89750190
89750190
    CROUZET(高诺斯)
    CROUZET AUTOMATION - 89750190 - Probe, Temperature Sensor, Zone, Space, -10°C to 40°C, em4, Milleniu...
89750190 数据手册
››Millenium 3, Millenium Evo & em4 Accessories Temperature sensors ››Integrated converter: 0-10 Vc / 4-20 mA output for direct connection to the em4 and Millenium 3 analog inputs Zone/space probe Duct probe External probe Remote/submersible probe Specific Characteristics Description Range Accuracy Supply Protection casing Protection probe Code Zone/space probe -10 +40 °C See curve 24 V z IP30 - 89 750 190 Duct probe -10 +60 °C See curve 24 V z IP54 IP65 89 750 191 External probe -10 +40 °C See curve 24 V z IP54 IP65 89 750 192 Remote/submersible probe -10 +110 °C See curve 24 V z IP54 IP65 89 750 193 Accessories Description Accuracy Protection casing Code 316 stainless steel protective sleeve -20 +400 °C 16 bar 89 750 147 General characteristics Environmental characteristics Ambient characteristics 89 750 190: -10  +50 °C / 89 750 191 - 192 - 193: -30  +70 °C Ambient humidity 0  95 % RH no condensing Housing material ABS (flame retardant) Electrical characteristics Supply voltage 24 V z Output 0 10 V c / 4 - 20 mA self-detecting (not loop powered) I AUTOMATION.CROUZET.COM I 02 I em4, Millenium 3 Diagrams Dimensions (mm) 89 750 190 89 750 190 3,00% 3 1,50% 2 0,00% -10°C  Cut-outs made prior to delivery  Fixing holes  Total depth 27.8 mm  Accuracy  Temperature 89 750 191 89 750 191 0°C 10°C 20°C 30°C 40°C 2 4,00% 6 mm 150 mm 0,00% -10°C 0°C 10°C 20°C 30°C 40°C 50°C 60°C 2  Accuracy  Temperature 89 750 192 89 750 192 57 mm 70 mm % d'eereur (écart/pleine échelle) 103 mm 74 mm 2,00% 1,00% 50 mm 0,00% -10°C  Accuracy  Temperature 0°C 10°C 20°C 30°C 40°C 2 I AUTOMATION.CROUZET.COM I 03 I em4, Millenium 3 89 750 193 89 750 193 2,00% 1000 mm cable 150 6 1,00% 0,00% -10°C 0°C 10°C 20°C 30°C 40°C 50°C 60°C 70°C 80°C 90°C 100°C 110°C  Accuracy  Temperature Accessory 89 750 147 for 89 750 193  M4 screw Connections 89 750 190 89 750 191 / 89 750 192 / 89 750 193 OUT GND 24V OUT GND 24V OUT Auto-selecting 0-10 Vc or 4-20 mA (3-wire) output OUT Auto-selecting 0-10 Vc or 4-20 mA (3-wire) output GND Common 0V GND Common 0V 24V Supply +24 Va or Vc 24V Supply +24 Va or Vc 2
89750190 价格&库存
很抱歉,暂时无法提供与“89750190”相匹配的价格&库存,您可以联系我们找货
