82924033
82924033
    CROUZET(高诺斯)
    STEPPER MOTOR PM GEARED UNI 6.3V
82924033 数据手册
82 924 033 Series ratio 40 - 4 phases 829240 With flat type Pushed shaft Standard With flat type 4 -0,018 +0 13,2 max 8 -0,03 +0 3,2 3,5 -0,2 +0 8 With hole type 82924033 ratio 40 - 4 phases Hole diam. 3.2mm Shaft ref. Type φA B φC D E F φG H Round type Product Code Family Type Definition 82 924 033 82924 Stepper gearmotor Motor 82920 1,7W 500 rpm nominal 7,5 °/t 48 step/t + Gearbox Ovoide ratio 40 4 phases 10,7 Ohms/phase General characteristics Motor characteristics (1) Command sequence 829200 Motor type Number of phases W Input power Ohm Phase resistor mH Phase inductance A Phase current mNm Maintain torque Vcc Voltage per phase deg Step angle % Step precision g.cm² Rotor inertia mNm Max. detent torque g Weight Output leads UL style 1569 105°C 300V - 6 leads AWG24 Ohm Vcc W rpm Nm A g dBA B 46 25,8 0,99 10,2 0,93 Clip CEI60335 CEI60085 CEI60529 CEI60068-2-1/2 Vac class IP °C °C C D 92 138 38,7 51,6 1,17 1,30 11,7 11,7 0,95 1,06 0,28 140 35 Screws 600 B 40 -30 -> +70 -40 -> +80 Step - (3) Continuously rated torque, zero radial and axial loads (4) Max torque for continuous operation at 20 ° C, decrease this value for higher ambient temperature 4 - - Ovoide (6mm from front face) Nm N N g 81021 40 standard brass 0,5 80 10 275 400 500 600 15,63 18,75 1,4 1,2 1 0,8 0,6 0,4 0,2 0 Power (W) Notes 3 - 1,6 2011/65/UE 2014/30/UE Values without tolerance, are average production values. (1) Cold motor, 20 ° C ambient temperature, full speed (2) Without taking in count the torque gearbox limits, check gearbox characteristics 2 Gearbox Charateristics 250 mm +- 10 A 0 12,9 0,55 7,0 0,75 1 - 1 2 3 4 5 Type ratio Shaft Front bearing Continuous max. torque Max. Radial force Max. axial force Weight Torque (Nm) Gearmotor characteristics (1) (2) Additional resistor /phase Voltage (phase + add. resistor) Max. output power Speed at max. output power Torque at max. output power Max. current Weight Noise level Motor fixing on gearbox Miscelaneous (1s/2mA/50Hz) Dielectric Motor insulation Degree of protection Temperature range Storage temperature Approvals ROHS EC Drive sequence for Clock Wise rotation 4 7,5 46 24 0,28 70 12,9 7,5 5 18,8 6 210 0 100 200 300 0 3,125 6,25 9,375 12,5 300 400 500 600 9,375 12,5 15,63 18,75 700 Hz 21,88 RPM 2 1,8 1,6 1,4 1,2 1 0,8 0,6 0,4 0,2 0 0 100 0 3,125 A 200 6,25 B C D 700 Hz 21,88 RPM C+ (over-speed) D+ (over-speed) Max. continuous gearbox torque Specifications subject to change without notice. Updated 15/09/2016 Crouzet Automatismes 12, rue Jean Jullien-Davin 26902 Valence CEDEX 9 France www.crouzet-motors.com Series 829240 Stepper gearmotor Data sheet
82924033 价格&库存
很抱歉,暂时无法提供与“82924033”相匹配的价格&库存,您可以联系我们找货
