26532720N
26532720N
    CROUZET(高诺斯)
    CROUZET - 26532720N - Relay Accessory, Pre-Cut Thermal Pad
26532720N 数据手册
| | 10/2020 ››GN Series Classic Solid State Relays Panel Mount - AC Output Single Phase ››Output current of 10, 25, 50, 75, 100 and 125 Amps ››Output voltage of 24-280 Va and 48-660 Va ››Control voltage of 4-32 Vc, 18-36 Vz, 20-265 Va and 90-260 Va ››Zero cross or instantaneous (resistive or inductive loads) ››Integrated IP20 touch-safe removable covers ››Built-in overvoltage protection (only Zero Cross) ››LED input status indicator Zero Cross Version Instantaneous Version Product Selection - Zero Cross (Resistive Loads) Rated Load Current 10A Output Voltage 25A 50A 75A 100A 125A 24-280 Va 24-280 Va 48-660 Va 48-660 Va 48-660 Va 48-660 Va 48-660 Va 84137000N 84137010N 84137110N 84137120N 84137130N 84137140N 84137180N 84137131N 84137141N 84137181N Control Voltage 4-32 Vc 84137012N 18-36 Vz 84137001N 20-265 Va 84137011N 84137122N 84137111N 84137121N Product Selection- Instantaneous (Inductive Loads) Rated Load Current 25A Output Voltage 50A 24-280 Va 75A 48-660 Va 48-660 Va Control Voltage 4-32 Vc 84137210N 84137320N 90-260 Va 84137211N 84137321N 84137330N PART NUMBERING SYSTEM Series 8413: Single Phase 8413 Output Voltage 0: 280 Va / Zero Cross 1: 660 Va / Zero Cross 2: 280 Va / Random 3: 660 Va / Random 7 0 1 Cover/Layout 7: Included Generation N: New Generation 1 Output Current 0: 10 A 1: 25 A 2: 50 A 3: 75 A 4: 100 A 8: 125 A N Control Voltage 0: 4-32 Vc 1: 20-265 Va 2: 18-36 Vz Do you need an adapted or customized solution? Contact us on www.crouzet.com Description: Crouzet Solid State Relays are designed to be used in almost any application, offering very long life expectancy and are easy to install, easy to use, robust and multipurpose. RÉFÉRENCEMENT For more information about Crouzet’s Solid State relays, please visit www.crouzet.com. Série 8413: Monophasé Tension de sortie 0: 280 Va / Synchrone 1: 660 Va / Synchrone 2: 280 Va / Instantanée Génération N: Nouvelle génération | | WWW.CROUZET.COM || 2 | | GN Series | | 10/2020 Accessories Type Description Heatsink 0.9 °C/W Thermal Resistance 26532752N Heatsink 1.1 °C/W Thermal Resistance 26532753N Heatsink 1.2 °C/W Thermal Resistance 26532754N Heatsink 1.75 °C/W Thermal Resistance 26532755N Heatsink 2.2 °C/W Thermal Resistance 26532756N Adapter DIN Rail 26532764N Thermal Pad Pre-cut Thermal Pad 26532720N Thermal Pad Self-Adhesive Thermal Pad 26532722N Screws Screw Mounting Kit 26532001 Thermal Grease Thermal Grease for Heatsink mounting 26532003 Part-Number Output Specifications(1) Description 10A 25A 50A Maximum Load Current [Arms](3) 10 25 Minimum Load Current [mArms] 5 Min / Max Operating Voltage (47-63Hz) [Vrms] 24-280 Va 48-660 Va Transient Voltage [Vpeak](2)(Random version) 600  1200  (600) (1600) 75A 50 75 100A 125A 100 125 Maximum Off-State Leakage Current @ Rated Voltage [mArms] 1  (Random version) (5) Minimum Off-State dV/dt @ Maximum Rated Voltage [V/µsec] 500 1 Second Surge Current (Apk. Ta=25 °C) 50/60 Hz 45 100 125 230 347 613 Maximum 1 Cycle Surge Current (50/60 Hz) [Apeak] Typ @ 50 Hz 120/126 (min) 270/284 (min) 280/_ (min) 700/_ (min) 1100/_ (min) 2000/_ (min) 160 (typ) 340 (typ) 500 (typ) 750 (typ) 1200 (typ) 2100 (typ) 1.23  1.25  1.38  1.34  (1.08) (1.37) (1.37) (1.34) 1.7  0.55  0.4  0.3  (0.7) (0.7) (0.4) (0.3) 487/600 720/1250 2450/2800 6000/7200 (512/882) (512/882) (2450/2500) (6000/7200) 1.3  2.08  0.84  0.52  (2.6) (2.6) (0.84) (0.52) Maximum On-State Voltage Drop @ Rated Current [Vpeak] (Random version) 