TMR 48 analog timers
➜ TMR 48
Multi-function or mono-function
Multi-range from 0.02 s to 300 h
Multi-voltage 12 to 240 VDC / 24 to 240 V AC
Time setting displayed on dial
2 changeover relays 5 A / 250 VAC
Display of power and output states by 2 LEDs
Housing 48 x 48 mm
Specifications
Type
TMR 48 U
Functions
A, B, C, W, G, Ac, Bw
Relay outputs
2 timed changeover
Max. breaking current
5 A / 250 VAC
TMR 48 A
A
2 timed changeover
5 A / 250 VAC
TMR 48 X
A1, A2, H1, H2, Q1, Q2, D-Di
TMR 48 L
L, Li, G, Gi
2 changeover or 1 timed 5 A / 250 VAC
and 1 instantaneous
2 timed changeover
5 A / 250 VAC
3
Supply voltage
12 ➞ 240 VDC
24 ➞ 240 VAC
12 ➞ 240 VDC
24 ➞ 240 VAC
12 ➞ 240 VDC
24 ➞ 240 VAC
12 ➞ 240 VDC
24 ➞ 240 VAC
Connection
Plug-in 11 pin
Part Number
88 886 016
Plug-in 8 pin
88 886 106
Plug-in 8 pin
88 886 116
Plug-in 11 pin
88 886 516
Accessories
Accessories
Part Number
11-pin connector base
SA11NN
8-pin connector base
SA8NN
Spring clips (packet of 2)
[For use with socket part numbers 25 622 808 and 25 622 130 only]
face plate or housing in black, gray, or other color
Part Number
S11
S08
Part Number
25 622 080
25 622 130
79 237 740
consult us
General characteristics
Supply voltage Un
Operating range
Frequency
Power consumption
Timing ranges (14 available options)
Repetition accuracy
Temperature drift according to CEI/EN 61812
Display accuracy
Minimum pulse duration START
Minimum pulse duration GATE
Minimum pulse duration RESET
Output specification
Nominal rating
Nominal insulation voltage
Rated power (resistive load)
Minimum current
Electrical life at I max. 250 V AC resistive (number of operations)
Mechanical life (operations)
Function and use
Display of output state by 2 LEDs
Operating temperature range (°C)
Storage temperature range (°C)
Breakdown voltage
Protection class (IEC 60529) - Panel-mounted
Protection class (IEC 60529) - Casing
Material housing
Weight (g)
12 ➞ 240 VDC
24 ➞ 240 V AC
± 10 % DC supply
- 15 % / + 10 % AC supply
50 / 60 Hz
4.8 VA / 230 VAC
2.5 VA / 110 VAC
1.1 VA / 24 VAC
0.5 W / 24 VDC
0.8 W / 12 VDC
0,02 ➞ 1,2 s 0,2 ➞ 12 min. 0,2 ➞ 12 h
0,05 ➞ 3 s
0,5 ➞ 30 min. 0,5 ➞ 30 h
0,2 ➞ 12 s
2 ➞ 120 min.
2 ➞ 120 h
0,5 ➞ 30 s
5 ➞ 300 min.
5 ➞ 300 h
2 ➞ 120 s
5 ➞ 300 s
± 0.5 % of full scale at 25°C (typical with constant parameters)
± 0.05 % of full scale
± 5 % of full scale at 25°C
25 ms
60 ms
60 ms
50 ms
2x5A
250 VAC
2000 VA
10 mA
105
30 x 106
Green : power ON, flashing during timing
Yellow : ON output ON, OFF output OFF
-20 ➞ +55
-40 ➞ +70
2 KV
IP 50
IP 40
self-extinguishing
140
Products and specifications subject to change without notice.
