89810908
89810908
    CROUZET(高诺斯)
    MOTOR89810024V4000RPMENCODE
89810908 数据手册
| | WWW.CROUZET-MOTORS.COM | | 10 | | DCmind BRUSH MOTORS DCmind: DC DIRECT-DRIVE BRUSH MOTORS Ø 42 mm - 20 W › Silent motor › 12 V and 24 V built in EMC filter class B › Excellent efficiency › Long life › IP65 › In accordance with UL - CE - ROHS regulations Part numbers T yp e Voltage References Option: IP65 level Option: holding brake 0.25 Nm, 24 Vc Option: 2 channels encoder 1000 pulses/revolution, 5 Vc 12 V 24 V 48 V 89810 12 Vc 89810 24 Vc 89810 48 Vc 89810007 89810507 89810907 89810008 89810508 89810908 89810003 89810503 89810903 4000 0.11 4100 0.07 2920 50 15 1 64 2980 50 16 0.53 61 3300 30 10 0.6 72 3400 31 11 0.35 65 Class E 35 20 190 3.3 7. 3 6 56 0.8 17 75 340 8 4000 200 Class E 35 19 180 1.7 28 22 109 0.8 18 75 340 8 4000 200 No-load characteristics Speed (rpm) 4200 Absorbed current (A) 0.26 Nominal characteristics Speed (rpm) 2900 Torque (mNm) 50 Output power (W) 15 Absorbed current (A) 2.1 Efficiency (%) 60 Maximum efficiency characteristics Speed (rpm) 3500 Torque (mNm) 27 Output power (W) 10 Absorbed current (A) 1.26 Efficiency (%) 65 General characteristics Insulation conforming to IEC60085 Class E Noise level (dBA) 35 Max. output power (W) 17 Starting torque (mNm) 158 Starting current (A) 6.1 Resistance (Ω ) 2 Inductance (mH) 1.3 Torque constant (mNm/A) 27 Electrical time constant (ms) 0.7 Mechanical time constant (ms) 20 75 Inertia (g.cm2 ) Weight (g) 340 Commutator segments 8 Service life (h) 4000 Wires length (mm) 200 Ball bearing Comments IP65 level except for the output shaft. Encoder and brake options are IP20. Product adaptations, contact us › Special output shaft › Shaft with pinion, pulley, worm gear › Special supply voltage › Other wire length › Optical or Hall effect encoder - 1 or 2 channels › Specific motor mounting flange › Special motor connectors › IP67, IP69K Product made to order | | WWW.CROUZET-MOTORS.COM | | 11 | | DCmind BRUSH MOTORS Curves 89810007 - 89810507 - 89810907 89810008 - 89810508 - 89810908 4 500 7 4 500 3,5 4 000 6 4 000 3 3 500 4 2 500 2 000 3 1 500 A 2 500 2 2 000 1,5 A 1 500 2 1 000 500 500 0 0 0 0,05 0,1 0,15 1 1 000 1 0 2,5 3 000 rpm 3 000 rpm 3 500 5 0,5 0 0,05 Nm 0,1 Nm 89810003 - 89810503 - 89810903 4 500 2 Speed (rpm) 4 000 1,8 3 500 1,6 Current (A) rpm 1,2 2 500 1 2 000 Torque at nominal Torque at maximum efficiency A 0,8 1 500 0,6 1 000 0,4 500 0 3 1,4 3 000 0,2 0 0,05 0,1 0,15 0,2 0 Nm Dimensions (mm) ’ 22°30 2 x 200 mm AWG20 ø42 2 ± 0.1 25 ± 0.4 1 2 1 2 x M3 at 180° depth 5 over Ø 32 2 2 x Ø 2.75 at 120° depth 5 over Ø 32 Options E nc ode r Ø38 36,3 Ø37 -0.004 3,5 max 71,4 max Holding brake 0.25 Nm 6 -0.009 -0.01 22-0.05 -0.01 22 -0.09 2 ± 0.07 0,15 0,2 0
89810908 价格&库存
很抱歉,暂时无法提供与“89810908”相匹配的价格&库存,您可以联系我们找货