1.2 Thermal Resistance Junction to Case (Rjc) [°C/W] (Random version) 2.3 Maximum 1/2 Cycle I² t for Fusing @ 50 Hz (min. / typical) [A² sec] (Random version) 78/128 Minimum Heat Sink for Rated Current @ 40 °C [°C/W] (Random version) 5.3 1.45 1.15 0.25 6000/7200 20000/ 22000 0.23 0.29 Input Specifications Description Input Voltage Range 4-32 Vc 4-32 Vc (4) 18-36 Vz 18-36 Vz Maximum Reverse Voltage -32 Vc N/A Minimum Turn-On Voltage 3 Vc 18 Vz 20-265 Va 20-265 Va 90-260 Va 90-260 Va 90 Va Must Turn-Off Voltage 1 Vc 5 Vz 5 Va Minimum Input Current (for on-state) 10 mA 5 mA AC / 4 mA DC 6.5 mA 10 mA Maximum Input Current [mA] 14 mA Nominal Input Impedance [Ohms] Current Limited Maximum Turn-On Time [msec] 1/2 Cycle(5) Maximum Turn-Off Time [msec] 1/2 Cycle (5) < 0.1 | | WWW.CROUZET.COM || 3 | | GN Series | | 10/2020 General Specifications Description 10A 25A Dielectric Strength, Input to Output (50/60 Hz) 4000 Vrms Dielectric Strength, Input/Output to Ground (50/60 Hz) 2500 Vrms Minimum Insulation Resistance (@ 500 Vc) 109Ω Maximum Capacitance, Input/Output 0.8 pF Ambient Operating Temperature Range -40 to 80 °C Ambient Storage Temperature Range -40 to 100 °C Weight (typical) 80 g Housing Material UL94 V-0 Baseplate Material Aluminum Input Terminal Screw Torque Range (in-lb/Nm) 11-18 /1.2-2.0 Load Terminal Screw Torque Range (in-lb/Nm) 18-26 / 2-3 SSR Mounting Screw Torque Range (in-lb/Nm) 11-16 /1.2-1.8 Humidity per IEC60068-2-78 40-85 % LED Input Status Indicator Green MTBF (Mean Time Between Failures) at 40 °C ambient temperature(5)(years) 72 MTBF (Mean Time Between Failures) at 60 °C ambient temperature(5)(years) 46 50A 75A 100A 125A 4000 Vrms General Notes (1) All parameters at 25 °C unless otherwise specified (2) Output will self trigger between 450-600 Vpk not suitable for capacitive loads (3) Heat sinking required, see derating curves (4) Increase minimum voltage by 1 V for operations from -20 to -40 °C (5) All parameters at 50 % power rating and 100 % duty cycle (contact tech support for detailed report) Diagrams Wiring GN Recommended Wire Size AC V TERMINALS 1 1 (a) 2 (a) 4 (-/a) WIRE SIZE SOLID Load Terminal Screw Torque (N.m) Input 18..14 AWG (0.75..2.5 mm²) 2 x 18..14 AWG (0.75..2.5 mm²) 18..14 AWG (0.75..2.5 mm²) 2 x 18..14 AWG (0.75..2.5 mm²) 1.2 - 2 Output 16..8 AWG (1.5..10 mm²) 2 x 16..8 AWG (1.5..10 mm²) 16..8 AWG (1.5..6 mm²) 2 x 16..10 AWG (1.5..6 mm²) 2-3 3 (+/a) For the random (instantaneous) models, external overvoltage protection is recommended: TVS Diode B STRANDED | | WWW.CROUZET.COM || 4 | | GN Series | | 10/2020 Diagrams Equivalent Circuit Block Input current vs Input Voltage GN Series 4-32 Vc control (Thyristors) - All out 660 Va Standard Regulated DC inputs Current Limiter 14 12 OUTPUT 10 Input Current (mA) INPUT 8 6 4 2 0 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 20 22 24 26 28 30 32 Input Voltage (V) Input current vs Input Voltage GN Series 4-32 Vc control (Triac) - 10 A /25 A (280 Va) Standard Regulated DC inputs Current Limiter 14 12 OUTPUT 10 Input Current (mA) INPUT 8 6 4 2 0 0 2 4 6 8 10 12 14 16 18 Input Voltage (V) Input current vs Input Voltage GN Series 18-36 Vz control Standard Regulated AC/DC inputs Current Limiter 7 6 OUTPUT Input Current (mA) INPUT 5 4 3 2 1 0 0 20 40 60 80 100 120 140 160 180 200 220 240 260 280 Input Voltage (V) Input current vs Input Voltage GN Series 20-265 Va control Standard Regulated AC inputs Current Limiter 7 6 OUTPUT Input Current (mA) INPUT 5 4 3 2 1 0 0 20 40 60 80 100 120 140 160 180 200 220 240 260 280 