1
Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com
Dimensions
35 mm DIN rail base with clips 79 237 739
Panel cut-out
5
45
18,5
3,5
5
4
3
32
12
14
1
15
3,5
45
6
34
68,2
52
7,8
1,1
35
6,4
1,5
B
31
4
3
7
8
1
2
24,2
30
38
6,8
48
39
44,4
TMR 48 U / A / X / L
15,5
64,5
96,8
48
Connections
TMR 48 U
TMR 48 A
TMR 48 X
U
U
4
3
Reset
R1
Start
6
5
Gate
2
7
3
1
8
4
R1
R2
2
11
5
6
R2
3
7
2
8
5
6
R1
1
R2
7
8
10
1
4
6
9
U
5
TMR 48 L
U
Gate
7
8
4
3
R1
R2
1
2
2
6
off start
on start
9
10
2
11
7
L
G
Time Function Curves
Function A (TMR 48 A)
Delay on make (delay on energisation)
Function A1
U (2
7
7
2(5
6 8
2(5
6 8
R2 ( 5
6 8
1(1
3 4
1(1
3 4
R1 ( 1
3 4
U (2
U (2
Function A2
T
T
T
Function H1
Timing on energisation - interval
U(2
R2 ( 5 6
R1 ( 1
8
3 4
7
R1 ( 1
T
T
T
T
Function H2
U (2
R2 ( 5 6
8
3 4
7
7
Function Q1
Star-delta
U (2
T
T
T
7
R2 ( 5
6 8
R1 ( 1
3 4
T Ti
T
T Ti
2
Function Q2
Star-delta 2
U (2
Function D-Di
Cyclic timing : repeat cycle : symetric recycler
7
R2 ( 5
6 8
R2 ( 5
6 8
R1 ( 1
3 4
R1 ( 1
3 4
U (2
T
T Ti
7
T T
T Ti
T T
Function A (TMR 48 U)
U (2
Function B
Timing on impulse : single shot
10 )
U
6
Start
Gate ( 2
5
Reset ( 2
7
R1 ( 1
3 4
R2 ( 8
9 11 )
Start ( 2
T
t1
T
t2
T
T
2 10
2 6
Gate
2 5
Reset
2 7
R1 ( 1
3 4
R2 ( 8
9 11 )
T
T
Function C
Timing after impulse - Delay on break - Delay off w/ constant supply
U (2
3
U (2
6
Start ( 2
6
Gate ( 2
5
Gate ( 2
5
eset ( 2
R1 ( 1 3
7
Reset ( 2
R1 ( 1 3
7
4
4
R2 ( 8
9 11 )
R2 ( 8
T
t1 t2
T=t1+t2
T
U (2
6
Start ( 2
6
Gate ( 2
5
Gate ( 2
5
Reset ( 2
R1 ( 1 3
7
Reset ( 2
4
R2 ( 8
t1 t2
T=t1+t2
T
T
T
Function Ac
Timing after closing and opening of control contact
10 )
U (2
Start ( 2
T
T
9 11 )
T
Function G
Cyclic function
T
10 )
T
T
t1 t2
T= t1+t2
T
Function W
Timing after impulse on control contact
10 )
Start ( 2
T
T
T= t1+t2
9 11 )
T
T
P
P
10 )
7
R1 ( 1
3 4
R2 ( 8
9 11 )
T
t1 t2
P
t3 t4
P
P = t1+t3+t4
T = t1+t2
T
T
T
T
t1 t2 t1 t2
T=t1+t2 T=t1+t2
T
T
T
Function Bw
Pulse output (adjustable)
U (2
10 )
Start ( 2
6
Gate ( 2
5
Reset ( 2
7
R1 ( 1
3 4
R2 ( 8
9 11 )
T
T
T
t1 t2
t1
T=t1+t2
T=t1+t2
t2
T
T
Function L/Li - G/Gi
Cyclic timing : asymetrical recycler
L
U (2
Li
G
Gi
10 )
Gate ( 2
5
OFF start / ON start ( 2
6
L /G ( 2
7
R1 ( 1
3 4
R2 ( 8
9 11 )
Ton
Ton
Ton
Toff Toff
t1 t2
t1 t2
Toff = Ton =
t1+t2 t1+t2
Ton
Ton
t1
Toff
t2 t1 t2
Toff
Ton = Toff =
t1+t2 t1+t2
P
Ton
P
t1
t2
t3
t4
Ton = t3+t4
P=t1+t2+t4
Ton
T
Ton
T
t1 t2
t3 t4
Ton = t1+t2
P=t1+t2+t3+t4
3
T
很抱歉,暂时无法提供与“88 886 016”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+840.52162
- 25+825.80687
- 50+810.46729
