex K for version with positive break operation Short circuit test Current peak Short circuit protection device Adjustable roller lever with idle-return Principles Conformity to standards Assigned impulse voltage (Uimp) V Assigned insulation voltage (Ui) V Thermal current (Ith) A Assigned working characteristics (EN 60 947.5.1) Adjustable roller lever 83 842 701 83 841 701 Comments Accessories for 83 843 7 (see Dimensions - Accessories) Galvanized, passivated steel lever Thermoplastic roller Supplied with nut, washer and locating block loose General characteristics Stepped adjustment roller lever Contact us 10 0,1 0,2 0,5 1 2 5 1016 5 B C D E F Number of operations Resistive circuit Inductive circuit Mechanical life limit Current in Amps |   CROUZET.COM |  3 |   LIMIT SWITCHES |   10/2020 Dimensions Product Body 1 2 B Axis of heads C No. 13 sealing gland 83 840 7 83 841 7 83 842 7 Adjustable in 8° steps 83 842 8 83 842 9 83 843 7 83 845 7 Accessories 79 210 997 (for 83 843 7) 79 210 998 (for 83 843 7) Lever angular settings 1 B Block Adjustable in 90° steps Block 1 must not be mounted the other way round Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
83843701 价格&库存
很抱歉,暂时无法提供与“83843701”相匹配的价格&库存,您可以联系我们找货
  • 1+1635.556801+211.99930
  • 25+1509.8453325+195.70470
