| 06/2022
› GND Board Series
SIP Solid State Relays
PCB Mount – DC Output
› Output Current of 4 or 10 Amps
› Output Voltage of 2-60 Vc, 7-36 Vc
› Control Voltage of 4-10 Vc, 4-30 Vc, 10-30 Vc
› Classic SIP package for Printed Circuit Boards
› DC Switching
› CE and UKCA Compliance
› Built-in Output Overvoltage Protection
GNDB4D2D
Product Selection - DC Switching (DC Loads)
Rated Load Current
10A
4A (9)
Output Voltage
2-60 Vc
7-36 Vc
Control Voltage
GNDB4D2D
4-30 Vc
4-10 Vc
GNDB10D1E
10-30 Vc
GNDB10B1E
PART NUMBERING SYSTEM
Part Number System
GND Board
Series
GNDB: GNDB Series
GNDB
Control Voltage
D1: 4-10 Vc
D2: 4-30 Vc
B1: 10-30 Vc
4
D2
Output Current
4: 4 A
10: 10 A
D
Output Voltage
D: 2-60 Vc | DC Switching
E: 7-36 Vc | DC Switching
RÉFÉRENCEMENT
Série
GNDB: Série GNDB
GNDB
Tension de commande
D1: 4-10 Vc
D2: 4-30 Vc
B1: 10-30 Vc
4
D2
D
Do you need an adapted or customized solution? Contact us on www.crouzet.com
Description:
Courant de sortie
4: 4 A
Tension de sortie
D: 2-60 Vc | Commutation CC
Crouzet Solid State Relays are designed
to be used in almost anyE:application,
offering very long life expectancy and are easy to install, easy to use,
10: 10 A
7-36 Vc | Commutation CC
robust and multipurpose.
For more information about Crouzet’s Solid State relays, please visit www.crouzet.com.
NOMENCLATURA
| WWW.CROUZET.COM
| 2
| GND Board Series
| 06/2022
Output Characteristics (1)
Description
10A
4A (9)
Minimum Load Current [mArms]
5
0.1
1 Second surge current @ Ta=25 °C [Apeak]
10
N/A
Maximum 1 Cycle Surge Current [Apeak]
10
100 @t=10ms
Maximum On-State Voltage Drop @ Rated Current [Vpeak]
1.6
0.2
1.36
Thermal Resistance Junction to Case (Rjc) [°C/W]
1.66
Minimum Heat Sink for Rated Current @ 40 °C [°C/W]
No heatsink
Operating Voltage [Vrms]
2-60 Vc
Transient Voltage [Vpeak]
7-36 Vc
60
(2)
Maximum Off-State Leakage Current @ Rated Voltage
[mArms]
1
0.1
Minimum Off-State dv/dt @ Maximum Rated Voltage [V/µsec]
200
N/A
Minimum Power Factor
GNDB4D2D: 0.45 but Overvoltage (Varistor/Diode) and free-wheel diode
protection required
GNDB10D1E: 0.45 but free-wheel diode protection required
GNDB10B1E: 0.45
Input Characteristics (1)
Control Voltage Range
4-30 Vc
4-10 Vc
10-30 Vc
Part Numbers
GNDB4D2D
GNDB10D1E
GNDB10B1E
Maximum Reverse Voltage
-30 Vc
-10 Vc
-30 Vc
Minimum Turn-On Voltage
3 Vc
Must Turn-Off Voltage
1 Vc
Minimum Input Current (for on-state) [mA]
2
7 Vc
7
6
Maximum Input Current [mA]
30
32
30
Nominal Input Impedance [Ohms]
1000
270
1000
Maximum Turn-On Time [msec]
0.2
0.01
Maximum Turn-Off Time [msec]
0.8
0.15
General Characteristics
Description
Dielectric Strength, Input to Output (50/60 Hz) [V]
2500
Dielectric Strength, Input/Output to Ground (50/60 Hz) [V]
N/A
Minimum Insulation Resistance (@ 500 Vc) [Ohms]
109
Maximum Capacitance, Input/Output [pF]
8
