Single direction synchronous geared motors
Constant speed, dependent on supply frequency
Wide range of speeds
Direction of rotation controlled by long-life mechanical
anti-return (>107 starts)
Permanent magnet rotor
Types
Applications
- Programming devices
(time base)
- Office equipment
- Medical equipment
- Motorised displays
- Scanners
- Moving light displays
- Pumps
Motors :
- other voltages/frequencies
- lead length
- output lead at 120° from standard
angle (clockwise or anti-clockwise)
- fixed by screws not clips
82 344 0
82 344 0
82 344 0
230 V 50 Hz
230 V 50 Hz
240 V 50 Hz
240 V 50 Hz
Anti-clockwise
Clockwise
Anti-clockwise
Clockwise
82 344 736
82 344 698
82 344 690
Output speeds (rpm)
60
50
48
30
24
15
12.5
12
10
9.6
8.33
7.5
6
5
4.8
4
3
2.50
2.40
2
1.67
1.60
1.20
1
0.83
0.80
0.56
0.5
0.42
0.33
0.28
0.25
0.21
0.20
0.17
0.10
Made to order products,
non stocked
2
82 344 0
Voltage and frequency
Ratios (i)
10
12
12.5
30
36
40
48
50
60
62.5
72
80
100
120
125
150
200
240
250
300
360
375
500
600
720
750
1080
1200
1440
1800
2160
2400
2880
3000
3600
6000
Part numbers
7200
9000
12000
14400
36000
43200
54000
72000
108000
144000
180000
216000
432000
864000
82 344 744
82 344 738
82 344 739
82 344 740
82 344 741
82 344 743
82 344 752
82 344 754
82 344 755
82 344 756
82 344 765
82 344 766
82 344 775
82 344 771
82 344 772
82 344 773
82 344 746
82 344 747
82 344 748
82 344 749
82 344 751
82 344 760
82 344 762
82 344 763
82 344 764
82 344 757
82 344 758
82 344 768
82 344 778
82 344 779
82 344 780
82 344 699
82 344 692
82 344 693
82 344 694
82 344 695
82 344 697
82 344 706
82 344 708
82 344 709
82 344 710
82 344 719
82 344 720
82 344 729
82 344 725
82 344 726
82 344 727
82 344 691
82 344 700
82 344 701
82 344 702
82 344 703
82 344 705
82 344 714
82 344 716
82 344 717
82 344 718
82 344 711
82 344 712
82 344 722
82 344 732
82 344 733
82 344 734
Output speeds (rev/hr)
5.00
4.00
3.00
2.50
1.00
0.83
0.67
0.50
1/3
1/4
1/5
1/6
1/12
1/24
Gearboxes :
- other output speeds
- ball bearings
- special shaft
- special lubrication
- fixing by M3 holes
Standard gearbox shaft: see dimensions
Options : for made to order products non stocked
Voltages / Frequencies
24 V 50 Hz
24 / 115 V 60 Hz
48 V 50 Hz
For version with no anti-return (SAR version see page 2/6)
Free-wheel device : Y system (see page 2/34)
Torque limiter F symbol (see page 2/34)
Gearbox shaft round
79 200 967
pierced
79 200 779
Ø 6 with flat
79 999 421
Other information
For basic principles, see page 2/6
The speed of a motor powered by a
60 Hz supply is 20% higher than that
of a motor powered by a 50 Hz
supply.
2/14
Downloaded from Elcodis.com electronic components distributor
General characteristics
Type
Motor
Gearbox
Maximum permitted continuous
rated gearbox output torque
for 1 million gearbox revolutions
Clockwise
82 334 734
82 334 726
82 334 811
82 334 803
82 334 758
82 334 759
82 334 760
82 334 769
82 334 748
82 334 744
82 334 741
82 334 764
82 334 766
82 334 767
82 334 768
82 334 761
82 334 742
82 334 751
82 334 808
82 334 810
82 334 772
82 334 774
82 334 775
82 334 776
82 334 785
82 334 796
82 334 792
82 334 794
400
300
200
150
100
80
60
40
30
82 334 818
82 334 780
rpm
rpm
2
82 334 799
82 334 801
30
(pushed-in shaft ←)
82 334 789
10 15
60
Dimensions
82 344 0 - 82 334 5
82 334 777
6
3 4
5
82 334 782
82 334 783
82 334 784
82 334 5
500
23,8
13,2 max.
23,8
3,2
2 fixing
holes Ø 3.2
8
Fixing claw
Ø 50,5
17,2 max.
55,5 max.
4
Type
82 344 0
82 334 5
L1
2
L1 (mm)
35.6 max.
41.65 max.
Products available to order : gearbox output shaft
Shaft 79 200 967
(pushed-in shaft ←)
Shaft 79 200 779
(pushed-in shaft ←)
Shaft 70 999 421
SP1295-10
13,2 max.
Ø 1,5
13,3 max.
Ø4
82 334 733
82 334 756
82 334 739
82 334 804
82 334 813
82 334 814
82 334 815
15,6 max.
Ø8
82 334 812
82 334 805
82 334 806
82 334 807
14
82 334 731
82 334 727
82 334 736
82 334 737
82 334 738
65,9 max.
82 334 735
82 334 728
82 334 729
82 334 730
82 344 0
mN.m
Ø 12
Anti-clockwise
5 across
flat
Clockwise
1
8
3.5
0.42
55
-5 +60
210
250
IP40
Ø6
Anti-clockwise
1
8
3
0.16
55
-5 +60
160
250
IP40
Ø8
240 V 50 Hz
daN
daN
W
W
°C
°C
g
mm
3.5 across flat
240 V 50 Hz
0.5
Ø 4-0,018
230 V 50 Hz
0.5
Ø4
230 V 50 Hz
1
2
3
4
Nm
Ø8
82 334 5
82 334 5
82 330 5
81 021 0
Ø 47,2
82 334 5
12,75
82 334 5
13,5
82 334 5
Axial load (static)
Radial load (static)
Absorbed power
Usable motor power
Maximum temperature rise
Ambient temperature
Weight
Lead length (approx..)
Protection
Graph of torque versus speed
82 344 0
82 340 0
81 021 0
9
6,8
5
To order, specify :
Standard products
4
Part number
Example : Synchronous geared motor -
82 344 744
Standard products,
non stocked
1
3
5
Type
Direction of
rotation
2
4
Voltage and
frequency
Output
speed
Option
Example : Synchronous geared motor 82 344 0 -
230 V 50 Hz - CW - 0.80 rpm - Round shaft
2/15
Products available to order,
please consult us
很抱歉,暂时无法提供与“82344780”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1077.968881+139.45173