Input Voltage (V) | | WWW.CROUZET.COM || 5 | | GN Series | | 10/2020 Input current vs Input Voltage GN Series 4-32 Vc control instantaneous Standard Regulated DC inputs Current Limiter 14 12 OUTPUT 10 Input Current (mA) INPUT 8 6 4 2 0 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 Input Voltage (V) Input current vs Input Voltage GN Series 90-260 Va control instantaneous Standard Regulated AC inputs Current Limiter 9 INPUT 8 OUTPUT 7 Input Current (mA) 6 5 4 3 2 1 0 0 20 40 60 80 100 120 140 Input Voltage (V) Diagrams Dimensions (mm) GN front view GN side view 28 2 M5 3 47,6 59,4 16,3 29,1 Ø4,7 44,5 (±0,3) 4,7 25,4 2 M4 160 180 200 220 240 260 | | WWW.CROUZET.COM || 6 | | GN Series | | 10/2020 Curves Surge Current Information 150 300 125 250 100 200 Itsm (Apeak) GN - 25 A Itsm (Apeak) GN - 10 A 75 50 25 0 150 100 50 0,01 0,1 T (s) 1 0 10 0,01 No Repetitive Surge Current Repetitive Surge Current GN - 75 A 800 1200 Itsm (Apeak) Itsm (Apeak) 1 10 1 10 1 10 900 500 400 300 800 700 600 500 400 300 200 200 100 100 0 0,01 0,1 T (s) 1 10 0,01 No Repetitive Surge Current Repetitive Surge Current 0,1 T (s) No Repetitive Surge Current Repetitive Surge Current GN - 100 A GN - 125 A 1200 2200 1100 2000 1000 1800 900 1600 800 Itsm (Apeak) Itsm (Apeak) 10 1000 600 1400 700 1200 600 1000 500 400 800 600 300 200 400 100 200 0,01 0,1 T (s) 1 0 10 0,01 No Repetitive Surge Current Repetitive Surge Current 0,1 T (s) No Repetitive Surge Current Repetitive Surge Current GN - 25 A Instantaneous GN - 50 A Instantaneous 350 800 300 700 600 Itsm (Apeak) 250 Itsm (Apeak) 1 1100 700 0 T (s) No Repetitive Surge Current Repetitive Surge Current GN - 50 A 0 0,1 200 150 100 500 400 300 200 50 100 0 0 0,01 0,1 No Repetitive Surge Current Repetitive Surge Current T (s) 1 10 0,01 0,1 No Repetitive Surge Current Repetitive Surge Current T (s) | | WWW.CROUZET.COM || 7 | | GN Series | | 10/2020 GN - 75 A Instantaneous 1200 1100 1000 Itsm (Apeak) 900 800 700 600 500 400 300 200 100 0 0,01 0,1 1 T (s) 10 No Repetitive Surge Current Repetitive Surge Current Curves Thermal Derating Curves GN - 10 A GN - 25 A 14 GN - 50 A 30 55 50 12 25 45 10 40 20 35 6 4 Current (Arms) Current (Arms) Current (Arms) 8 15 10 2 5 0 0 30 25 20 15 10 5 0 10 20 30 40 50 60 70 80 0 0 10 20 Ambient Temperature (°C) 5 30 3 3 2,2 2,2 2 C°/W 70 65 60 55 45 Current (Arms) Current (Arms) 50 40 35 30 25 20 15 10 5 20 30 40 50 60 70 80 110 105 100 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 80 1,1 1 1,5 0 10 20 1,2 0,9 0,7 0,5 1,5 1,75 1,5 2 30 40 50 60 70 80 1,2 1,1 1 0,9 0,7 0,5 10 60 70 80 2 1,75 C°/W 0 10 20 30 1,1 0,9 1,75 2,2 40 50 60 70 80 1 0,9 0,7 0,5 0,3 55 50 45 25 20 15 40 35 30 25 20 15 10 5 0 0 10 20 30 40 50 60 70 80 0 10 Ambient Temperature (°C) 1,5 0,9 60 Ambient Temperature (°C) 2,2 0,7 65 30 0 3 1 70 5 50 80 75 10 5 70 80 Current (Arms) 15 60 GN - 75 A Instantaneous 35 Current (Arms) Current (Arms) 20 50 C°/W 40 40 1,5 1,2 45 30 135 130 125 120 115 110 105 100 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 0,3 50 25 40 Ambient Temperature (°C) 55 20 30 Ambient Temperature (°C) C°/W GN - 50 A Instantaneous 30 10 20 C°/W GN - 25 A Instantaneous 0 10 Ambient Temperature (°C) C°/W 0 0 GN - 125 A Ambient Temperature (°C) 1,75 70 Current (Arms) 75 10 60 GN - 100 A 80 0 50 C°/W GN - 75 A 0 40 Ambient Temperature (°C) 2 1,5 1 0,7 C°/W 0,9 20 30 40 50 60 70 80 Ambient Temperature (°C) 1,75 2,2 1,75 1,5 1,2 0,9 0,7 0,5 C°/W Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
26532720N 价格&库存
很抱歉,暂时无法提供与“26532720N”相匹配的价格&库存,您可以联系我们找货