Ambient Operating Temperature Range [°C]
10A
4A (9)
(7)
2500
-40 to 80
Ambient Storage Temperature Range [°C]
-40 to 100
Weight (typical) [g]
20.5
Housing Material
UL94 V-0
Baseplate Material
N/A
Input Terminal Screw Torque Range [in-lb/Nm]
N/A
Load Terminal Screw Torque Range [in-lb/Nm]
N/A
SSR Mounting Screw Torque Range [in-lb/Nm]
N/A
Humidity per IEC60068-2-78 [%]
40-85
LED Input Status Indicator
No LED
MTBF (Mean Time Between Failures) at 40 °C ambient
temperature [years] (8)
69
42
MTBF (Mean Time Between Failures) at 60 °C ambient
50
28
MTTFd [years]
313
138
15
Ceramic Substrate
| WWW.CROUZET.COM
| 3
| GND Board Series
| 06/2022
General Notes
(1)
All parameters at 25 °C unless otherwise specified
(2)
Output will self trigger between 450-600 Vpk not suitable for capacitive loads
(7)
AC models operating range is -20 to 80 °C
(8)
All parameters at 50 % power rating and 100 % duty cycle (contact tech support for detailed report)
(9)
4 A at 20°C; 3.5 A at 40°C
Diagrams
Wiring
GND Board Series
4(-)
3(+)
2(-) 1(+)
L
O
A
D
1
B
DC
Protection Equipment: Short circuit protection
GNDB4D2D: it is recommended to add an overvoltage protection
Diagrams
Equivalent Circuit Block
GNDB4D2D, GND Board Series 4-30 Vc control; 2-60 Vc output DC switching (DC Loads)
Input Current vs Input Voltage
Standard Regulated DC inputs
30
4-
INPUT
3+
OUTPUT
Input Current (mA)
25
1+
2-
10
5
4
6
8
10
12
14
16
18
24
26
28
30
Input Voltage (V)
4-
INPUT
3+
1+
OUTPUT
2-
Input Current (mA)
GNDB10D1E, GN Board Series 4-10 Vc control; 7-36 Vc output DC switching (DC Loads)
36
34
32
30
28
26
24
22
16
14
12
10
8
6
4
2
2
3
4
5
6
Input Voltage (V)
7
8
9
10
| WWW.CROUZET.COM
| 4
| GND Board Series
GNDB10B1E, GN Board Series 10-30 Vc control; 7-36 Vc output DC switching (DC Loads)
Input Current (mA)
1+
4-
OUTPUT
INPUT
3+
| 06/2022
2-
30
28
26
24
22
16
14
12
10
8
6
4
2
4
6
8
10
12
14
16
18
24
26
28
30
Input Voltage (V)
Diagrams
Dimensions (mm)
GNDB4D2D
GNDB10D1E - GNDB10B1E
7,6 ± 1
25,4
24,5
43,6
4x Ø1
7,63 ± 1
7,62 ± 1
6,4 ± 1
10,16 ± 1
12,7 ± 1
7,83 ± 1
10,2 ± 1
5,08 ± 1
6,3 ± 1
10,16 ± 1
5,08 ± 1
43,2
4,57 ± 1
4x Ø1
12,7 ± 1
Curves
Thermal Derating Curves
GNDB4D2D
12
4,5
4
10
3,5
8
Current (A)
Current (A)
3
2,5
2
1,5
6
4
1
2
0,5
40
50
60
Ambient Temperature (°C)
70
80
90
100
40
50
60
70
80
90
| WWW.CROUZET.COM
| 5
| GND Board Series
| 06/2022
Standards & Electromagnetic Compatibility Specfification
EN61000-4-4 Immunity to fast transients / bursts
EN61000-4-5 Immunity to surges
Standards
L508
Warning:
The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Crouzet and its subsidiaries reserve the right to
modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate
tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction
with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products.
很抱歉,暂时无法提供与“GNDB10D1E”相匹配的价格&库存,您可以联系我们找货
