GN325ASZH
GN325ASZH
    CROUZET(高诺斯)
    CROUZET - GN325ASZH - SOLID STATE RELAY/25A/24-510VAC/PANEL
GN325ASZH 数据手册
|   05/2021 › GN3  Series Classic Solid State Relays Panel Mount – Three phase › For frequent start/stop operation of Three-Phase Heaters or Motors › A market favorite for many years › 25 and 50 Amps › 3 legs control › Output overvoltage protection › Zero Cross Turn-On and Instantaneous (Random) › cRUus, CE and UKCA Recognized Zero Cross Version Instantaneous Version (Marking label 26532004 sold separately) (Marking label 26532004 sold separately) Product Selection - Zero Cross (Resistive Loads) Rated Load Current 25 A Output Voltage 24-510 Va 50 A 24-510 Va Control Voltage 4-32 Vc GN325DSZH GN350DSZH 24-255 Vz GN325ASZH GN350ASZH Product Selection- Instantaneous (Random) (Inductive Loads) Rated Load Current 25 A Output Voltage 24-510 Va PART NUMBERING SYSTEM 50 A 24-510 Va Control Voltage 4-32 Vc GN325DSRH GN350DSRH Part number system GN3 Triphase Series 8413: GN3 Series GN3 Control Voltage A: 24-255 Vz D: 4-32 Vc 25 D Output Current 25: 25 A 50: 50 A Switching Type R: Instantaneous Z: Zero Cross S R Overvoltage Protection S: Yes H Output Voltage H: 24-510 Va RÉFÉRENCEMENT Séries Tension deContact commande Type de commutation Do you need an adapted or customized solution? us on www.crouzet.com 8413: Gamme GN3 A: 24-255 Vz D: 4-32 Vc Description: R: Instantanée Z: Synchrone Crouzet Solid State Relays are designed to be used in almost any application, offering very long life expectancy and are easy to install, easy to use, GN3 25 robust and multipurpose. D S R H For more information about Crouzet’s Solid State relays, please visit www.crouzet.com. Courant de sortie 25: 25 A 50: 50 A Protection surcharge en tension S: Oui Tension de sortie H: 24-510 Va |   WWW.CROUZET.COM |  2 |   GN3 Series |   05/2021 Accessories Type Description Heatsink 0.9 °C/W Thermal Resistance 26532752N Heatsink 1.2 °C/W Thermal Resistance 26532754N Adapter For DIN Rail 26532765N ID Tag Marking label 16 x 8 x 1 mm 26532004 Thermal Grease Thermal Grease for Heatsink mounting 26532003 Screws Screw Mounting Kit 26532002 Part-Number Output Characteristics (1) Description 25 A 50 A 24-510 Va Operating Voltage (47-440Hz) [Vrms] (4) Load Current, General Use UL508 /AC51 @ 40 °C [Arms] (5) 3 x 25 @40°C 3 x 50 @40°C Load Current, AC-53a @ 480 Va [Arms] 5A 12A (2) (5) (2) Minimum Load Current [mArms] 5 Transient Overvoltage [Vpk] 1200 (1100) 1200 (950) Maximum Surge Current (50/60 Hz (typ.@ 50 °C, 1 Cycle) [Apk] 320/_ (min) 420 (typ) 700/_ (min) 750 (typ) Maximum I²t for Fusing (50/60 Hz 1/2 cycle) [A² sec] 512 (min) 880 (typ) 2450 (min) 2800 (typ) 230 1 second surge current (Apeak. Ta = 25 °C) 50/60 Hz 96 Minimum Off-State dv/dt @ Maximum Rated Voltage [V/µsec] 500 Maximum Off-State Leakage Current @ Rated Voltage [mArms] 1 Maximum On-State Voltage Drop @ Rated Current [Vpk] 1.375 Thermal Resistance Junction to Case (Rjc) [°C/W] 0.7 0.4 0.82 5.2 0.26 1.5 Minimum Heatsink for rated Current @ 40 °C [°C/W] AC-51 (5) AC-53 Minimum Power Factor (at Maximum load): GN325ASZH / GN350ASZH (6)GN325DSZH / GN350DSZH / GN325DSRH / GN350DSRH 0.8 0.5 HP Ratings at 120V / FLC [Arms] (2) 0.75 / 6.4 1.5 / 12 HP Ratings at 240V / FLC [Arms] (2) 1 / 4.2 3 / 9.6 HP Ratings at 480V / FLC [Arms] (2) 3 / 4.8 7.5 / 11 Input Characteristics (1) Description Control Voltage Range 4-32 Vc 4-32 Vc 24-255 Vz 24-255 Vz Minimum Turn-On Voltage 4 Vc 24 Vz Must Turn-Off Voltage 1 Vc 2 Vz Maximum Reverse Voltage -32 Vc N/A Minimum Input Current [mA] 20 mA 5 mA (AC) 4 mA (DC) Maximum Input Current [mA] 25 mA 7 mArms Nominal Input Impedance [Ohms] Current Regulated Maximum Turn-On Time 1/2 Cycle 25 ms Maximum Turn-Off Time 1/2 Cycle (3) 50 ms |   WWW.CROUZET.COM |  3 |   GN3 Series |   05/2021 General Characteristics Description 25 A 50 A Dielectric Strength 50/60 Hz (Vrms) 4000 (Input-Output-Case) Minimum Insulation Resistance (@ 500 Vc) 109Ω Maximum Capacitance, Input/Output 0.8 pF Ambient Operating Temperature Range -40 ºC to 80 ºC Ambient Storage Temperature Range -40 ºC to 100 ºC Housing Material UL94 V-0 Basplate Material Aluminium Terminals Screw Type Control wiring Screw Torque (in-lb/Nm) 11-18/ 1.2-2 Power wiring screws Torque (in-lb/Nm) 18-26/ 2-3 Humidity 85 % non-condensing Input Status Indicator LED Green Weight (g) 200 MTBF (Mean Time Before Failure) 63 General Notes (1) All parameters at 25 °C unless otherwise (2) Only for Instantaneous (Random) Version (3) For Instantaneous (Random) =
GN325ASZH 价格&库存
很抱歉,暂时无法提供与“GN325ASZH”相匹配的价格&库存,您可以联系我们找货
